PDA
View Full Version : R56 :: Hatch Talk (2007+)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. R56 Drivers side Window squeaks when closing Door
  2. R56 Bergii is going in the body shop on Monday
  3. R56 Static noise from speakers when car is off
  4. R56 Help! Waterpump & Thermostat need replacing?
  5. R56 All my warning lights are on?!?,
  6. R56 Replace brake lamp on 2007 mini
  7. R56 How did u fix the oil burning issue the R56S has?
  8. R56 "Service" Indicator
  9. R56 Timing chain Tensioner... AGAIN!!!!
  10. R56 Tires actually fit
  11. R56 Possible to replace brake pad sensor without removing pads?
  12. R56 Warning light after replacing battery
  13. R56 Where to place Seafoam after rear PCV hose delete?
  14. R56 USB error
  15. R56 Vibrations After Alignment - Need Advise
  16. R56 Can anyone tell me whats going on with my paint here?
  17. R56 Suspension Question !!
  18. R56 2011 JCW Cooper emitting black smoke from exhaust on hard acceleration. Normal?
  19. R56 Used coilovers - what to look out for?
  20. R56 OBDii "Linking Error" with "Check Engine" light on.
  21. R56 Finally washed it !
  22. R56 Black Grille surround
  23. R56 Strange window memory setting after battery jump
  24. R56 Trouble fully closing hood (gap on left side)
  25. R56 Detaching the wipers
  26. R56 Buying Help
  27. R56 07 mini cooper non-s transmission fluid
  28. R56 Removing tail lights?
  29. R56 Oxygen sensor replacement - trouble with harness
  30. R56 Thermostat/warm up
  31. R56 Any issues that can be caused from catless DP?
  32. R56 test drive 2013 Bayswater
  33. R56 WMW Remote tuner vs Alta AP vs RMW tune
  34. R56 Straight pipe and an air filter mod
  35. R56 Vacuum Pressure Question...
  36. R56 Dashboard removal
  37. R56 Pulled the Trigger
  38. R56 Black Headlights suggestions help
  39. R56 TPMS Inactive
  40. R56 My custom downpipe (Video)
  41. R56 What's the best FMIC?
  42. R56 Looking for some new wheels
  43. R56 CEL Codes
  44. R56 So long it's been a nice ride!!!!
  45. R56 how can I tell what packages came with the car?
  46. R56 Fog bulb replacement
  47. R56 Recommendations as I approach 100k & warranty expiry
  48. R56 R56 Cooper NON S section?
  49. R56 2009 MCS - Known Issues To Address Before Purchase
  50. R56 Parking light
  51. R56 Carbon Issues
  52. R56 Quick Advice Needed
  53. R56 Intercooler Shootout?
  54. R56 Justa
  55. R56 Lowered Minis
  56. R56 My R56 disappeared
  57. R56 Clutch adjustment
  58. R56 Possibly purchasing a Cooper S, need some info
  59. R56 Anyone with a Stratmosphere CBE and aftermarket DP?
  60. R56 Really need help with brakes (R56) Major issues- details inside!
  61. R56 Help! Tow truck ruined my mini
  62. R56 What Do Rear Fogs Look Like?
  63. R56 A peculiar thing about JCW & MCS shift knobs (& weight)
  64. R56 ORO-TEK™ - TPMS Sensor
  65. R56 Question about BlueTooth phone?
  66. R56 no check engine light,,, idle problem
  67. R56 Observations after Owning an MCS for 6 Months
  68. R56 Satellitte Antenna
  69. R56 Help Installing AEM Water/Meth Kit On R56?
  70. R56 2011 Brake Force Display
  71. R56 Front fog light
  72. R56 dealer overfilled oil
  73. R56 R56 Quad Driving Light Kit
  74. R56 new sunroof motor set up
  75. R56 warning indicator help
  76. R56 08 MCS - cracked exhaust manifold???
  77. R56 lighting
  78. R56 Anyone heard this noise? R56 Heater Buzz
  79. R56 Help with a loose something in headliner
  80. R56 New engine for next generation Mini
