View Full Version : R56 :: Hatch Talk (2007+)
- R56 Reprogram After Walnut Blast Changed Oil Service Interval
- R56 Juvenile Diabetes License Plate
- R56 Car is running lean under load?
- R56 About to order my 2013 MCS - Questions
- R56 Grey smoke
- R56 Dynamat
- R56 Wanted to say hi....I'm baaaack.... possibly.
- R56 Need to replace temperature control knob....
- R56 Green S logo stickers for R56
- R56 Squeak/Creak in Front End
- R56 Difference Between Beru Plugs?
- R56 had electrical glitches on a 2009 with 29K, got new battery and everything is fine
- R56 momentary rant
- R56 Mini Cooper S Hardtop vs the BRZ
- R56 Cross Country Road Trip
- R56 Warranty is about to expire - Anything I should have checked out?
- R56 Trouble Installing Heat Shield
- R56 Mini cooper d stereo pinout
- R56 owner input 2007-2008 mini cooper s
- R56 Satellite radio kit in 2010 Cooper S?
- R56 Air Filter?
- R56 Window Scraper Replacement?
- R56 Waiting game.
- R56 I want to make some car ramps
- R56 rough idling
- R56 Rubber shift boots
- R56 100K Service
- R56 Doesn't smell good
- R56 Weird click when cars off
- R56 Oil leak, white smoke from exhaust! help!!
- R56 garage buddies
- R56 Drivers Side Airbag Fault
- R56 Alta sway bar and Alta end links
- R56 CEL code P0128, bad thermostat?
- R56 2013 MCS w/Connected Snap In Adapter Issues
- R56 Satellite Radio locking up
- R56 2013 MCS Options
- R56 paint "micro" chips in weird places
- R56 MCS R56 Carbon Cleaning
- R56 what happened to my pop and burble??
- R56 bluetooth quality
- R56 Massdrop | [Group Buy Feeler] US Mill Works Tow Hook License Plate Holder
- R56 Massdrop | [Group Buy Feeler] LED Front Driving Light Kit
- R56 Need Cam and Center bolt Torque Specs
- R56 2013 Mini GP Order Sheet
- R56 2011 Cooper (Non S) Oil Leaking
- R56 Moving Bluetooth Mic
- R56 Random "No-starts"?
- R56 Latest Tensioner Info
- R56 Where can I look up the gear ratios?
- R56 What do I have?
- R56 2012 MCS oil change issue
- R56 Identify this part!
- R56 Goodbye
- R56 Does B200 Airbag tool work for R56?
- R56 "AC broken due to suspension being lowered"
- R56 SW change to address intake valve carbon build up...
- R56 Inter cooler muffler delete-Check engine light?
- R56 Aftermarket Parts - Warranty
- R56 Changed key fob battery....now not working...
- R56 "Secret Compartment"
- R56 CC ID 29? High Pressure Fuel Pump? CEL issue. Please help
- R56 "Loose" steering issue - mechanic didn't find anything
- R56 How .8 extra qts. of oil in my Subaru saved my MINI (maybe)
- R56 Coolant Leak...Want to make sure all bases are covered
- R56 Should I Keep It?
- R56 spark plugs recommendation?
- R56 Clicking clattery sound from turbo at moderate acceleration. Help! I'm begging!
- R56 winter tires/wheels question
- R56 TPM light on for all four tires
- R56 Retrofit Dash Trim?
- R56 n18 vs ni4 w/ JCW upgrade
- R56 2011 may have carbon issues
- R56 Weird clicking sound from 09 MCS
- R56 Vinegar smell in A/C and interior vents
- R56 Replacing passanger mirror assembly
- R56 time to have a tune up?
- R56 2012 manual folding mirrors standard???
- R56 Track Questions
- R56 Independent Garage Recommendations - NW Ohio/SE Mich?
- R56 Any 2012 R56 Four-Light Rally Bars ?!?
- R56 TPMS light never illuminates !
- R56 Springs or Sway Bar?
- R56 Selling my 2011 S Hardtop BRG II
- R56 brake sensor on lit yellow. and car on lift lit yellow
- R56 comfort access and stereo
- R56 Rennline Pedals
- R56 2012 Hardtop JCW engine?
- R56 Moisture and condensation in the reverse light?
- R56 New Cooper S Bayswater
- R56 31K miles and need cam chain?
- R56 FES Auto Sportplus Module Review
- R56 JCW Challenge Wing Anyone?
- R56 BOV noise
- R56 Service Light issue!
- R56 '12 Known Issues
- R56 Port and Polish
- R56 Is it possible to twincharge a r56?
- R56 Carbon Build Up Fixes, Catch Can, SeaFoam Etc....
- R56 Rear hatch question
- R56 On the cusp of Justa ownership and could use a second opinion.
- R56 "S" that unreliable?
- R56 3 yr free service is up in oct - what to do?
- R56 Cold Start Issue
- R56 ID on seats plz
- R56 All Stand Please
- R56 To put things in perspective (even for me to an extent)...
- R56 BRG with BRG roof. Anyone have pics?
- R56 Seatbelt chime on a 2012.
- R56 Post pics of Minis with black star bullets
- R56 Praises be to MINI of WESTCHESTER (NY)!!!!
- R56 Tire Psi Sensor rebuilt
- R56 Engine picture needed?
- R56 P0171 engine code on 2012 MCS...Help??
- R56 Advice needed. The question that we will all face.
- R56 Just a question for Justas
- R56 Hard to Start, but runs beautifully
- R56 car pull back when I accelerate
- R56 Subframe Connectors for MINI???
- R56 Where to get one M14 to M12 stud?
- R56 Hard downshifting, Please help!
- R56 Options that you love or hate
- R56 Can you Check if Engine was Replaced?
