JCW 2021 JCW and Eventuri intake.
Old Dec 12, 2024 | 03:39 PM
Apollyon78's Avatar
Apollyon78
I recently purchased an Eventuri Intake for my JCW and have run into a small issue. In the past I installed an MMR intake resonator delete and their silicone intake hose to match up with it. The delete and hose work perfectly with the stock air intake, but when installing the Eventuri, the MMR silicone intake hose is too long to work with the intake. It is about a 1/4" to 1/2" too long and pushes the Eventuri filter housing forward which misaligns everything and doesnt allow for a good or proper seal. To install the Eventuri, have it seat properly and position correctly I need to use the stock plastic intake hose. I'd like to be able to use the silicone hose and wanted to check and see if anyone has run into this before? Any suggestions or advice would be appreciated!
Old Dec 13, 2024 | 05:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
It should be pretty easy to trim the silicone hose 1/4"-1/2", either from just one end or both, just to get it to fit.
Old Dec 20, 2024 | 09:24 PM
michaelo's Avatar
michaelo
What's the purpose of the intake? It won't give any significant gains.
Old Dec 20, 2024 | 09:48 PM
Agbullet25's Avatar
Agbullet25
What's the purpose of asking a question that's not helpful to the OP's situation?
Old Dec 20, 2024 | 10:22 PM
michaelo's Avatar
michaelo
I asked it for my situation.
Old Dec 21, 2024 | 11:40 AM
Agbullet25's Avatar
Agbullet25
That's not at all how your comment was phrased to be taken.
Old Jan 7, 2025 | 12:42 PM
Cableaddict's Avatar
Cableaddict
My local, uber-expensive "Euro sport cars only" repair / mod shop says the Eventuri absolutely makes a significant difference on BMW's, using basically the same engine.
No reason to assume the Mini would be different.
Old Jan 16, 2025 | 10:58 AM
FlyingScot57's Avatar
FlyingScot57
Just trim the hose to fit and enjoy the intake. I have one, not sure of gains as I’m tuned but do like it. Helps lower my intake temps a bit (I log obd data), I get a functional hood scoop vs fake, and the carbon fiber intake alone costs $500+…so I get that plus a an arguably functional cold air intake.
OP - enjoy the car, add a hardpipe if you want to hear the intake noises even more
Old Jan 16, 2025 | 11:16 AM
Cableaddict
Originally Posted by FlyingScot57
......OP - enjoy the car, add a hardpipe if you want to hear the intake noises even more
I second this suggestion.
I'm not sure myself about the intake, still on the fence, but I did install a Dinan intake pipe (basically a resonator delete, which thankfully is legal) and I love the subtle sonic difference.
"Just enough" of the right sounds, without being annoying. I takes a while to install it, though.
Old Jan 16, 2025 | 01:42 PM
FlyingScot57
It takes a while to install it, though.
Yeah tight but take the time to remove the “apron” below the windshield. Might take 15 minutes but will save you hours and much frustration…gives a lot more space to work with. A lot of installs and videos show them trying to work with the space ‘as is’. I’ve learned, take the time to remove stuff and open up working space, you will never regret that on the mini
Old Mar 26, 2025 | 12:54 PM
FlyingScot57
Added the Dinan Hardpipe, removed the apron and job was not bad. Key thing here is track the parts and DO NOT let anything get into the turbo inlet while working. Minimania YouTube guy had a turbo go on him when something (a piece of plastic?) got in. Also have to say - for $119 USD the Dinan Hardpipe is a nice piece of kit for 1/3 the price of forge. Forge looks nice too but the welds on the Dinan are top notch and a high quality product that fits great. Butt Dyno says better throttle and definitely can hear the turbo “whoosh”. I have a tune on the car, and with that pipe being almost 10 years old…plastic gets brittle and breaks so reliability a good reason to update.
veelangs
Jun 3, 2021 03:42 PM
Greg Eldada
Jul 24, 2019 07:33 PM
JaysinStrife
44
Oct 9, 2015 08:09 AM
cargod4490
11
Aug 14, 2012 11:06 AM
