View Full Version : R56 :: Hatch Talk (2007+)
- R56 Void my warranty? Cai
- R56 Its been a long road but I am back!
- R56 Burl Shift Knob
- R56 Representing the MINI
- R56 R58 JCW LA wheels
- R56 Transmission Warning Indicator Issue
- R56 Adjustable Steering Ratio?
- R56 R56 Jarvik Thermostat Housing
- R56 Bad alternator or just battery?
- R56 Tinted the '13 MCS windows
- R56 2012 MCS: Jack! New wheels! New Look!
- R56 Oil Cooler
- R56 Stock 2010 Cooper S Dyno Sheet
- R56 does this seem like a plausible way to mount lights?
- R56 First Time on the Track!
- R56 Boost gauge on R56 s auto
- R56 2010 MCS Air Conditioning noise
- R56 JCW tuning kit - to buy or not to buy?
- R56 Wheel swap with JCW exterior
- R56 JCW interior with paddle shifters
- R56 Plastic cover btwn windshiled and driver window
- R56 Almost made it back to the mini fold...
- R56 No gloves for installing windshield
- R56 HELP with steering wheel radio controls
- R56 Windshield cracked T.T
- R56 Review on Evolve Downpipes and Evolve-R
- R56 2013 mods begin
- R56 Mini cooper with mechanical problems
- R56 Wheel on Steering Column
- R56 Hyper Sport Body Kit
- R56 Miami Minis
- R56 Where should i go?
- R56 Chromiumtech bonnet scoop
- R56 Adding Coilovers and suspension mods NEED HELP
- R56 Rear light assembly retrofit
- R56 2013 mcs vs 2013 jcw engine specs??
- R56 Factory alarm settings
- R56 Bulkhead for dos cai
- R56 Cai bulkhead
- R56 DOS CAI bulkhead
- R56 Dos cai
- R56 Deleting MFSW controls from 2011 R56S
- R56 Anybody else transport their 29er mtn bike on TOP of their Mini?
- R56 Vibration Issue
- R56 advice on a 2007 S Model
- R56 Tach disassembly/reassembly (and Craven gauge mount)
- R56 Correct spark plugs for a 2009 R56 Base Hatchback??
- R56 Want to hose down engine compartment for cleaning
- R56 DD/HS Build Thread
- R56 Oil residue on back of valve cover
- R56 Warranty expired. Can i buy warranty now?
- R56 Is the 2012 / 2013 R56 the best Mini S ?
- R56 Caliper Covers
- R56 IHKS vs IHKA and new coding in general for vehicle
- R56 Replace windshield, Saint Gobain or?
- R56 overfilling oil by dealer
- R56 Pilot Super Sports Installed
- R56 What gauges are you running?
- R56 N16 engine -- IS there a timing chain problem?
- R56 3 Questions for the board (JCW tuning kit, JCW big brake kit, dealer)
- R56 DuelL AG order update
- R56 No Heat, Temp Warning Light - Thermostat or ?
- R56 2013 Electrical Info Needed
- R56 Hud
- R56 Schroth harness install - bolt attaching lab belt too big?
- R56 Speedometer error?
- R56 What wheels do i have?
- R56 Justa water pump problem
- R56 Clutch 7 FlyWheel
- R56 Flywheels
- R56 Engine Woes... Detailed description inside....
- R56 Freshly Detailed 09 MCS
- R56 About to replace timing chain....what next?
- R56 Need a summary of all MINI issues for the R56?
- R56 Retrofit bluetooth/usb port
- R56 Comfort Access Key Issue - Please Help
- R56 Advice for hardtop build choices
- R56 stupid armrest
- R56 aftermarket cruse control question
- R56 What you tinks?
