R56 Check Engine Light Woes
Old Nov 8, 2011 | 02:42 PM
futureicon's Avatar
futureicon
Hi all,
I've been getting a p115c cel now for about 2 weeks. It goes out now and then but always returns. My reading through the forums led me to believe it was a dirty maf sensor. I tried cleaning it and when that didn't solve it, I ordered a new one from rockauto for 200$. Dropped the new one in today and it didn't resolve the light. I tried clearing the cel after replacing the maf and it won't clear, even temporarily. This problem is occurring on a 2009 Cooper S. The only mod I've done is an oil catch can. I still use the stock airbox and filter. Before I take the car in and get raped by the dealer, does anyone have any ideas on how to fix it?
Old Nov 8, 2011 | 06:26 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
That looks like a MINI specific code which can only be read by a dealer or one with the MINI codes. Some folks could make an educated guess, but it would be just that, a guess. What did you clean the sensor with ?
When it comes to things like this I ask myself.....Do I want to just keep throwing money at this problem with the "$hotgun method" of replacing all sorts of parts ? Or, just fork that ill spent cash to someone with the equipment and know how and be done with it....You've already spent over $200.00 which could have been used at the dealer and well on your way to a diagnosis and some probably $$ towards a new part.
Granted maybe $120.00 an hour labor at a dealer is not cheap but it's almost half what you have spent so far with no results whatsoever.
Your call.
Old Nov 8, 2011 | 06:37 PM
futureicon's Avatar
futureicon
Very true, but the sensor takes literally 10 minutes to replace, and it'll be easy to return. I read that this was a maf sensor code on five different threads from three separate websites so I figured it was a no brainer. Does anyone offer a code reader that specifies what the mini codes actually mean?
Old Nov 8, 2011 | 06:43 PM
bluefox280's Avatar
bluefox280
Bavarian Technic does; but your P115C is enough to post up the actual fault code from the Bentley Service Manual:
* MINI DTC P115C (0x2775) - Mass Air Volume Flow 'A' Too Low
If your filter (assuming paper element) clogged?
Is the intake tube clear of oil film?
Is your catch can empty?
- Erik
futureicon's Avatar
futureicon
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
