F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Where is the EVAP Purge Solenoid/EVAP Charcoal Canister?
Old Mar 7, 2019 | 08:33 AM
Arrivederci Zagato's Avatar
Arrivederci Zagato
I'm having some issues with a lazy ignition after fueling and would like to attempt a DIY solution. The car in question is a F55 2.0l B48. Thanks!
Old Mar 9, 2019 | 07:03 PM
spotted's Avatar
spotted
Seems like a few people are starting to have this problem. Very easy fix.
I put this in another thread about the same issue:
The Fuel Tank Vent Valve is failing. Easy to replace. But if you're still under warranty then have them fix it.
https://www.newtis.info/tisv2/a/en/f...ion/1VnXuZr3fG
Part number 13907621174 and it's around $90
I was having this problem also and it would hesitate to start when filling up the tank. I have a 2015 F56S
Old Mar 9, 2019 | 07:55 PM
Arrivederci Zagato
Aha, there she is! I would have thought it was a little further down in the bay, but no you can literally see it straight away. Thanks a lot, I really appreciate it!
Old Mar 10, 2019 | 07:48 AM
spotted's Avatar
spotted
No problem!
Old Mar 10, 2019 | 04:13 PM
Arrivederci Zagato
Ok, so I checked it out yesterday and was about to pull the valve out for testing when the connector in #1 of the diagram stumped me. It seemed like however I depressed the white switch, the connector would not yield. Do you remember anything about this specific part of the process when you changed yours?
Old Mar 10, 2019 | 08:44 PM
spotted's Avatar
spotted
I believe that was the connection lock for the sensor. They pop up a little but have to be careful cause they can fly off easy and you'll have a hard time looking for it. Not sure how to describe how to do it.
Old Mar 11, 2019 | 03:25 PM
TVPostSound's Avatar
TVPostSound
Could this be the reason I hesitate at lights, after a fill up for a few minutes???
Old Mar 11, 2019 | 03:31 PM
spotted's Avatar
spotted
That was the problem I had. This fixed it.
It only happened after a fill up, any other regular start-up it didn't hesitate.
Old Mar 11, 2019 | 03:38 PM
TVPostSound
Thank you!
Im going in for my free service next week , Ill bring it up!!
Is it a known issue?
Old Mar 11, 2019 | 04:44 PM
spotted's Avatar
spotted
Thank you!
Not sure but i've seen it pop up on forums.
Old Apr 27, 2019 | 12:41 PM
Jf1000's Avatar
Jf1000
Our F55 has the delayed start(10-20 seconds) after fueling. I tried cleaning the valve which didn't fix it. Just ordered a new one on minipartsdirect for 97usd delivered. Stay tuned I'll post if it fixes it.
direct
Old Apr 27, 2019 | 08:17 PM
Arrivederci Zagato
direct
Ah, sorry I forgot to update this thread! I bought a used one from eBay a month ago and it worked like a charm. Have absolutely none of the issues that I previously had. Good luck to you and hope yours turns out the same way as mine!
Old May 4, 2019 | 11:42 AM
Jf1000's Avatar
Jf1000
Replacing the fuel tank valve fixed this problem
X
Originally Posted by jf1000
our f55 has the delayed start(10-20 seconds) after fueling. I tried cleaning the valve which didn't fix it. Just ordered a new one on minipartsdirect for 97usd delivered. Stay tuned i'll post if it fixes it.
Direct
Old Jun 8, 2020 | 09:22 AM
Dorothy Simons's Avatar
Dorothy Simons
I have the same problem in my 2015 F56 and also I scan it and the error was P0456 because the engine light appears. Did you scan your mini?
Old Jun 8, 2020 | 09:55 AM
spotted's Avatar
spotted
I believe I did but I don't remember what the code was.
Old May 14, 2021 | 07:08 AM
Third Ave's Avatar
Third Ave
I HAVE THE SAME ISSUES .. ON MY F56 WITH BIMMERCODE ERROR 190302
fuel tank ventilation system and purge air system minor leak leakage greater than 0.5 mm
any help ?
Old May 14, 2021 | 09:33 AM
Arrivederci Zagato
any help ?
I ended up replacing my evaporator purge valve (part number 13907621174). Cheap and easy to replace. It is located at the very front of the engine (closest to bumper) underneath the engine cover.
Old Aug 8, 2021 | 07:15 AM
manny1976's Avatar
manny1976
Question Vapor Canister Purge Valve
does anybody have picture of where this is located , I'm trying to replace it myself on an 2015 F56
Thanks,
Old Aug 8, 2021 | 07:17 AM
manny1976's Avatar
manny1976
I need to replace this valve do have any picture of where this valve its at,
Old Sep 12, 2021 | 04:52 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
Did you get a reply to your question? I just replaced the part (it's easy!) and I can take a picture of its location for you. PM me if you need me to.
Old Sep 13, 2021 | 04:06 AM
manny1976's Avatar
manny1976
Hello Eric
I found the location once received the part I realized it was right in front of me.
Thanks for the help.
Old Sep 22, 2021 | 02:08 PM
rpslee's Avatar
rpslee
@manny1976 @eric.stewart Was it easy to replace yourself? my car idles terribly, so i'm thinking it might be the Purge Valve and want to order/replace it myself. Mechanics quoted me like $400+
Anything special you have to do like bleed the lines?
Old Sep 22, 2021 | 03:37 PM
eric.stewart
7 minute job and no tools. No need to bleed lines or anything like that.
Old Sep 27, 2021 | 11:50 AM
TVPostSound
Purge valve issues on F series is hard start after fuel fill.
Old Sep 27, 2021 | 11:59 AM
eric.stewart
That is *one* of the issues and the one which was covered under a recall as it's the most obvious. Other symptoms may include cold start stumble and part-throttle hesitation and also inability to fill the fuel tank.
pocketmaster
Aug 6, 2015 01:41 PM
bavmotors
Nov 30, 2014 01:27 PM
zgokart
Jun 30, 2011 10:03 AM
Raley
Cooper (non S)
Feb 9, 2011 05:38 PM
orangegirafe
May 26, 2010 04:11 PM
