R56 Anyone running 205/40-17 tires?
Old Nov 30, 2012 | 12:42 PM
Ryan89's Avatar
Ryan89
Hi guys, Found a decent second set of wheels I was planning on picking up for the summer. 17in is where I want to be. I believe I saw a chart with the different stock wheel diameters with different tires/rim sizes, but can't seem to find it.
The set I am looking at has 40s which I am not sure if that would be good or bad. Anyone run 40s before?
Old Nov 30, 2012 | 08:07 PM
bluefox280's Avatar
bluefox280
There's several running 205/40-R17 tires; typically on a lowered vehicle with wider (7.5"+) wheels.
Search the wheel/tire archives as you'll find lots and lots of images.
- Erik
Old Nov 30, 2012 | 09:28 PM
Big Jim Swade's Avatar
Big Jim Swade
I'd go with at least the stock size of 205/45-17's to keep your speedometer somewhat close
Old Dec 1, 2012 | 05:25 AM
Ryan89's Avatar
Ryan89
I would certainly prefer the stock 205/45 but there is a good deal on a set of wheels that have 40s on them. Was just curious if anyone ran them. I know the wheels are 17x7. I'll check out the pictures, thanks Erik
Old Dec 1, 2012 | 06:44 AM
hemisedan's Avatar
hemisedan
I've been running 215 x 45 x 17 tires since it was new. The 205's have around a 7 mph speedometer error, thanks to Europe in trying to slow cars down. With the 215's I have about a 1 mph error. I've had this checked by Iowa Highway Patrol radar that they use.
As for going 205 x 40, I think that 225 would work better for you and I've heard of guys running them on hatch's with no problems. Get with TireRack, they are good help.
Old Dec 1, 2012 | 07:06 AM
Ryan89's Avatar
Ryan89
Any idea where I can find the chart ive seen floating around on wheel diameter with the different tire sizes that come on the mini?
Old Dec 1, 2012 | 08:37 AM
cristo's Avatar
cristo
Alliance Member
Halfway down this page on the other forum (that I seldom visit anymore)
http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres
is this:
On street cars, it should have an overall diameter that is within ±3% of the factory specification.
The ±3% variation is recommended for street cars in order to maintain accurate speed data
going into the computer, thus keeping odometer and speedometer changes negligible.
While a ±3% diameter increase or reduction in tire diameter may sound very limiting,
in most cases it allows approximately a ±3/4" diameter change.
Assuming 24.00" (609.6mm) as the factory specification for overall diameter, any of the following tire sizes may be appropriate:
TIRE SIZE | DIAMETER
195/55-15 | 23.44in (595.5mm) |
205/40-17 | 23.46in (595.8mm)
215/50-15 | 23.46in (596.0mm)
215/45-16 | 23.62in (599.9mm)
195/50-16 | 23.68in (601.4mm)
185/60-15 | 23.74in (603.0mm)
215/40-17 | 23.77in (603.8mm)
205/55-15 | 23.88in (606.5mm)
215/35-18 | 23.93in (607.7mm)
175/65-15 | 23.96in (608.5mm)
225/45-16 | 23.97in (608.9mm)
205/50-16 | 24.07in (611.4mm)
225/40-17 | 24.09in (611.8mm)
225/35-18 | 24.20in (614.7mm)
195/60-15 | 24.21in (615.0mm)
205/45-17 | 24.26in (616.3mm)
215/55-15 | 24.31in (617.5mm)
195/55-16 | 24.44in (620.9mm)
205/40-18 | 24.46in (621.2mm)
215/50-16 | 24.46in (621.4mm)
185/65-15 | 24.47in (621.5mm)
215/45-17 | 24.62in (625.3mm)
Stock fitments are highlighted
________________________________________
This list leave off at least one commonly used size:
205/55-16 | 24.88in (631.9mm)
Some other good tire and wheel info on the page in the link above,
although a lot is missing or outdated now.
Old Dec 1, 2012 | 10:27 AM
llewellyn's Avatar
llewellyn
I have 205 40 17's General Exclaims on my car - the speedometer does read off. You'll have a bit more fender gap, and you wouldn't think it would make a big difference, but your car will sit a bit lower. I can just fit the toe of my shoe under the front rubber lip under the bumper. Everyone asks me if I have springs on it haha..
Old Dec 1, 2012 | 07:41 PM
mini coop's Avatar
mini coop
Discount Tire Direct has a calcuator. Top right under info center and then click on tire size calculator. Running these against stock will mean a diference. You don't say what your stock size is but 205/40/17 is not a direct replacement for any stock size tire that Mini uses. This calculator will provide diameter, circumference, width, side wall height and very important.....mph equivalent against the stock tire size.
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
kyungmanpark
Aug 23, 2015 07:26 PM