  81. R56 Easy to replace "Dash surface " ?
  82. R56 Covers for steel rims?
  83. R56 Sputtering MINI
  84. R56 Thoughts on ATF
  85. R56 Keyless Entry on Passenger Side
  86. R56 Yet another new owner...
  87. R56 Couple of questions before potential purchase.
  88. R56 I Vinyl Wrapped My Roof
  89. R56 Short Shifter Questions
  90. R56 Getting the back seat headrests ALL the way down
  91. R56 Checking oil level as MINI recommends
  92. R56 02 sensor in my 07 mini cooper hatchback
  93. R56 What is this for on the rear view mirror?
  94. R56 please recommend a good shop in Westchester (NY) area
  95. R56 New owner with questions...
  96. R56 Can't reset low tire warning
  97. R56 first time Mini Cooper owner, maintenance questions.
  98. R56 Replacement parts for my mini
  99. R56 DuelL AG North America
  100. R56 A quick question for anyone who has more knowledge than me...
  101. R56 Looking for a trade
  102. R56 Dashboard / Radio Button Lights Not Working?
  103. R56 R56 N12 2845 DME Vanos Exhaust Actuator Movement
  104. R56 Useful R56 Threads
  105. R56 I need bypass valve help
  106. R56 Time Based Maintenance Schedule?
  107. R56 Need detailed pics of '13 secret compartment door!
  108. R56 2010 Howling Clutch???
  109. R56 Knocking sound from front end?
  110. R56 Glazing rotor, need input
  111. R56 New Mini. Tires are the worst ever
  112. R56 2011 mcs engine part Id help
  113. R56 Help with R56 air intake
  114. R56 Normal?
  115. R56 Brake job
  116. R56 What Seats Are These?
  117. R56 MINI painted Bentley Matte Silver
  118. R56 Racing Stripes
  119. R56 Help with Instructions on Timing Chain Tensioner Replacement
  120. R56 Helix Intercooler Install Question
  121. R56 Replaced R56 MCS Spark Plugs w/Pic
  122. R56 Fogs or not?
  123. R56 Post pictures of your stripes/roof color choices!
  124. R56 Paint Code location - 2013 MC
  125. R56 TPMS on an 07 MCS
  126. R56 Side Mirror control
  127. R56 Oil on Engine? Help!
  128. R56 Top 5 favorite mods?
  129. R56 New CF Rally Stripes on 2007 MCS.
  130. R56 ENKEI M52 Performance Series Wheels? (new for 2013)
  131. R56 Brake Problem?
  132. R56 HID fog lights??
  133. R56 Dipstick reading after oil/filter change
  134. R56 Turbo Lag vs. Serious hesitation
  135. R56 Turbo??
  136. R56 Evap emmission check engine
  137. R56 I want to take the MINI on a 2000+ mi road trip...need advice!
  138. R56 Yellow Check light...Uh Oh!
  139. R56 Flywheel/Clutch replacement, also oil valves at 38k on 09 JCW. Please help
  140. R56 tow hook
  141. R56 V band help!
  142. R56 Completely catless
  143. R56 New User - Mod Advice
  144. R56 Swapping the Speedo to 1 with Navi
  145. R56 Hood Pin/ Quick Release parts
  146. R56 HK speaker issues
  147. R56 Can someone post pics of 2013 MC HT Automatic steering wheel?
  148. R56 Optional OEM "Non S" Chrome Tip Exhaust
  149. R56 Broken Front Window
  150. R56 Mystery Glass Breakage!!!!
  151. R56 Clutch Question
  152. R56 Anyone else's car do this, remote fob not pop trunk. Comfort access/alarm option
  153. R56 time to pour coolant
  154. R56 Painted arches and trim... Anyone still sell them.
  155. R56 Question on 2007 MCS Battery Replacement
  156. R56 Help! Can you drive w/o diverter valve?
  157. R56 NEED HELP 2008 Mini R56 BAD Engine noise 160k
  158. R56 Interesting oil use observation
  159. R56 Replacing TPMS Valve Stems in older wheels
  160. R56 Catted Downpipe
  161. R56 TPMS Funky in cold weather
