R56 New to Mini, trouble with hot air
Old Jan 2, 2013 | 12:29 PM
Some Dude's Avatar
Some Dude
Hello, this is my first post and I am interested in learning more about the Mini community. I am active on Nasioc and own a 2006 Subaru WRX. The car in question is a 2008 Mini Cooper. It is my mother in-law's car. The problem is that the heat is no longer hot all of the time. It gets hot when the engine is under load but cools down dramatically when coasting. My first thought is that the thermostat is bad. I don't know if there is a engine temp I can access somewhere to confirm that it is a bad thermostat. Is there anything I can do to verify it is the tstat? I would be looking at doing the work myself assuming it isn't too difficult. Any input is appreciated.
Old Jan 2, 2013 | 03:00 PM
myR56S's Avatar
myR56S
To eliminate the thermostat you would need a engine temp gauge or a advance scanner you can hook up to the OBD II port and monitor the temps. It could be a thermostat but the car would warm up VERY slowly if it were say stuck open. If it was stuck shut then it would over heat.
Does the car have auto climate control?
Old Jan 2, 2013 | 03:33 PM
Some Dude's Avatar
Some Dude
It does not have auto climate control. It seems to warm up in a relatively normal amount of time. But the heat is colder than room temperature while idling. It will get to what i would consider 'full hot' within about 10 seconds when the engine is under load. The heat also heats up when decelerating and downshifting to keep the revs up.
Old Jan 2, 2013 | 03:44 PM
Deli's Avatar
Deli
I can't help with you problem but I can say "WELCOME TO NAM!"
Old Jan 2, 2013 | 04:39 PM
millerb7's Avatar
millerb7
When my thermo went bad the car overheated. Your issue seems very odd. Hopefully someone can help out. Welcome aboard.
PS. I'd try nabbing a scanner like mentioned above, it'll be the only way to get actual temps.
Old Jan 2, 2013 | 04:43 PM
Just Krusen's Avatar
Just Krusen
Is the radiator full?
Old Jan 2, 2013 | 04:51 PM
Kenny the kid's Avatar
Kenny the kid
Sounds to me that the coolant level is low , therefore it takes high revs from the engine to circulate the coolant through the heater box.
Old Jan 2, 2013 | 08:45 PM
CooperS84's Avatar
CooperS84
I had the same problem, turns out I had a coolant leak, no cooalant = no heat. I also had a thermostat issue that got replaced as well so I would have it checked out.
Old Jan 2, 2013 | 08:52 PM
daddyandmadi's Avatar
daddyandmadi
I had the same issue. Mine was thermostat. Was -20 Celsius when it wouldn't heat. Brrr.
I thought there was a recall on some thermostats. Check it out.
Welcome to NAM.
Stephen
Old Jan 4, 2013 | 04:25 PM
Some Dude's Avatar
Some Dude
Thanks for the replies, and thank you for the welcome. I have not checked the coolant level so I will do that first and report back.
Old Jan 5, 2013 | 10:52 AM
Ta87's Avatar
Ta87
Same thing happened to me. -10 degrees and no heat in the morning makes for a rough drive to work. I have one ordered to be replaced next week.
Old Jan 6, 2013 | 11:19 AM
Some Dude's Avatar
Some Dude
The coolant was low. It was just covering the bottom of the reservoir so I topped it off and now it has piping hot heat! Thanks for the input, 1st thread is a success.
Old Jan 6, 2013 | 04:17 PM
bratling's Avatar
bratling
Super Moderator
Don't forget to look for the leak!
09R56
Nov 16, 2022 10:49 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
Motown
Apr 20, 2018 09:31 AM
MiniJess
Aug 10, 2015 09:51 PM
