R56 Has anyone tried to run Alta Acessport Stage 2
Old Dec 14, 2012 | 12:44 PM
mcoupe's Avatar
mcoupe
With a FMIC and the JCW exhaust? I know the JCW is not considered a true free flow 3" exhaust but can it be done? Or just Stage 1 only. Thanks!
Old Dec 14, 2012 | 12:57 PM
JPMM's Avatar
JPMM
stage one only on a stock R56 jcw exhaust
Old Dec 14, 2012 | 02:34 PM
mcoupe's Avatar
mcoupe
Even if I have a FMIC?
Old Dec 14, 2012 | 02:49 PM
JPMM's Avatar
JPMM
tons of threads on this
Yep, makes no diff, yours( and mine ) exhaust is too stuffed up . I don't think the 2nd stage tune thing is gonna matter too much anyways. You would have to run a loud, and/or code throwing exhaust to use the #2
Old Dec 14, 2012 | 02:55 PM
mastermason11's Avatar
mastermason11
I run a stage 2 with a helix fmic + akrapovic dp + jcw factory exhaust. Runs well....
Old Dec 14, 2012 | 03:10 PM
JPMM's Avatar
JPMM
there you go..... change some of the JCW exhaust( the cat) and you will be OK, thanks for the info ( how much diff are you seeing with the stage two?)
Old Dec 14, 2012 | 03:33 PM
mastermason11
Just wanted to put a disclaimer on this.. Although this is what i'm running right now, this was against ALTA's recommendations. Per Alta, i should stick to stage 1 fmic regardless if i have an aftermarket dp unless i have a 2.5" or bigger exhaust system. With the jcw being to about 2.25", i figured its worth a shot.
From a difference perspective, big pull difference but nothing like you get wet in your pants.
Hope this helps.
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Aug 21, 2015 11:25 AM
