R56 BSH R56 Lower Engine Mount (Street)
Old Mar 21, 2013 | 12:06 PM
fcminicoopers's Avatar
fcminicoopers
Hi there, does anyone have this Lower Engine Mount installed?
How is the fitment and performance?
This is what i'm talking about
http://www.parts4euro.com/DCShop/pro...oducts_id=1464
Old Mar 25, 2013 | 12:53 AM
barnoun's Avatar
barnoun
I ran the BSH street mount on my car for a few years. Fitment was perfect and the improvement in response feels awesome.
I took it off and sold it though. My car is a daily driver and eventually the vibration got to me. It made the whole car vibrate and the interior panels would vibrate at different rpms. Went I went back to the stock mount the car felt like new again, super smooth and rattle free.
It's nice if you're going to the track or auto-x, but definitely not for a daily.
Old Mar 25, 2013 | 04:24 AM
KilmerPT's Avatar
KilmerPT
+1
I have one for sale if you are interested. After installing it, I decided after only a day that it wasn't for daily driving due to the added noise and vibrations. Anyhow, PM me if interested. :cheers:
Old Mar 25, 2013 | 05:28 AM
JPMM's Avatar
JPMM
I love mine , its what the Mini should have from the factory.
Old Mar 25, 2013 | 09:19 AM
sooper_cooper's Avatar
sooper_cooper
Has anyone used both the BSH street as well as the NM? How do they compare? I'm guessing the BSH is stiffer.
Old Mar 25, 2013 | 12:29 PM
TazMinianDevil's Avatar
TazMinianDevil
NM takes out the slop. Makes things slightly sharper. Little if any vibration added. Too Cold...
BSH takes it to 11. Love the steering feel. Laser sharp inputs. Horrible vibration and noise at 2700rpm... It backed the nuts off the downpipe brackets after 600 miles. Too Hot!
I will install BSH before Solo Nationals, but run NM for DD.
Still looking for just right... Picked up Powerflexes new Black Series insert but haven't tested it.
Old Mar 25, 2013 | 12:41 PM
KilmerPT's Avatar
KilmerPT
Just answered your PM. Hope it helps. = )
Old Mar 25, 2013 | 12:45 PM
KilmerPT's Avatar
KilmerPT
LOL @ "it backed out the nuts off the DP brackets"
Old Mar 25, 2013 | 12:52 PM
JPMM's Avatar
JPMM
NM not enough control , BSH just right for me and my Mini
Old Mar 25, 2013 | 06:35 PM
sooper_cooper
It did, thanks for the info. The NM is definitely too little for my style, or maybe I've just gotten used to it.
Think it's time to try the BSH...
Old Mar 25, 2013 | 08:17 PM
Hoopty's Avatar
Hoopty
DIY Motor Mount
I've tried both the black inserts and the BSH mount......this solution has worked out perfectly.
https://www.northamericanmotoring.co...tor-mount.html
Hoopty
Old Apr 10, 2013 | 01:50 PM
iminir56's Avatar
iminir56
Hello everyone, i have a brand new BSH Lower motor mount for sale. Pm me if youre interested! I am selling it for my cousin cause he just sold his mini. This was ordered 2 weeks ago and it was never installed.
Old Apr 30, 2013 | 05:13 PM
fcminicoopers
great, thanks for the feedback guys
Old Apr 26, 2014 | 03:43 PM
Genzox's Avatar
Genzox
Bsh
Just curious if you still had these?
Old Apr 27, 2014 | 05:20 AM
sgscomps's Avatar
sgscomps
I installed the PowerFlex "Street" bushings on both ends of mine and it really made a big difference
Old Apr 27, 2014 | 08:40 AM
iminir56's Avatar
iminir56
Sorry! I do not
Old Apr 27, 2014 | 06:01 PM
afadeev's Avatar
afadeev
Why?
What problem does it solve by transmitting more vibration from the engine to the chassis?
a
Old Aug 18, 2017 | 06:14 PM
lex76's Avatar
lex76
hey guys so I had the bsh engine mount and removed it because of the vibrations inside the car.
i'd like to know from someone who has tried the power flex black, street and the bsh mount.
Does the power flex black give you the same amazing feeling and feedback you get with the bsh but without the vibrations?
can you get the power flex top mounts and mount that with the bsh? Will that eliminate the irritating vibration?
let us know what is the best solution is.
Old Aug 24, 2017 | 02:37 PM
The power flex black is pretty tight, if you go power flex and you want a better feel go with the performance series.
Old Sep 9, 2017 | 11:13 AM
R56devotion's Avatar
R56devotion
Can you post up an ECS link for this? Thanks
Old Sep 18, 2017 | 09:42 AM
Yep.
Here is the full line. The engine support is a large and small bushing. Listed.
https://www.ecstuning.com/News/MINI_Gen_2_Powerflex_R55_R59_S_JCW_23542/
Old Sep 19, 2017 | 03:27 AM
KCLARK's Avatar
KCLARK
^^^ these powerflex bushings you posted, are these only for fitment in the STOCK lower motor mount, or you saying you can use these in the BSH or NM versions that's offered. I saw this post by Gipper that claims that the lower motor mounts need to be modified to ensure the smaller end isn't metal on metal (as this is whats causing the vibration everyone is complaining about). https://www.northamericanmotoring.co...ngineered.html
Old Aug 6, 2018 | 08:06 AM
JPMM's Avatar
JPMM
old thread update
I had my BSH loosen bolts after a while ,causing rattling so I tightened the BGee's out of them. That introduced more vibration than I had before. Could'nt figure that out. But eventually I removed the BSH , reinstalled the OEM mount and like the other poster mentioned the car felt new again. I think the BSH center spacer crushes under the bolt torque causing the rubber to become really squeezed more than it was designed for and causing more vibration. This could be fixed by adding spacers , but I took it off. So I do have one for sale
Old Aug 7, 2018 | 01:48 PM
Originally Posted by KCLARK
^^^ these powerflex bushings you posted, are these only for fitment in the STOCK lower motor mount, or you saying you can use these in the BSH or NM versions that's offered. I saw this post by Gipper that claims that the lower motor mounts need to be modified to ensure the smaller end isn't metal on metal (as this is whats causing the vibration everyone is complaining about). Just saw thishttps://www.northamericanmotoring.co...ngineered.html
Just saw this post, its stock. Just got a notification on this post, must have been since JPMM replied.
silence2-38554
Nov 12, 2015 09:39 AM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
xpunisherx
Aug 10, 2015 10:50 PM
