F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Door Locking
Old Sep 20, 2016 | 10:31 AM
RiBarrett's Avatar
RiBarrett
Door Locking
In order to get my door to lock using the button, it generally takes 3 pushes of the button. It always opens on one push. Dealer has no solution to get it to lock on one push. Any suggestions?
Old Sep 20, 2016 | 12:30 PM
ASKtheteach's Avatar
ASKtheteach
I'm going to assume you're referring to a car with Comfort Acess. Mine does the same. If both (or all four doors on an F55) are not unlocked, one push unlocks the passenger door (or the other three on an F55). Another push locks both (or all). My solution is simple. Hit the unlock button by the inside door handle before I get out of the car. Then, when I close the door and push the Comfort Access button on the exterior door handle, both doors lock on the first push.
Old Sep 24, 2016 | 12:38 PM
RiBarrett's Avatar
RiBarrett
Your suggestion works, but it seems like there is a software issue. The dealer states there is no service bulletin.
Old Sep 24, 2016 | 04:25 PM
Lucila's Avatar
Lucila
I brought this same issue up on my second date appointment. They told me it was programmed that way. It's not a defect. I just hit the unlock before I get out and then one push locks it. You will notice that if you have a passenger, you won't need to hit the unlock button before getting out. If both doors are opened before you lock, it will only take one push.
Old Oct 1, 2016 | 06:45 PM
Miniblue2's Avatar
Miniblue2
F55 - Mine locks everything one push. Do you have the software set to unlock all doors with one push?
Old Oct 3, 2016 | 10:38 AM
RiBarrett's Avatar
RiBarrett
I have it set to unlock all doors. This unlock always works with one push of the button. Pressing the unlock button inside the car or opening one of the non-drivers doors also insures that the car locks with one push of the comfort access button. Otherwise, it often takes 3 pushes.
Old Oct 12, 2016 | 06:17 PM
umberto's Avatar
umberto
my F55 locks all doors on the first push
Old Oct 15, 2016 | 12:00 AM
johntotah94's Avatar
johntotah94
Mine used to have an annoying delay.
You can solve this by turning off one of the settings in the comfort Access settings screen. I can't remember which one on the top of my head.
I think it was "lock doors after driving" or something. Turn that off and you get instant response locking doors with comfort Access after driving. Made me so much happier.
Old Oct 21, 2016 | 01:22 PM
RiBarrett's Avatar
RiBarrett
Seem to resolve the problem. Thanks.
Sep 27, 2016 07:28 PM
GregoryK
Sep 15, 2016 02:52 PM
thomasdmini
Sep 14, 2016 09:22 AM
LormaD
Sep 8, 2016 12:52 PM
Jaden Korth
Sep 6, 2016 08:23 AM
