PDA
View Full Version : R56 :: Hatch Talk (2007+)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. R56 It's a baby?? Literally...PARTS FOR SALE
  2. R56 Floor Mat What is option code 423?
  3. R56 2011 Mini Cooper Tire changing kit
  4. R56 What stmbol is this?
  5. R56 Effect of Run Flat Tire Pressure on Ride Quality?
  6. R56 Hello folks....
  7. R56 Someone help? airbag module trim!
  8. R56 Recommendations for firmer shifting? Bushings? Motor Mount?
  9. R56 2013 recaro seat option
  10. R56 check engine light, car in limp mode
  11. R56 I want to retrofit my, spec-d headlights
  12. R56 Are first gen and second gen headrests swapable?
  13. R56 rear seat delete
  14. R56 Service mode?
  15. R56 New purchase wheel upgrade question
  16. R56 Overheat warning
  17. R56 Seepage, drips, oil consumption help.
  18. R56 Hop
  19. R56 Glad I got my Remote Starter ! 2012 MCS
  20. R56 Motul Engine Oil
  21. R56 Steering wheel removal
  22. R56 Turbo Inlet Pipe Cracked
  23. R56 Mini's color?
  24. R56 Engine light/No hot air Code P112B
  25. R56 Snow tire recommendations
  26. R56 base cooper ECU tune?
  27. R56 Grinding / popping noises from engine at low rpm
  28. R56 2013 Justa Manual
  29. R56 Used 2011 MCS ok deal?
  30. R56 New exhaust sound clip sample.. sounds so gooood.
  31. R56 Mid-grade vs. Premium Fuel
  32. R56 Bently Service Manual
  33. R56 R56 mcs k&n filter
  34. R56 i need to replace license plate bulb
  35. R56 New guy with a MCS
  36. R56 My mini saved my life
  37. R56 Cannot syphon / siphon fuel out?
  38. R56 A/C panel swap, coding needed?
  39. R56 $7000.00 engine repair bill??? Would engine replacement be cheaper??
  40. R56 Custom Gauge Faces Speedo/Tach
  41. R56 iPod Input Sound Quality??
  42. R56 Stoptech Brake Question.
  43. R56 Back in the fold
  44. R56 help please, my moms mini, sounds like big problems
  45. R56 MINI in for service crap rental car
  46. R56 Mini Cooper Vs BMW 1 series
  47. R56 My wife's rear-ended justa
  48. R56 Vanity Mirror feel out
  49. R56 07 Cooper S
  50. R56 Gear Ratio differences between 2009 and 2011
  51. R56 Headlight Sensor
  52. R56 R56 Battery replacement
  53. R56 October 2007
  54. R56 Brake Job and Sensors for "Do it Your Self" DIY
  55. R56 DRoc's Super Awesome Build Thread!
  56. R56 Mini-Generator
  57. R56 Gas cap cover
  58. R56 Help! my car won't start!!
  59. R56 Sparco seats and steering wheel extension
  60. R56 Wtf!!!
  61. R56 Jcw challenge parts
  62. R56 No fuel filter on my Mini Cooper
  63. R56 MY Mini gave me HELL 2day! Dealer wants to charge me 80$ to register new battery!
  64. R56 Cel codes p0302 p2783 p277f
  65. R56 08 MCS whining while holding speed
  66. R56 Stock suspensioon and 215-45/17 tires
  67. R56 Project Matte black done!
  68. R56 CEL = three codes
  69. R56 Meth Inject Kits
  70. R56 So noisy!
  71. R56 2010 MCS Alarm Questions
  72. R56 RED Brake light, sensor re-set???
  73. R56 12 MCS cold idle / coolant temp problems
  74. R56 cold weather boost ?
  75. R56 07 justa shakes at idle
  76. R56 Need some help from the US mini funs
  77. R56 Searched but no clear answers
  78. R56 How to set Horn Notification or Beep When Locking Doors?
  79. R56 Help... With these lights and codes:
  80. R56 Can you remove the boot lid belt line trim retainer without removing the window?
  81. R56 Replacement of thermostat housing
  82. R56 dealer day
  83. R56 hey owner, having a slight problem
