Mystery Dash Warning - Anyone Know
Periodically a symbol will pop up on the speedometer message area, bottom left.
It's a 3/4 circle or open circle arrow head with the letters mph on the inside.
it pops on and the off once in a while. I have look to no avail....
No, I do not have the speed limit warning box checked, it is unchecked.
thanks in advance.
thanks in advance.
Were you in green mode? I was on the highway today, going 75-80mph, flipped to green mode and that same symbol showed up, I could only assume it was telling me to slow down to conserve fuel. Flipped back to mid mode, symbol gone.
unknown caution warning symbol on
I have an little yellow warning light on my car its a circle around triangle with an explanation symbol in middle of circle. Does anyone know what it is. Also my airbag symbol it always on why ?
the other maybe a speed wearing above your speed settings.
You can usually find more information in the menu under "Check Control".
MENU->Vehicle Info->Vehicle Status->Check Control.
Attachment is from the MINI Motorer's Guide app.
thanks in advance.
thanks in advance.
If you're not in green, usually this symbol shows up when you have cruise control on, but it doesn't sound like that's the case here
Usually the triangle with an exclamation mark is a general check control message and can mean anything, though I can't think of a symbol with a circle around the triangle. Check control messages can be accessed from your radio; from the main menu, go to VEHICLE INFO, then VEHICLE STATUS, then CHECK CONTROL. You should see a list of open warnings.
Post pictures if you can
black_stallion
R57 :: Cabrio Talk (2009+)
Dec 28, 2015 11:39 AM
Martin-Logan
20
Dec 28, 2015 06:37 AM
SneedSpeed
Dec 22, 2015 08:33 AM
