PDA
View Full Version : F55/F56/F57 Stock Problems/Issues
Pages : 1 [2] 3
  1. Mini Cooper F56 Failed Update
  2. False Low Oil Alert
  3. Coolant level
  4. F55 with Automatic Transmission Jerks in First Gear
  5. Burnt Oil on my rear bumper?
  6. 2016 f55 avg 16mpg
  7. Mini Cooper F56 - 2015- Issues when applying breaks
  8. 2014 F56 Starter/Ignition Failure
  9. Where is the EVAP Purge Solenoid/EVAP Charcoal Canister?
  10. 2017 Conv. Fuel issues
  11. Transmission Squealing in 1st and 2nd gear!!
  12. Stripped oil pan bolt thread
  13. Thumping when engine shut off - NonTurbo
  14. Auto headlamps don't go off
  15. Windshield Washers Stopped Working
  16. Suspension/Alignment Issue 2016 F56 JCW
  17. Mini F56 Cooper S B48 Engine hesitation at mid rpms
  18. Please help any insight stuck in limp mode
  19. Need assistance
  20. To extend the warranty or not to extend....?
  21. Vibration or Tremble?
  22. Bottom row of gears stuck.
  23. Lost Key Fob (comfort access)
  24. MPG loss
  25. 2015 F55 Cigarette Lighter socket
  26. 2016 MCS Harmonic Balancer
  27. "Loose" sunshade cords?
  28. Driver side mirror glass vibration/shake
  29. Sunroof Screens Rattle
  30. High beam headlight shadows make using high beams unsafe
  31. Bubbling headlight trim
  32. A/C Blowing Warm Air
  33. Would someone with an F55 please take a roof rails measurement for me?
  34. Broken T-Map Securing Clip
  35. Issue with steering wheel control
  36. What is this buzzing noise in my footwell?
  37. Hood stuck, won't release one side
  38. Coilover Installation Issue?
  39. Jerky Ride
  40. 2016 countryman s awd repairs!?
  41. new mini windshield distortion
  42. Brake Wear Sensor Warning
  43. F56 B38 Engine Binding Vanos
  44. Front plastic behind license plate...
  45. Air conditioning issue f56
  46. Bang! Detonation while on red light stop.
  47. Lighting system stop carefully
  48. Pulling Left under throttle / right under decel
  49. ABS wheel sensor code
  50. P0004 Error Code
  51. Where's the cabin filter on 2015 4door?
  52. Car goes left
  53. F56 Cooper S Whine Noise (video)
  54. F56 Headlight Adjustment
  55. P0015, P0014 Help!!
  56. F56 Cooper S rear suspension issues
  57. Reset Service Interval
  58. Auto Transmission shift shudder
  59. Manual transmission 1st gear question.
  60. 2016 conv alarm issues
  61. Engine stopping the last 2 days after coming to a stop (not stand-by)
  62. Cross threaded lug bolt.
  63. P144b
  64. Plastic Composition Or Actual Glass ?
  65. P2270 code from hell
  66. 2008 automatic transmission
  67. 2015 MC Engine Recall
  68. Can't fill up my 2016 4 door
  69. 45000 miles - major $3800 repair 2009 Clubman
  70. Bad o2 sensor at 33,500 miles?
  71. Aerodynamic noise at high speed
  72. HELP with Parts needed for repair!
  73. Backup Camera Failure
  74. once again a Mini S owner (2014)
  75. Dent in Passenger side Knee Bolster
  76. 2013 Mini low oil pressure light
  77. How to keep the green light on around the information center.
  78. Why Aux in is very loud vs Bluetooth or Any music app?
  79. 2016 Clubman S issues
  80. Shaking at Idol (Manual Transmission)
  81. Fault/Error Code
  82. 2003 mini ac problems
  83. Water leaking down interior of door
  84. Front strut brace - install question
  85. ABC Reports BMWs Catching Fire
  86. Stalling when reversing after cold start
  87. Transmission fluid/filter issue?
  88. Tire Pressure Indicator
  89. Stubby Antenna Reception
  90. whinning with speed, cv joint?
  91. Lugs stripped
  92. 2015 MCs P143c
  93. iDrive Touch?
  94. Side scuttle removal F54
  95. Leatherette Defect?
  96. Panoramic Sunroof Won't Open
  97. Passenger airbag off light staying on
  98. F55 B pillar/seat belt area noise/rattle
  99. Automatic Transmission Fluid Question
  100. Vibration during idle
  101. Auto Climate Control - Not FULLY Auto
  102. Fuel System Leak Diagnosis Module (NVLD)
  103. Automatic Climate Control Question
  104. Drivetrain malfunction
  105. Creaky Clutch?
  106. Side marker S faded out.
  107. 2016 F55 S idle control: speed to high issue
  108. Bluetooth problem
  109. 3 cyl - engine noise on startup
  110. Center Display LED Ring Strangeness
  111. Heater noises....
  112. title error mistake by dealer
  113. front end clunking noise
  114. Help find parts from shifter assemly
  115. 2015 Mini Cooper S Brake Light Reset
  116. Noise from Power Steering.
  117. Convert...noisy operation
  118. 4 way flasher
  119. 2006 Mini-Coooper S whining/revving issue
  120. Interior fan vibration
  121. right cornering light malfunction
  122. Issue : fuel levels not being equalized !
  123. Brakes and Hesitation
  124. Mini Cooper s p2421 vent valve open
  125. Fuel tank system issue !!!
  126. Door Locking
  127. Quick Sanity Check
  128. Clubman passanger seat noise
  129. Side window seals failing?
  130. DIY Rear Brake Job
  131. Air conditioning issues
  132. Emergency brake
  133. New (again) to forum - Owner's Manual
  134. Backup camera
  135. Low RPM Hesitation
  136. small piece missing from bumper
  137. Electronic Malfunction
  138. 2011 Hatchback Cigarette Lighter fuse - help!!
