F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Sunroof Won't Open
Old May 10, 2015 | 10:38 AM
ebMiniGuy's Avatar
ebMiniGuy
Sunroof Won't Open
I guess I'll be dropping my 2015 cooper S off at the dealer this week. My sunroof suddenly stopped working yesterday. Luckily it stopped working in the closed position.
Before I take it to the dealer, I would like to check the fuse. I found the fuse panel behind the glove box, but I can't find a mapping of fuses to the accessories that they belong to. Does anyone know where I can find the fuse diagram?
Thanks in advance!
Old May 10, 2015 | 08:01 PM
marshun's Avatar
marshun
Mine did that once. The dealer performed a reset by holding the switch closed for 30 seconds and then open for 30 seconds (if i remember right).
Old May 10, 2015 | 09:10 PM
ebMiniGuy's Avatar
ebMiniGuy
Well I'll be damned. It worked. Thanks for the tip
Old May 11, 2015 | 06:16 AM
hammerhands's Avatar
hammerhands
The should be a fuse map in the fuse box with icons that you can't interpret.
There is a photo of it, let me see...
https://www.northamericanmotoring.co...n-the-f56.html
https://www.northamericanmotoring.co...-fuse-box.html
Old May 11, 2015 | 08:24 AM
ebMiniGuy's Avatar
ebMiniGuy
hammerhands, thank you for the links. I did end up finding these with the search, but as you said the icons will take a little getting use to. The links should be stickied.
Old May 12, 2015 | 04:35 AM
hammerhands
Someone has an App for decoding BMW icons.
Old Jul 11, 2015 | 01:22 PM
e46jb's Avatar
e46jb
Often when you have a MINI with a black roof and leave it in the hot sun, the roof won't open. Is this the case here?
Old Jul 11, 2015 | 05:13 PM
ebMiniGuy's Avatar
ebMiniGuy
My roof is white.
Old Oct 15, 2016 | 04:54 PM
Kevin Davitt's Avatar
Kevin Davitt
Sunroof
Thanks guys. I had the same problem today and this worked for me as well.
I held the switch in the "closed" position as suggested and "voila!"
When I hit the "open" position it was fixed!
Thanks,
Kevin
Old Oct 16, 2016 | 08:53 AM
ASKtheteach's Avatar
ASKtheteach
I've now had two MINIs with black roofs and this has never happened to me with either car (and I live in South Florida, where it gets very hot).
Old Oct 28, 2016 | 04:18 PM
TybeeJim's Avatar
TybeeJim
How about the dang thing won't close? It opened fine today but when I went to close it, it stopped just this much () short of closing. The rear pane is open and the front as it would be for venting. The motor seems fine and I can't see anything restricting its movement. I took it to a friend mech and he hooked up his computer (BMW) to it. We reset it and it still won't close. It seems like something is resisting at the last second. I tried to wipe out the tracks as best as I could and sprayed some WD-40 on them. All to no avail. The closest dealer is 100 miles away in Charleston! It's a 2007 Cooper S with the JCW package. Oh, and it's for sale at $6900.
Old Oct 29, 2016 | 09:01 AM
TybeeJim's Avatar
TybeeJim
Well, there you go! Went out this morning, pushed the close direction and "Ta Da" it closed!!!! All is well with the world. And I found a potential buyer at the Post Office, too. Checking with the wifey!
Old Oct 29, 2016 | 11:08 AM
JustinGTP's Avatar
JustinGTP
Did you hold it for 30 secs? That will start the reinitialization
Old Oct 29, 2016 | 03:28 PM
TybeeJim's Avatar
TybeeJim
I tried that several times, both at opening and closing. So I'm not sure what worked. I closed it last night as far as it would go, basically the vent position. Left it alone til this morning, went out, started it and pushed the switch to close. It closed! Wouldn't do that last night. 😳
ToyCar
Nov 19, 2023 05:20 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
