R56 Codes P000A and P0190 Mini runs on half power.
Old Mar 15, 2013 | 12:32 PM
Railic's Avatar
Railic
Did anyone got this before? When driving I'm getting the hiccups before full throttle I already changed Vanos solenoid and timing chain is good.
Thank you for help.
I'm new here this is great.
Old Mar 15, 2013 | 01:42 PM
Found the code for the P000A:
https://www.northamericanmotoring.co...916-p1497.html
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
Here is a great link for Gen 2 MINI codes:
http://www.clubmanregister.co.uk/vie...hp?f=14&t=1007
P000A: I would get that checked out asap the , seems like camshaft position senors is bad or check the wire going to it.
Old Mar 15, 2013 | 03:51 PM
Braminator's Avatar
Braminator
Keep us posted.
Old Mar 16, 2013 | 12:44 PM
Railic's Avatar
Railic
On Monday I will call and check how much camshaft position sensor cost if not to much will replace it and start from there.When was at service they told me timing is retarded but I did,t feel paying $900 to fix it. Recently change clutch myself I guess I can fix the other thing if I got good diagnose.
Car jerking when need to change gear.When in neutral run on 1000/rpm and if I push on gas it takes it good but go down to 1000/rpm very slow .
Thanks for help.
Old Apr 22, 2013 | 05:03 PM
Railic's Avatar
Railic
Anyone change fuel rail pressure sensore on 2007
need to know if the sensor is incorporated in fuel rail
Thanks for help
Getrieben
Sep 12, 2024 07:03 AM
mdutton11
14
Oct 26, 2015 01:47 PM
Lt. Dan
Aug 10, 2015 08:23 AM
kwijmbo
Aug 5, 2015 09:00 PM
