PDA
View Full Version : R56 :: Hatch Talk (2007+)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. R56 headlights
  2. R56 low boost at 4500 rpm
  3. R56 2010 MINI S trailer hitch?
  4. R56 After market wheels
  5. R56 Euro Style Plate for New Mexico?? YESS!!
  6. R56 winter tires
  7. R56 R56 2007 MCS quick engine questions
  8. R56 CEL with code P301. Dipstick at fault?
  9. R56 Had to happen sometime...
  10. R56 Sparco Terra wheels on a MC S
  11. R56 MIL displays the little yellow engine
  12. R56 Bluetooth problems
  13. R56 how do you check the oil temperature?
  14. R56 Internal Circulation when it's Cold Outside
  15. R56 Massive list of work, which should I not even attempt myself?
  16. R56 Are you serious?
  17. R56 Doing business with M7 Tuning!! OUCH!!
  18. R56 Taking off the B pillar cover
  19. R56 Weird noise during first minutes
  20. R56 All season tires for mcs
  21. R56 Obd ii p2c9c
  22. R56 Cruise control dash light issue, maybe?
  23. R56 MCS 08 Removing Intake VANOS Unit Fastening Bolt
  24. R56 M7 Splitter Install HELP!!!!!
  25. R56 New Issues to Ring in the New Year
  26. R56 My S feels really slow after service
  27. R56 Noise maker
  28. R56 Looking for replacement part help
  29. R56 When you remove stripes is there paint discoloration underneath?
  30. R56 09 Mini Brake Question/Strange Occurrence
  31. R56 Check Engine Light
  32. R56 Cold Air from radio controls
  33. R56 R56 mod tips!?
  34. R56 Question about heated mirrors
  35. R56 spring questions
  36. R56 Noob question on exhauste
  37. R56 Does OEM Sport Suspension show up on VIN?
  38. R56 New to Mini, trouble with hot air
  39. R56 Codes P1338, P0011, P0014 after multiple resets.
  40. R56 Bless my build? (looking for config suggestions)
  41. R56 Is a justa w/auto trans too slow/odd?
  42. R56 Heated rear window, quick question.
  43. R56 Where is the pcv valve?
  44. R56 Bless my build? (looking for config suggestions)
  45. R56 07 MC. Yellow check engine light
  46. R56 Ordering a MINI: Questions
  47. R56 K&N filter part # question
  48. R56 RIP Horizon Blue MINI
  49. R56 Just picked up my 2013 Hyde Park S
  50. R56 Another mile stone
  51. R56 Another good experience at MAG, Dublin, OH
  52. R56 code help please
  53. R56 Something wrong with my 09 cooper s? Or normal..
  54. R56 Tire sensors
  55. R56 is mileage and mph at trip computer avail. same time?
  56. R56 Clearcoat Problems
  57. R56 Blown Engine Update
  58. R56 Just two questions
  59. R56 Help Please! Tachometer warning lamp
  60. R56 engine light vanos warning
  61. R56 extending racing stripes - vinyl recommendations?
  62. R56 Spark plugs removal tool
  63. R56 Thermostat Housing Replacement
  64. R56 2007 R56 - started perfectly for 12 months - but not now. Need help diagnosing.
  65. R56 2009 MC NON S custom exhaust specs and Qs
  66. R56 BlackIce's Dipstick modification works great!
  67. R56 Wheel help?
  68. R56 Red car on lift and yellow brake light???
  69. R56 M7 AGSR Intake
  70. R56 Interesting article about exhaust
  71. R56 justa thermostat and oil burning
  72. R56 Body Shop Recomendation on Long Island for Painted Arches
  73. R56 Catback Exhaust Recommendations
  74. R56 m7 Vortex Scoop 2
  75. R56 New outfit for Tackleberry
  76. R56 Thermostat Housing Spring Clip
  77. R56 Will these instructions work to get access to front swaybar?
  78. R56 Justa
  79. R56 Does anyone have current lease rates on 2012 Cooper Hardtop?
  80. R56 Timing Chain Measurement and Dealer Procedure