- R56 First autocross with new Swaybar
- R56 Questions about ordering a 2012 MCS
- R56 Fixing Trim
- R56 MINI 10 Years Anniversary Boot Spoiler
- R56 Turbocharger removal and installation?
- R56 Alignment
- R56 larger wheels & tires = codes?
- R56 Speaker replacement help.
- R56 Had my MINI for ten days... Misery :(
- R56 Power loss after installing intake
- R56 R56 auto trans problem
- R56 What happened to my pops and burbles?
- R56 Looking for info/advice on replacing a speaker.
- R56 JCW Recaro (Sporster CS) Seats
- R56 Sprint Booster
- R56 Am I missing a cover?
- R56 Brakes Sticking for a few seconds?
- R56 AC Nosedive
- R56 Hello! Considering an R56 Mini, need some advice...
- R56 Proper way to advance crank
- R56 Car Wiggles when driving on Concrete Highway
- R56 "debunking the K&N myth"
- R56 Flashing Lights
- R56 Can't change everything to km/h?
- R56 Lightweight Wheels
- R56 Any spoiler changes to 2013 MINI & MCS models?
- R56 2007 mini stuttering at idle. Need help
- R56 Grrr..water tube from thermostat housing
- R56 Smell of Fuel
- R56 Retrofitting aftermarket "wiper delay" box ?
- R56 first maintenance help
- R56 MT for a NOOB
- R56 Let's play a game... where does this line go?
- R56 Looking for help, not judgement!!!
- R56 Bentley manual lets me down!
- R56 Wheel Well Fabric
- R56 removing factory GPS mount
- R56 The Official KNIGHTSBRIDGE Owners Club
- R56 automatic adjusting headlights
- R56 drive by wire?
- R56 Supercharger?
- R56 Speaking of Transmissions...
- R56 2007 MC Spark Plugs
- R56 Transmission make, R56 Justa?
- R56 The OFFICIAL Bayswater Owners Club
- R56 DAM Rattle driving me crazy
- R56 Is This a normal sounding '09 engine?
- R56 looking for exhaust non turbo R56
- R56 Help with picking an exhaust system
- R56 Power fold Mirrors question
- R56 How to launch MINI Cooper S MT??
- R56 Stopping EasyPay Payment's on Mini.
- R56 Any Problems with removing hood stripes on 2011?
- R56 P0118
- R56 Is this a good deal?
- R56 Installed H-Sport Competition sway bar
- R56 Damage to bumper
- R56 Please HELP! Loss of engine power ? intake ?
- R56 DIY Mini dipstick (old school)
- R56 2008 Mini Cooper Upgrades
- R56 GP replicas on R56s "help please"
- R56 Radiator Replacement
- R56 Ordered Helix BOV
- R56 Firmware Upgrade
- R56 OBX DOWNPIPE...Cracked??? LMAO!
- R56 Tire sensors all good.....still inactive?????
- R56 Anybody else notice this?
- R56 How to put square Thule bars on a Mini rack?
- R56 Any new developments?
- R56 Need help??
- R56 Snow performance meth kit
- R56 the OFFICIAL Baker Street Edition owners thread...
- R56 Mini Jacking Point
- R56 Service B*llshit
- R56 My new wheels/tires
- R56 Bought my H-Sport Competition rear sway bar, now what?
- R56 The only thing premium about MINI is price...
- R56 code# 6053
- R56 Website reliability
- R56 Need a dealer oil change in Los Angeles
- R56 increase boost but engine light show up.
- R56 tire noise
- R56 Performance difference on 2 different 2007 r56?? any ideas?
- R56 How ghetto is this?
- R56 Do I need 1 or 2 front brake pad sensors?
- R56 Sport Mode Default to On?
- R56 Need help finding CARB approved Intake
- R56 mini cooper intake/exhaust
- R56 Heat from driver side footwell.
- R56 Foreign object in oil?
- R56 inactive reset
- R56 Single halo rim projector headlights
- R56 Help me find new wheels (Black and 18/17") photoshop help?
- R56 Need Info On Yellow Brake & Service Light
- R56 coolant flush
- R56 brake pads and rotors
- R56 Painting the black wheel trim around the black trim around the mini
- R56 Side Marker Light on Front Wheel Fender (Not Side Scuttle) Replacement/Installation?
- R56 Mini brused looking for help in a resonable body shop (NJ)
- R56 I accidentally almost stopped the car while in 3rd gear....
- R56 Intake
- R56 Had my MINI emblems blacked out, should i remove "cooperS and JCW emblems?
- R56 why are there two different NAM marketplaces?
- R56 Big problem, over-tightened Lugs
- R56 Onboard MPG gauge reading 6mpg high?
- R56 What's this duct for?
- R56 Is it possible to special order an exterior color on the Justa Hardtop?
- R56 MINI Cooper S Competition?
- R56 trying to sell my hood scoop but nam says i can only have 5 ads? anyone heard of this
- R56 Traction control, DSC, and autocrossing
- R56 Brake and traction control light
- R56 2009 vs 2011 mcs...What will I be missing if i get the 2009???
- R56 Alta or K&N
- R56 Rushing Air Sound From Driver Door....?
- R56 What to do between runs at autocross, car on or off?
- R56 New MINI Owner--2007 MCS with popping joints?
- R56 Replacement bumper
- R56 Fade to black
- R56 AC compressor making noise after r134a refill
- R56 close up picture of new mini interior
- R56 How to Seafoam 2011 R56?
- R56 quick question: what does this sensor on the oem intake do?
- R56 Need advice: Persistent handling problem
- R56 Where are all my speakers?
- R56 Is red lining once a bad thing?
- R56 Weird noise above 110
- R56 Rear hub replacement procedure