  162. R56 Few questions about Trim
  163. R56 Spark Plug Damage
  164. R56 Spark Plug Change Tip
  165. R56 2008 mini base model h, how do i know if its r56 etc?
  166. R56 Are these 17"?
  167. R56 Advice needed
  168. R56 aaaaack! another lowering question!
  169. R56 Ambient lighting question
  170. R56 Reprogramming the CBS oil change interval - can it be done?
  171. R56 2009 base model h, where to find a good code reader
  172. R56 Custom Matte Blue Metallic Wrapped MINI
  173. R56 Chain Tensioner or something else...
  174. R56 window problem - up is down and down is up!
  175. R56 Mini 2013 Justa HT - OEM Mud flap install Are they easy
  176. R56 Still happy with your CNT exhaust?
  177. R56 Who Farted?
  178. R56 2013 octane rating
  179. R56 P129D...Any Suggestions?
  180. R56 in the market
  181. R56 Towing Mini behind RV need to wire for taillights to work with trailer connection.
  182. R56 2007 R56 no crank when warm
  183. R56 My xenon light burned out
  184. R56 R56 keyfob died
  185. R56 XM Radio Sucks !!
  186. R56 Thoughts on Koni FSD for R56
  187. R56 Passenger Seat Mat Occupancy Sensor Needs Replacing! :(
  188. R56 Kite Blue/Chili Red JCW
  189. R56 Where does the Seafoam go?
  190. R56 Strange case of 07 S rotors/brakes - help
  191. R56 Did I screw up the Oil Service Reminder while resetting?
  192. R56 Discount on '13 Cooper Hardtop S ?
  193. R56 Cel without a code
  194. R56 R56 Part Out
  195. R56 Break in?
  196. R56 Xenons: Love them or hate them?
  197. R56 error after HID install
  198. R56 Need input on alignment after JCW Suspension
  199. R56 Tail light / Light Cover needed?
  200. R56 JCW turbo vs the others
  201. R56 Best method to turn engine?
  202. R56 Gas Guage
  203. R56 M7 or DDM intake?
  204. R56 Greetings!
  205. R56 Stereo muted on startup
  206. R56 Muscle car, ( torque thrust american racing) wheels on a tuner mini.
  207. R56 2007 Cooper S Turbo Stopped Running today
  208. R56 Loaner Car Age restrictions?
  209. R56 Wiper blades
  210. R56 Turbo Inquiries
  211. R56 Newbie to NAM
  212. R56 got rear ended at a red light
  213. R56 2007 R56 vacuum pump issue, the bearing may be starving for oil.
  214. R56 HID kit
  215. R56 faded fender trim with cosmolene stains
  216. R56 Coming soon: the littlest mini
  217. R56 Need some assistance.
  218. R56 Emergency help! Can push start!
  219. R56 Carbon Build-up
  220. R56 Why are my exhaust tips sticking out so much?
  221. R56 Tranny or clutch?
  222. R56 Riss Racing Downpipe
  223. R56 What do I need to know about changing my wheels?
  224. R56 07 MCS question.
  225. R56 Drifting
  226. R56 BOV question!
  227. R56 R56 OEM Headlight Lamp
  228. R56 Any major clutch issues since the new design in 2011?
  229. R56 Help Roof Rack Install!
  230. R56 Will 07 dash covers fit on a 13?
  231. R56 White wheel upgrade
  232. R56 What is missing?
  233. R56 JCW Engine Tune Kit 2013
  234. R56 bonnet strips
  235. R56 r56 non-s question
  236. R56 buzz/rattle on 2012 MCS
  237. R56 Should there be a hose here ?
  238. R56 R56 MCS running too cold?
  239. R56 Power Windows Problem
  240. R56 BiXenon lights
  241. R56 Hello everyone
  242. R56 I got a owie
  243. R56 R56 weight distribution ??
  244. R56 headlights
  245. R56 low boost at 4500 rpm
  246. R56 2010 MINI S trailer hitch?
  247. R56 After market wheels
  248. R56 Euro Style Plate for New Mexico?? YESS!!
  249. R56 winter tires
  250. R56 R56 2007 MCS quick engine questions
