R56 how do you check the oil temperature?
Old Jan 8, 2013 | 08:38 AM
yyj3869's Avatar
yyj3869
especially R56 models don't have any functions to check the oil temperature right?
these days I went to several sevice shop and they told me that i need to replace the thermostat. thermostat matters to oil temperature right?
is there any ways to check the oil temperature?
Old Jan 8, 2013 | 09:02 AM
DneprDave's Avatar
DneprDave
There are electronic gages that plug into the OBD2 connector, that will show you many different temperatures and pressures. Scangauge 2 and Aeroforce interceptor are two examples.
http://www.scangauge.com/products/scangaugeii/
http://www.aeroforcetech.com/products_interceptor.html
There are also smartphone apps that work with a transmitter plugged into the OBD2 connector that will display data on your phone.
I installed analog water and oil temperature gages as well as oil pressure and boost gages in my MINI, 'cause I like the look.
For thermostat problems you would want to watch the water temperature, rather than the oil temperature.
Dave
Old Jan 8, 2013 | 09:19 AM
countryboyshane's Avatar
countryboyshane
Are you seeing oil temperature broadcast over OBDII? I thought the N14 engine didn't even have an oil temperature sensor because of cost cutting.
I always though you had to tap a hole for a temperature sensor in the oil pan and have a separate gauge installed for oil temp
Old Jan 8, 2013 | 09:32 AM
byron h's Avatar
byron h
I got the ScanGuage Beta update described in the followin post. This update reads the oil temperature on my 2011 MC plus many other nice readouts.
https://www.northamericanmotoring.co...577-post1.html
Morris, 2011 MC, PW/B
Old Jan 8, 2013 | 10:08 AM
DneprDave's Avatar
DneprDave
Yes, oil temperature is broadcast on the OBD2 with the N14 engine. The oil temperature probe is right at the driver's side of the head, it's where I put the Cravenspeed adapter for my analog gages. I plugged a data logger into my OBD2 port and oil temperature was one of the things it was reading.
Dave
Old Jan 8, 2013 | 12:17 PM
yyj3869's Avatar
yyj3869
regardless of my topic, I also plan to replace rotors but there are some life left on brake pads. Is it okay to replace only rotors???
Old Jan 8, 2013 | 02:47 PM
countryboyshane
Yes. Are they thinner than the minimum thickness that's shown on the rotor hat? If not you're wasting your money.
TREX
Nov 2, 2019 07:31 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
kwijmbo
Aug 5, 2015 09:00 PM