  139. F56 - Any reports of carbon buildup?
  140. R60 codes galore + misfire/hesitation
  141. Tachometer not working
  142. Fix for Horn Problem/Delay
  143. Drivetrain Error
  144. White Grease Leak
  145. And it gets worse... Air in ABS pump
  146. Brake frustration on 2015 cooper S
  147. Alignment issue after spring install
  148. Backup camera not working
  149. P.O.S. Pirelli RFT
  150. Add'l 6 yr/100,000mi no-cost maintenance a good idea?
  151. B38 3cyl Turbo Oil Return Line Leak
  152. Light out warning after led swap HELP!!!
  153. Wax type stuff coming out of hood
  154. secret compartment
  155. Replacement engine B46 or B48?
  156. OEM Wheel
  157. 2015 S hardtop klunking noises front end and in rear
  158. Drivetrain Malfunction Error
  159. Loss of power after engine recall / drivetrain malfunction software upgrade
  160. Parking brake on while moving
  161. Engine light
  162. Possible Electronic Dipstick Malfunction.
  163. Rear wing air bubbles
  164. Lost all personalized settings....
  165. F56 Power steering... pulsing?
  166. Instrument lighting dim during the day
  167. Bearing recall TSB procedures
  168. iPhone 6S Bluetooth connect problems
  169. Driving mode selector feels sticky
  170. This is interesting....
  171. Passenger Seat Trouble
  172. Sirius Coding-- Dealer Can't Figure it Out
  173. Desperate Need of Help! 2009 Clubman- 55k- needs new engine and water pump
  174. Strange rattle and rear window washer
  175. Center Console LED Ring Light
  176. Brake rotor (brake disk) uneven wear
  177. fog!!!
  178. Too much play in steering wheel
  179. Paint chips on my bonnet.
  180. No Sport Mode?
  181. squeaky noise from steering
  182. Scrolling through songs on ipod connected via USB - problem
  183. F56 manual trans owners: new software update!
  184. 2004 Mini will not start?
  185. F55 Trunk Open Warning
  186. F55 body panel crooked
  187. Mystery Dash Warning - Anyone Know
  188. Slow Clock ????
  189. Rodent damage 2015 cooper S
  190. Squealing from gearbox (I think)
  191. Replacing the battery in 2011
  192. Electrical problems?
  193. Driver side headlight and wipers not working.
  194. Engine replacement issues?
  195. I smell gas
  196. 2015 R56 Daytime lights - anyone change to led no error bulb
  197. Engine Squeal 2015 JCW
  198. F56 airbag recall
  199. Rough downshifting with a jerky stop 2015 MCS
  200. Intermittent pop from audio system
  201. Engine Light ON F56s
  202. Any good pictorial or video install of the LED fog lights
  203. USB Memory Stick Not Working 2015 f56 Mini Cooper
  204. Car making horrible screeching sound!!
  205. New Recall 2014 S HDTP
  206. 2016 radio echo
  207. f56 Auto dimming of the dash / nav brightness
  208. 2015 Mini Cooper Hardtop Mud Flaps Install Instructions where
  209. Bumper Defect!!
  210. PDC and active cruise control sensor error
  211. Automatic Climate Control - Blower Fan Issue?
  212. Does the f56 mini come with a plastic thermostat housing
  213. Car keeps popping out of 1st gear
  214. Service Manual - F56 (2014+)
  215. AC doesnt feel as cold as it seems it should
  216. Headlight Malfunction.
  217. Green mode - miles saved counter intermittent fail and even resets
  218. MCS Chrome Exhaust Tips Poor Quality
  219. Sunroof Won't Open
  220. Extended maintenance and extended warranty
  221. How did you remove this tag?
  222. Removing Dash Air Vent
  223. climate control comes on automatically
  224. Problem locking doors with Comfort Access
  225. Bad air smell
  226. Headlight condensation
  227. Successfully removed cosmoline stain on brack trim
  228. Engine light
  229. Tire mixup and dealer problems
  230. Radio Issues
  231. New to mini world
  232. battery removal
  233. Whistling Noise, a different one
  234. Goodbye BMW- Had Enough of my F56
  235. Run Flat Issue
  236. Door pillar paint rub
  237. Comb connector
  238. MINI Connected problems with Android
  239. Revs dropping slow when upshifting
  240. Vehicle Off Road with Steering Failure
  241. Lemon or not
  242. sick of searching for answers! too many issues
  243. Wet Windows
  244. 2014 MCS in for Computer Issues
  245. Computer Codes (CEL)
  246. High Pitched Squeal
  247. 2015 LED Headlights aimed too high?
  248. Gas surge in complete stop-and-go traffic. 2015 F56 Automatic.
  249. All options + settings were reset (favorite stations, key options, language, etc)
  250. Kudos to Pirelli
