View Full Version : R56 :: Hatch Talk (2007+)
- R56 What did you pay for your extended warantee?
- R56 Will I be happy with a manual S?
- R56 water leak - factory roof rack
- R56 Universal mount, fairing for OEM rack
- R56 Any spoiler changes from 2007-2012 ?
- R56 R56 DIY Clutch Diagnosing/fixes
- R56 First Time MINI Modder
- R56 Ditched the run flats - car feels different
- R56 What did your mini get for Christmas?
- R56 15" steel wheels and R56S
- R56 Lowering spring opinions?
- R56 sudden turbo lag?
- R56 Free painted headlight and trim rings... see details inside.
- R56 Vacuum pump seizure...
- R56 Afternoon Mini Photoshoot
- R56 Some pics of my 'new' mini
- R56 Auto Transmission
- R56 gas milege indicator
- R56 Without fail, winter whee/tires installed = 55f weather
- R56 Tach needle movement not smooth
- R56 Invidia Q300 Resonater Delete
- R56 Transmisson Bad on R56 only 42K Miles? What's with that?
- R56 sound from gas tank?
- R56 first time to replace cabin air filter
- R56 brake fluid
- R56 oil filters
- R56 Factory black headlights/WC50 healights color?
- R56 Oil three quarts low?!?
- R56 Wired OBD2-to-Android
- R56 MINI shop needed Milwaukee Wi
- R56 Factory HID question
- R56 Cost of 30000 mile service
- R56 First Oil Change?
- R56 while I replace an air filter.
- R56 Need a clear bra installer in denver area
- R56 5 features I miss from my previous car
- R56 Check out my new MINI :)
- R56 HAtch button on fob?
- R56 brake pad recommendation?
- R56 Adaptive Light Control defect?
- R56 Dealer recommendation for service in NJ
- R56 Can I add heated mirrors?
- R56 Were any R56's pre-wired for OEM front fog lights?
- R56 I'm officially an owner!!!
- R56 Anyone have window droop?
- R56 My Baby is Dinged!
- R56 Random sluggishness above 4500rpm?
- R56 Mud Flaps (rally armor?)
- R56 07 R56 Clutch Problems
- R56 RE: R56 Oil Hose for Turbo
- R56 My Mini is even shorter now (accident)
- R56 Mini Cranks over but wont start
- R56 Advice on buying a used Mini
- R56 PIAA 520 ATP Brackets
- R56 oil pressure warning?
- R56 Good Year
- R56 Edge Insight CS Opinions?
- R56 Rear Brake LEDbulbs
- R56 Funky alarm (LED) behavior
- R56 A close call MINI
- R56 Brake light
- R56 My JCW has no name because its a car - build thread
- R56 Digital vs actual pic
- R56 New steering wheel hook up?
- R56 Roof Rack?
- R56 Euro blind spot mirrors
- R56 Automatic Transmission Fluid Change
- R56 Wheel Of Fortune
- R56 screeching sound while driving
- R56 stock 16" conti runflats question
- R56 Lamps in bumper, what are they?
- R56 Random power loss
- R56 Cooper Hatch Bra?
- R56 Carbonfiber wrap dash trim
- R56 Tires tires tires
- R56 How do I remove the coolant bottle to change the oil filter?!!!!?
- R56 HELP - '07 MCS Cold "not a death rattle?" noise
- R56 heated lounge leather
- R56 Couple electronic/stereo questions 07MCS
- R56 no power when motor not up to temp
- R56 Seat-sons Greeings Teaser!
- R56 Mini Shop Needed-Bob Smith Area
- R56 it's time to replace air filter
- R56 For those of you who like to draw...
- R56 Next Scheduled Service?
- R56 A DIY Oil Change That's Worth the Effort
- R56 Lowest lowering spring? H&R?
- R56 Cold Weather Gas Mileage
- R56 Checking Oil level
- R56 Which OBD scanner
- R56 The Beast's Build Thread
- R56 Leaking thermostat...
- R56 Oil Filter Question
- R56 New Rear Brakes @ 23,000?
- R56 07 S exhaust
- R56 buying TPMS
- R56 Mitigating Long Term Maintenance Issues
- R56 Driving Excitiment Application for MINI Connect
- R56 07 engine noise
- R56 scan tool recomendations
- R56 Sport mode 24/7 or not?
- R56 Normal Temperatures?
- R56 Goodbye guys! (maybe a see you later?)
- R56 My Cooper S doesn't see corners anymore!!
- R56 Burping the Coolant System
- R56 This is Samuel L....
- R56 Removing trim pieces on steering wheel. How?
- R56 OEM Shorty Antenna
- R56 potential purchase need advice
- R56 Question about winter tires
- R56 new leather dash option? r56
- R56 R56 Clutch Lifespan?
- R56 London 2012 Limited Edition
- R56 New tires for my 08 Hardtop
- R56 vacuum leak coming from valve cover?
- R56 OEM offset and compatible offsets for 2012
- R56 Removing the fuel filler surround piece
- R56 MINI AM2 CUP SPOILER KIT From Germany
- R56 Loud grinding/squealing from driveshaft/transmission?
- R56 Yah So Excited!!!
- R56 union blackjack fuel door
- R56 Rear mud flap = ANGRY
- R56 R84 X-lites for R50 on an R56
- R56 R56 2011 MC Hardtop Parts List?
- R56 Union Jack on Roof?
- R56 another vote for the "top side" oil change.