- R56 bbs style 5 wheel fitment
- R56 Should I be pissed? Dealer refusing to install my new shift knob
- R56 seeking build input
- R56 OEM Spark Plugs @58,295 Miles
- R56 Hood scoop question
- R56 TRS HID retorfit
- R56 Factory fork mounted bike rack
- R56 Quick Opinion - Challenge or Webspokes
- R56 Ebay Strut Brace
- R56 K&N Typhoon Intake
- R56 Engine Light / Cooling Fan
- R56 Rislone in an R56
- R56 Looking to buy, but this car had 3 owners...should I stay away?
- R56 Uncomfortable seat
- R56 HID's in fogs
- R56 2007 R56 - Check Engine Light, fan seems to stay on longer after turned off
- R56 Over 100K miles on your R56?
- R56 11' R56 N18 obd2 data logging software? similar to VAG-COM?
- R56 R56 N18 obd2 data logging tool? similar to VAG-COM?
- R56 2008 Mini R56 Yellow Gear warning
- R56 May be time for a timing chain....
- R56 Use Borescope to check carbon buildup (?)
- R56 fan doesn't come on after stopping, '12S
- R56 How many Miles from a Mini ? 200k 300k ?
- R56 How Much Oil Can a Catch Can Catch ?
- R56 No more auto up driver's side window after reprogramming?
- R56 2007 MCS Auto (Starts is 2nd gear)
- R56 JM Turbo Coopers the real deal?
- R56 BSH R56 Lower Engine Mount (Street)
- R56 should i regret buying a Cooper?
- R56 New replacement engine with death rattle
- R56 Half power warning light
- R56 mann-hummel provent 200 air oil separator
- R56 JCW DV compared to S DV?
- R56 Cracked my wheel :(
- R56 Vanos actuator
- R56 Turbo upgrade?
- R56 Anyone make the two tail light bulb access compartments into a storage area?
- R56 reset adaptive throttle and AT settings
- R56 LED Interior Bulbs Installed
- R56 Map lights on at random
- R56 Coolant is brownish, low
- R56 Did a crazy thing... M3 -> Mini
- R56 New Exhaust Setup...finally
- R56 Codes P000A and P0190 Mini runs on half power.
- R56 Hitting bumps in my MINI Cooper S
- R56 08 R56 Turbo questions Mods)
- R56 need boot stripes. where do i get them?
- R56 Timing chain rattle, heard once Oil topped off, noise gone
- R56 First must do mod to a MINI
- R56 Cooper S spoiler mod
- R56 2010MCS towing question
- R56 MTF 94 Transmission Fluid + LSD
- R56 LCI Taillight Schematic's
- R56 R56 Double Din Install Metra Kit and Harness
- R56 Brakes: Best replacement?
- R56 Help please, my car hates me.
- R56 Can someone identify this steering wheel for me?
- R56 Fubrication GP style spoiler
- R56 Automatic: Your Smart Driving Assistant
- R56 Possibly ignorant question about where to buy MINI oil filters:
- R56 What mods do I have on my used MINI??
- R56 rota rb on a 07 s
- R56 Mirror Caps
- R56 Normal MPG in a 2nd Gen Cooper S?
- R56 turbo oil cooler line
- R56 How to kill your turbo in a R56 Mini. Any thoughts?
- R56 Big Brake Kit Options
- R56 Steering Wheel Replacement & Bentley Repair Manuals?
- R56 2008 mini copper s brake upgrade ?
- R56 Increased Battery Discharge!
- R56 Spice Orange and Eclipse Grey Goodness
- R56 Swap Seats?
- R56 Oil sump leak
- R56 CA Smog Check - Warning lights galore when done
- R56 R56 Water Pump leak
- R56 Good Deal? Thoughts...
- R56 Will a 2011 MCS's Turbo fit in a 2009 MCS?
- R56 Direct Injection?
- R56 Transmission problems while test driving a potential buy.