  81. R56 How to Listen to iTunes Music in Your MINI with Boost Radio (no nav)
  82. R56 Keys
  83. R56 Some "warranty friendly" mods inquiry
  84. R56 has anyone installed the factory mini roofrack themselves? help
  85. R56 Cup holder lighting?
  86. R56 Limp Mode, Coolant leak
  87. R56 Stupid question (yes it exists) - washer fluid
  88. R56 Some Extended Warranty Pricing
  89. R56 Carbon Cleaning - BG Fuel Air Induction Cleaning Service
  90. R56 Accessport maps
  91. R56 cold start problem
  92. R56 Custom mandrel bent/silicone
  93. R56 MCS 2009 to JCW 2013?
  94. R56 New guy!
  95. R56 Mini Goodwood
  96. R56 I'm A Catch Can Believer
  97. R56 Painful cooper s car seat... Solution needed!!!
  98. R56 Recommended Dealerships/Repair Shops
  99. R56 || Integral Audio || End of Year Blowout!!
  100. R56 Coolant Temperture
  101. R56 Fume smell
  102. R56 OEM Retrofit Thread
  103. R56 Fan/Blower overrun
  104. R56 JCW to cooper s
  105. R56 Need clutch advice...
  106. R56 TSW Short Jack Points help!
  107. R56 Green Fluid Leaking
  108. R56 Mini Extended Warranty Questions
  109. R56 Seat Removal: Airbag Light and Track Grease
  110. R56 Has anyone tried to run Alta Acessport Stage 2
  111. R56 2008 Mini R56 steering problem...
  112. R56 What button is supposed to go here?
  113. R56 Best Bluetooth Kit 07 MCS with Sat Nav
  114. R56 OBDII code says N/A
  115. R56 Well-Optioned Coopers (Non-S)
  116. R56 Copper Nuts - New vs. Original?
  117. R56 Downgrade my JCW brakes to run 15" wheels?
  118. R56 Just finished swapping out my Thermostat Housing and now my car won't stay on.
  119. R56 K&N Air filter
  120. R56 Good ways to read 2011+ oil dipsticks.
  121. R56 Water Pump and Timing Chain change:
  122. R56 Soon to expire warranty advice
  123. R56 R56 Advice
  124. R56 Need help- stupid mistake - hood release
  125. R56 Need Advice
  126. R56 transmisison parts needed where to get
  127. R56 Help! I did something stupid and now I have a window problem!
  128. R56 JCW exterior in snow.
  129. R56 Very strange (to Me)
  130. R56 2011 Justa Cold weather starting
  131. R56 Is this normal?
  132. R56 Custom Blackout Driving Lights
  133. R56 2012 MCS clutch shudder
  134. R56 Newbie -- to R56 that is..
  135. R56 My new to me 2010 S
  136. R56 WTB: 07 MCS Pure Silver Rear Bumper Cover
  137. R56 Possible to reprogram comfort access key?
  138. R56 R56 mini S and 09 MINI COOPER NON S SUSPENSION
  139. R56 R56 in Sport mode, automatic, without higher shift points
  140. R56 Wastegate rattle N14?
  141. R56 auto trans weirdness
  142. R56 studded snow tires
  143. R56 Sucking/grinding noise
  144. R56 Auto trans fluid changed - problem solved
  145. R56 Well it finally happen...
  146. R56 Saying farewell
  147. R56 Please help if you know where...
  148. R56 Oil to use in non-street motoring days
  149. R56 Maintenance/Repair manuals
  150. R56 try to seafoam today
  151. R56 BMW/MINI should be ashamed
  152. R56 Had a little fun Yesterday
  153. R56 Enable Pops an burble on MCs?
  154. R56 Are the engines really as bad as I've heard?
  155. R56 Recommended Mods after Short Shifter/Torque Arm?
  156. R56 Bov...bov....bov....
  157. R56 Pivot 52x-bw gauges anyone install themselves
  158. R56 how often do you change transmission fluid for justa?
  159. R56 Innovation and Mini R56
  160. R56 Warning symbol
  161. R56 Carbon buildup and OCC question
  162. R56 Need Help with replacing headlight bulbs.
  163. R56 ECU Tuner Upstate NY
  164. R56 Anyone running 205/40-17 tires?
  165. R56 Service Coupons/Discounts