  84. R56 Brake pads & rotors - should I change now??
  85. R56 Check engine light question
  86. R56 Interest for a Group Buy: Aquamist HFS-4 system
  87. R56 ARK Exhaust System
  88. R56 Yakima Basketcase with Mini Base Supports
  89. R56 Curbed rim repair
  90. R56 Xenon Headlight Issue
  91. R56 Tire size question
  92. R56 Hankook Tires
  93. R56 Fuel icon Q
  94. R56 Fuel for the Justa - 87 or 91
  95. R56 Fault Code CC ID 115
  96. R56 Flashing light dont turn off
  97. R56 Help with center console where the shifter is.
  98. R56 Did a res delete... Should i do a Muffler Delete?
  99. R56 Leaking oil pressure sensor?
  100. R56 Got towed...
  101. R56 08' R56 n12 code 287d
  102. R56 Noisy Star Specs?
  103. R56 New JCW Aero Kit for 2013 models
  104. R56 What are some of the common "issues"
  105. R56 Catch can, SeaFoam or both?
  106. R56 Show your JCW CF Spoiler!
  107. R56 Dropped Valve
  108. R56 Need a second opinion....
  109. R56 Picture of my new MCS on the Nuerburgring
  110. R56 Thinking about buying a turbocharged mcs
  111. R56 Question about all weather mats for 2012 MCS
  112. R56 Big Turbo MINI
  113. R56 Power outage MINI R56 diesel
  114. R56 Comfort Access Button Not as Responsive as Before
  115. R56 Ragazzon Catless DP... CEL dillema
  116. R56 Brake Job Make MINI Go Crazy
  117. R56 Oil Change
  118. R56 Burble
  119. R56 Mudflaps?
  120. R56 My wife wants to lease a 2013 Mini - questions
  121. R56 Tire&wheel question
  122. R56 So THAT'S where my power's been hiding
  123. R56 How do I adjust my HID's up?
  124. R56 My New MINI Pics! Rock chips are driving me crazy!
  125. R56 r56 justa shake at idle
  126. R56 My new Cooper Passenger Seat Wont Slide!?
  127. R56 2013 MINI GP? - Opinions Wanted
  128. R56 Multiple Key Fobs
  129. R56 10,000 Mile Service - 2012 R56?
  130. R56 JCW Strut bar fitment with Alta Intake
  131. R56 Good Deal or Bad Deal 08 hardtop S - Mini newbie
  132. R56 Octaneguy needs NAM's help
  133. R56 Trunk lid does not open with button on handle AND having closure problems TOO
  134. R56 MCS hood
  135. R56 Factory Stereo With Navigation PIN
  136. R56 10k miles; 1 dead clutch. HELP.
  137. R56 Engine Swap
  138. R56 Help with car purchase
  139. R56 break assist
  140. R56 Might be a stupid question...
  141. R56 Urgent input needed on purchase!! (Re: clutch wear etc)
  142. R56 Intro and 1 Q (for now!)
  143. R56 Q on '13 R56: Should I go for the AISIN for reliability or stick with the Manual?
  144. R56 Clicking noise
  145. R56 Well here's a first for me.... Graphic pics inside.
  146. R56 Order question - Adaptive light control?
  147. R56 Bsh occ
  148. R56 Way's Customer Service and first thoughts on Invidia
  149. R56 iPhone 5
  150. R56 NM Engineering N14 Heat Shield
  151. R56 Thermostat housing
  152. R56 Differences between MCS 2012 and 2013?
  153. R56 EBC ROTORS Dimpled and Slotted
  154. R56 key less entry
  155. R56 215/45/18 Pics anyone?
  156. R56 2007 MCS JCW lost power
  157. R56 My MINI is dead!
  158. R56 Mini Goodwood
  159. R56 Anybody got a broken antenna base ?
  160. R56 Bonnet stripes on your boot? Pics please
  161. R56 Front Suspension Noise
  162. R56 Timing Chain Tensior Seal
  163. R56 Plasticy interior
  164. R56 Forge Silicone Intake Hose--How to?
  165. R56 Aftermarket mud flap help
  166. R56 Help with Jacking Points?
  167. R56 Timing chain tensioner DIY
  168. R56 Drainage
  169. R56 Independent (non-dealer) shop wanted