- R56 "Ironically" I already got my my first warning light...
- R56 08 MC with Tailgate Issue
- R56 2012 MINI MC- Can it handle snow?
- R56 Any Satellite Grey Owners??
- R56 09 MCS Rims
- R56 Stripped Lugnut Threads
- R56 The real scoop?
- R56 Another One Saying Goodbye to Mini
- R56 Horizontal headlight adjustment?
- R56 R56 Clutch & Stuff: Options?
- R56 What Similarly Priced Cars Compete with the R56 MINI?
- R56 Re-wiring Driving Lights?
- R56 Well, It's been real fun folks.....
- R56 Do you always leave your roof rack on your R56?
- R56 Rennline 15% OFF Holiday Sale - Now Valid!
- R56 Who make the best runflat tire for the mini
- R56 Navigation video playback
- R56 So, how do YOU get treated on the road?
- R56 Best place to sell your Mini?
- R56 CTEK Battery Maintainer Won't Work?
- R56 Black Jack OR Checker
- R56 New Fix for Check Engine Light?
- R56 Aftermarket Wheels Advice?
- R56 Tire Sizes
- R56 JCW rocker moldings.
- R56 Modding Voids Warranties?
- R56 Asymmetrical rear lights?
- R56 Budget Navigation Possible using USB/iPod Adapter?
- R56 Where to buy McGard Wheel Locks 27226 BLACK in USA?
- R56 Power Steering Problem 2007 S
- R56 Against my better judgment, I opted for the extended maintenance...
- R56 JCW body kits installation
- R56 JCW Aero Body Kit Installation
- R56 Clear coat fail on wheels?
- R56 2 weird noises/ clutch life
- R56 A coupla newb questions on Daytime Running Lights...
- R56 Which retrofits make sense?
- R56 Mystery cable at right rear
- R56 i need rear caliper R56
- R56 Seat cover for dogs
- R56 Car won't start after rear brakes replacement
- R56 what did you buy for mini on black friday?
- R56 In Need of JCW Brake Duct Templates
- R56 R56 Clutch recommendations?
- R56 a how to replacing the rear bulbs?
- R56 Can I convert rear fog lights into clear backup?
- R56 Tape on engine wires???
- R56 1st Mod
- R56 Which Short Throw Shifter?
- R56 Rennline's Black Friday Starts Now!
- R56 Clunking Noise
- R56 Where is the engine build thread
- R56 EPA-sticker
- R56 Aftermarket headlight assy’s....
- R56 235 tire options...
- R56 Opinions on the Sport Seat Option?
- R56 anyone have this problem (pic)
- R56 Feeler: Group Buy 07-12 projector headlight group buy?
- R56 NM Engineering High Flow Intake - Blue Filter
- R56 what intercooler has the radiused plate edges
- R56 Which hitch?
- R56 Engine cooling fan on all the time
- R56 Should I be worried about someone stealing my spare tire? (non S)
- R56 Retrofit questions
- R56 Stealth bulbs 07 R56 not PY21W? Need 180 degree pins, anyone?
- R56 All clean after all the blackout work
- R56 West coast car trucking company help??
- R56 talk me into or out of a mini
- R56 R56 Water Pump Change Help
- R56 weird sound
- R56 Just picked up a 2012 MCS and had some modding ?'s
- R56 when to replace belt?
- R56 Windshield wiper size?
- R56 Tire suggestions
- R56 How To Do a Burnout ?
- R56 Clutch Question
- R56 iPod interface?
- R56 When do I need to change spark plug?
- R56 Service Manual Download?
- R56 Check this out!
- R56 Taking apart 2011 MCS auto gear selector knob
- R56 Justa Cooper Getrag... Redline MTL or GM Synchromesh?
- R56 New!!!
- R56 Opinion Needed Please....
- R56 how my mini knows when to change oil and brake?
- R56 $5G reward offered in theft of one-of-a-kind Mini Cooper
- R56 "noisy tires"
- R56 '07 S Steering Failure
- R56 Charlotte got rear ended by the biggest truck chevy makes
- R56 New Mini Cooper Intake from AEM
- R56 Mini Artwork
- R56 TPMS Question
- R56 R56 +35mm offset wheels question...
- R56 ugly on my MINI
- R56 Sold the MCS, happy motoring everyone!
- R56 Looking For... Replacement Boot/Bonnet paint guards
- R56 Bras - ins and outs
- R56 odd engine behaviour
- R56 Tire slipping crazy when breaking and...
- R56 Mini Weight???
- R56 Warranty warning!
- R56 Paddle Shifting
- R56 Help with brake squealing !
- R56 Discounts on New 2012's?
- R56 Extended Warranty?
- R56 Replaced thermostat, can't fill with coolant???
- R56 i dont know why?
- R56 Help with Driving Light decision
- R56 Break-in Period?
- R56 my mostly useless rally lights
- R56 Connected features that require cradle?
- R56 spray paint mirror cap?
- R56 *sad face* :(
- R56 Higher mileage with no major issues post here
- R56 Looking for pics of Minis with blue wheels
- R56 CPO trans replacement question
- R56 2012 Mini Cooper S oil change
- R56 JCW Upgrade or aftermarket?
- R56 Check engine and low power issues
- R56 what fluid evacuator do you use for oil change?
- R56 Check Engine Light Woes
- R56 Extended warranty or maintenance?
- R56 Rattles identified, what's the permanent fix?
- R56 What could be leaking?
