F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
squeaky noise from steering
Old Feb 14, 2016 | 03:39 PM
jaep1911's Avatar
jaep1911
I have been having squeaky noise coming from the front end of my MCS (Nov 2015 build) when I turn the steering wheel in either direction. I noticed this first time when I was pulling the car out of my garage in the morning but I can hear it even when I pull off from traffic lights and turn right/left. It has started a couple of weeks ago.
I recorded the noise inside the car. Please turn up the volume and listen very carefully. The noise is actually much easier to hear inside the car.
https://www.youtube.com/watch?v=qWkh...ature=youtu.be
Anyone else has had or is having this phenomenon?
Man, I am having all kinds of noise in this car - cluck from the rear shock(s), cracking noise from all the windows when the sun hits the car as if things are expanding and about to explode, and now this noise. Please do not tell me that is normal with the MINI. I have the second date coming up in a couple of weeks and we will have a long conversation then
Old Feb 21, 2016 | 09:00 PM
Gloriakogg's Avatar
Gloriakogg
My car is having the same problem earlier. My car is currently 7 months old with 3,100 km. About a month ago the exact same clicking/grinding noise happened to me when my car was around 2,700 km. It happens when I am trying to turn left at 0-15 km/h. Absolutely no noise when turning right though. My husband and I thought it's related to the cold weather that we are having at that time (-5 to -10 degrees, feels like -15 degree ish), but since it's under warranty so I decided to go back to MINI dealership for a check up anyways. After I got my car back, the dealership said they have fixed the problem but I can still hear it. Just not loud (I am talking about if you turn on your radio with normal volume then you won't be able to hear it at all).
Result from MINI dealership:
"Cause: puma measure #58332673 -05"
"Correction: Heard noise coming from the front of the vehicle. Isolated noise to front end suspension. Searched puma and found measure #58332673, removed both front tires and retightened the screw connection between the swivel bearing and the control arm/wheel control joint as per measure."
So I went back to the dealership for the second time after a week of driving because the noise gotten louder again, but for some reasons the noise just magically disappeared!!! The noise comes and goes for the next week or so. Then it's comely gone after that. I hope it won't come back again.
Old Feb 24, 2016 | 02:20 PM
We talked about it here already
https://www.northamericanmotoring.co...ning-left.html
BadMINI S
Sep 10, 2016 11:15 AM
takrdown
Feb 2, 2016 05:34 AM
itsbrianyo
Jan 25, 2016 03:28 PM
PelicanParts.com
Jan 22, 2016 03:54 PM
shieldsy33
Jan 21, 2016 08:59 AM