  166. R56 Flowmaster exhaust for mini cooper 09 non s
  167. R56 iPod worked, then did not work - any ideas?
  168. R56 Just a warning
  169. R56 Tail light upgrade
  170. R56 HKS SSQV4 BOV Video.
  171. R56 mini cooper original wheels
  172. R56 K&N CAI and JCW struct bar clearance problem
  173. R56 Help with aftermarket wheels
  174. R56 Brake Vacuum Pump
  175. R56 Tip for R56 owners...
  176. R56 Heater issues
  177. R56 Pic request : white silver
  178. R56 07S Brake Pads
  179. R56 Oil smell in exhaust.
  180. R56 2007 Mini Tail Light Removal
  181. R56 throttle response bulletin
  182. R56 Timing Chain Issues
  183. R56 Loosing coolant?
  184. R56 How are Mini's in the snow?
  185. R56 Need Os Giken GT Clutch Kit for R56 -- Fast
  186. R56 Maintenance and Service on a Mini
  187. R56 debating between clubman s and 128i
  188. R56 Update Call to action Ohio..Carbon buildup
  189. R56 tires for a 2008 MCS
  190. R56 Buying used 07-09 Cooper non S
  191. R56 '10 MCS Blew oil everywhere
  192. R56 Door lock issue
  193. R56 Hey check me out!
  194. R56 Picking back and forth between options, a couple of questions?
  195. R56 Front brake job, are rotors required?
  196. R56 Please Advise
  197. R56 07 justa alignment spec?
  198. R56 Catch Can Differences
  199. R56 Broken windshield
  200. R56 Doing maintenance got a concern
  201. R56 tire replacement and alignment tomorrow
  202. R56 Dis not know I was superman... I need help !!!
  203. R56 Mini Cooper R56 vs Lexus Is350
  204. R56 Help picking color for viper stripes!!
  205. R56 auto trans fill urgent help needed
  206. R56 auto trans new tool found
  207. R56 Maintanance Tips!
  208. R56 Strange Noise (Popping) or Thump
  209. R56 Driving lights mounting issue!!
  210. R56 Steering Wheel MINI Emblem
  211. R56 Door ding protection for our cars
  212. R56 Door inside plastic cover
  213. R56 Finally!
  214. R56 power fold mirror disassembly...HELP ME!!!
  215. R56 auto transmission fluid question
  216. R56 Experience with corporate MINI - thermostat housing issue
  217. R56 Antenna Toppers
  218. R56 Crashed my mini :(
  219. R56 brake pad recommendations?
  220. R56 R56 Hydraulic fluid leak between motor and transmission
  221. R56 Should I get this exhaust system and add a DP?
  222. R56 1st oil change
  223. R56 Driverside door lock stopped working
  224. R56 How to remove grill badges?
  225. R56 Whose converted to all spherical bearings in there suspension?
  226. R56 big tire sale on pepboys?
  227. R56 Stubby Antenna
  228. R56 What is this tube?
  229. R56 BSH OCC = Winning
  230. R56 Oil Pan Leaks after Mini Replaced It
  231. R56 Akrapovic downpipe & CEL Delete Module
  232. R56 NEWB here!!!!
  233. R56 D-stock or STX more competitive regionally
  234. R56 is this bad spark plugs?
  235. R56 license plate bracket HW
  236. R56 Oil diaphragm/vacuum leak
  237. R56 Anyone know if countryman 5x120 hubs fit the r56?
  238. R56 No Boost....sometimes
  239. R56 2013 Cooper has 4000rpm rev limit in neutral
  240. R56 Strange sound near oil cap...
  241. R56 Anyone going to FixxFest?
  242. R56 Am i the only one with a real blow off valve?
  243. R56 Ordering a New R56 S
  244. R56 Need advice on buying a mini (accident car)
  245. R56 recommendation for brake pads & rotors on 07 justa
  246. R56 Did my MINI play a joke on me??
  247. R56 First time MINI buyer looking for advice on a MCS Lease
  248. R56 Preparing for my first 1/4 mile.
  249. R56 Uhhhmmm... my hoodscoop flew off when I was driving???
  250. R56 NM Spring install instructions??
