R56 Sparco seats and steering wheel extension
Old Oct 30, 2012 | 09:27 AM
solskjaer1999's Avatar
solskjaer1999
I've seen a few people with the Sparco Evos in their Mini. Was it a tough install? Do the weight sensors freak out or anything or how do you get around that stuff. Also I'm trying to find a hub extension to bring the steering wheel closer. Even with the telescopic wheel, I don't like it's limited range and was wondering if anyone has fitted something like this.
Old Oct 30, 2012 | 09:29 AM
Porthos's Avatar
Porthos
You can bypass the airbag warning on the seats I just don't know how to. Search it you should be able to find out. Steerinh Wheel extension, do you have a picture of what you are talking about.
Old Oct 30, 2012 | 09:46 AM
solskjaer1999
I was thinking something like this:
http://www.google.com/imgres?hl=en&b...:19,s:17,i:192
I know there are universal spacers/extensions, but I was wondering if any one has one and what issues they may have had. I'm trying not to be a guinea pig.
Old Oct 30, 2012 | 10:54 AM
Porthos's Avatar
Porthos
I would get something with a good return policy and buy one. Also get some wire extensions for the airbag. That might work.
Old Jun 12, 2013 | 10:36 AM
lex76's Avatar
lex76
Did you end up getting the steering wheel extension kit?
Old Jun 12, 2013 | 11:26 AM
countryboyshane's Avatar
countryboyshane
I've installed Sparco Evo seats in my R56 along with Schroth 6-point harnesses. You should NOT use the stock seatbelts with the Evo seats for safety reasons!!! The seats are not difficult to install. I would just call it time consuming, but not necessarily "hard". I thought taking out my front subframe was more challenging of a DIY job. Most others have used the Brey Krause brackets but I used VAC Motorsports parts instead to interface with my Schroth 6-point. Grade A stuff!
The airbags are easy to defeat with a 2.2-2.3ohm resistor, but it's the seatbelt sensor, seat position sensor, and passenger occupancy sensor that I never got around to ironing out. If there is a fault in any one of these items the airbag light will trigger and can only be reset by a BMW diagnostics tool. My light is on, and I really don't have much initiative to fix it. Yes, it's a red light, but the safety system still works fine. That's coming straight from a BMW techs mouth. If you're really gung ho about killing the light, by all means spend the many hours attacking it.
Regarding the steering wheel extension, if you find a talented local fabricator they can figure out a way to make an extension.
Old Jun 12, 2013 | 05:28 PM
v10climber's Avatar
v10climber
You'll have a hard time finding someone to make you a hub extension while keeping your airbag...
theblackfalcon
Oct 11, 2015 09:49 AM
trw92a
Aug 26, 2015 01:47 PM
Zettinger
Aug 25, 2015 04:04 PM
Powershift
Aug 16, 2015 05:14 PM