- R56 NM spring help
- R56 Shutter at idle
- R56 weird noise low speeds (Video)
- R56 Hardtop (R56S) vs. Convert (R57S) Seat swap
- R56 2007 Mini Cooper S new engine...ADVICE PLEASE
- R56 M7 lowering springs help
- R56 H13 9008 fitment BiXenon Projectors are now available
- R56 wind noise rear sunroof
- R56 2013 hardtop vs 2011 countryman
- R56 NM Carbon Fiber Intake
- R56 Mini Code Reader
- R56 What is this sensor/electronic device under the back seat?
- R56 Maintenance Schedule
- R56 haha, rear seats are stupid
- R56 Normal Oil Pressure Range?
- R56 Does any one has a pictures for a horizon blue with any other color ?
- R56 Meth Injection Kit Questions
- R56 Waterpump ?
- R56 Dealer: " it is NORMAL to consume 1 qt of oil every 1k miles..."
- R56 VMAXX vs. EZstreets
- R56 Manual Transmission Fluid Spec - 07+ Non-S
- R56 No Stripes or Stripes?
- R56 sweet jesus!
- R56 Diagnostic Tool to check for knocking
- R56 Throttle Delay
- R56 General Alignment Question
- R56 I love my MINI, but..
- R56 Rear Brake Dust
- R56 Question about accessport
- R56 mirror caps.
- R56 driver window squeal / squeeks when going down?
- R56 New Timing Chain "kit" $1700??
- R56 Where to get oil drain plug ring/washer?
- R56 Engine Coolant Flush?
- R56 JCW Aero kit install
- R56 What is this exposed hole for?
- R56 Purchasing a '13 JCW
- R56 Mini Cooper S 2009
- R56 Headliner
- R56 Dos cold air intake
- R56 Trunk Emblem Decal
- R56 Eagle GT Tires
- R56 AC Vent - Hidden Screw Cover - Where to buy?
- R56 Intake on Justa?
- R56 Problem
- R56 Roof rack hole plugs?
- R56 Rally Stripes
- R56 MINI Connected plug in no longer working since updating to iPhone ver. 6.1.2
- R56 new here
- R56 Service light on Startup
- R56 New member: break in period
- R56 Coolant Leak Problem - Warranty Just Expired
- R56 Let's settle this Vvibration argument once and for all
- R56 Racing experiences...
- R56 Need a Tune in Minnesota
- R56 Anyone have experience with putting JCW front bumper on 09 R56?
- R56 195/55-16 conti pro contact
- R56 Official Midnight Black thread?
- R56 Temperature pressure sensor?
- R56 Need a line part identified R56
- R56 2008 Mini R56 Oil leak at Vacuum Pump
- R56 Non-S R56 Fuel Grade
- R56 No TPMS in my 02/2007 MC? 185/65R-15?
- R56 Help: Need fix for loose Fog Light triggering bulb out warning?
- R56 anyone running 195/45-17 on an 8 inch wide?
- R56 Baby Seat in Cooper Hard Top?
- R56 07 mini opinions needed....
- R56 Bluetooth connectivity?
- R56 Brake indicator tripped - quick question
- R56 Vibration after lowering :( new cv time
- R56 JCW spoiler...help
- R56 Oil Change Issue...
- R56 timing chain & tensioner problem on r56 justa?
- R56 Replacing Rear-Left Wheel Arch Trim
- R56 Quick video of my 40-75 MPH acceleration.
- R56 2008 R56 something is drawing down my battery!
- R56 Anyone know why MINI dealers are overfilling oil?
- R56 parking lights
- R56 First MIL
- R56 Don't reset computer oil interval if changing more often?
- R56 Red brake ducts
- R56 [Photos] R56 by Sotha Ith Photography
- R56 Radiator
- R56 Anyone Jonesing for an F56?
- R56 Endlink failure
- R56 Passenger Windindow Won't Stay Up
- R56 2007 R56S suffering lack of power
- R56 Button on the door handle will always unlock the car
- R56 Is 4.4 qts. the correct amount for a oil/filter change?
- R56 Lowering Issues?