  170. R56 Corbeau Seats?
  171. R56 Have leather seats for a while? Show your thigh bolsters!
  172. R56 Red Beltline? Anyone Have Pics?
  173. R56 Call to action Ohio.. Carbon build up
  174. R56 Headlight help???
  175. R56 Should I be nervous about buying an R56
  176. R56 Strut bar Could Fix Vibration on Lowered r56?
  177. R56 Parts For Shock Replacement?
  178. R56 Leak at thermostat?
  179. R56 Low Oil Warning Light Comes On At Idle
  180. R56 This hose is coming loose!?
  181. R56 Clutch Problems?
  182. R56 I think this is a Clubman...
  183. R56 To Clubman or not to Clubman
  184. R56 The Mystery of the Torque Arm Insert Dispelled
  185. R56 something old & something new
  186. R56 Born on Date
  187. R56 EBC Ultimax Black Dash Slotted Rotors
  188. R56 Blown turbo maybe
  189. R56 60k mile services?
  190. R56 turbocharger issue, serious?
  191. R56 Should i get another MINI? Yay or Nay?
  192. R56 Mini Cooper (base) reliability and highway commuter
  193. R56 Maintenance Schedule
  194. R56 Alta vs DDM?
  195. R56 Bad Day...
  196. R56 Speaker grill in drivers side door panel
  197. R56 motoringwerks.com
  198. R56 Used oem headlights
  199. R56 PCV Block-off / OCC Installation Question
  200. R56 Bonnet stripes?
  201. R56 Is there a way to have ASC Default to off?
  202. R56 Here we go, R56 Overhaul...
  203. R56 MINI achieves top spot on this list!
  204. R56 Exhaust upgrade for cheap Money?
  205. R56 Need Some Advice..
  206. R56 Will a 2009MCS rear bumper fit a 2011 MCS
  207. R56 Mini Troubles, Please Help
  208. R56 First Check Engine Light NON S
  209. R56 Replace brakes or replace car...
  210. R56 How much vinyl...?
  211. R56 Freaking weird noise after accident.
  212. R56 Armrest for 2013 model??
  213. R56 Rear Seat Delete
  214. R56 Anyone know what this plug is by the brake lines?
  215. R56 Anyone have any White Plasti Dip exterior Components?
  216. R56 R56 rear tail light interior trim
  217. R56 Second Chance to Order the Perfect Mini
  218. R56 Fogged Headlamp Lens
  219. R56 Another Carbon Build Up Problem Fixed (DIY)
  220. R56 Subtle Jerks When Idling
  221. R56 The Ponies have returned!
  222. R56 P115c but not.
  223. R56 Black out Options
  224. R56 Integral Audio: Howdy!
  225. R56 so, what do you think
  226. R56 Weird electricl problem
  227. R56 Rhino Ramps
  228. R56 P115C / P1497 possible valve cover or gasket problem
  229. R56 Thump noise..help!
  230. R56 stereo loses power
  231. R56 Factory Security System
  232. R56 anyone near cheshire ct that can listen to my engine?
  233. R56 Sports suspension, kind of regret not getting it.
  234. R56 Wanted to buy 2009 mini Cooper S Xenon headlights
  235. R56 dipstick ( new complaint)
  236. R56 Possible Purchase of a 2013 MCS.
  237. R56 Help Riley Children's Hospital!
  238. R56 What would you make?
  239. R56 Here we go again... let the facelift begin...
  240. R56 Sub box question
  241. R56 Anyone using Hawk pads in their Brembo's?
  242. R56 R53 mcs spoiler fits r56 non turbo?
  243. R56 2013 Center Console Tray
  244. R56 2011 bypass valve louder than pre 2011?
  245. R56 CEL = leaking exhaust valve. Heard of this before?
  246. R56 Need advice on lowering springs and pics if anyone has them
  247. R56 Fun video of weekend autocross
  248. R56 Any way to check why my service light is on?
  249. R56 Couple questions
  250. R56 Reprogram After Walnut Blast Changed Oil Service Interval
