R56 Non-S R56 Fuel Grade
Old Feb 27, 2013 | 12:14 PM
Staggs's Avatar
Staggs
I'm not so much a gear head as others on this forum are so I'd like others' opinions: Is a premium fuel grade for a non-S R56 really necessary?
I understand higher grade for turbo and special parts, but what about just the stock? What are you guys' opinions?
Old Feb 27, 2013 | 12:19 PM
raffy888's Avatar
raffy888
I drive a Justa and I always use premium fuel (93 octane). I always go to Valero and only that gas station because my grandpa told me that every gas station has a different mix so I only stick to one. I honestly think its necesssary because when I first got my car, my mom put a mid grade fuel (89 octane) and my car started bogging on idle. When I switched to premium fuel it was back to normal. Hope I helped.
Old Feb 27, 2013 | 12:32 PM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
I use 93 despite the added expense, and use top tier gasoline from Exxon and Shell to take advantage of the different additives in each. I'll even fill-up with BP since the Countryman owner's manual recommends it.
Old Feb 27, 2013 | 12:37 PM
jcauseyfd's Avatar
jcauseyfd
The non-S has a relatively high compression ratio (last I checked it was actually higher than the S when not boosted), which is why a higher octane fuel is recommended.
Braminator's Avatar
Braminator
91 is the minimum octane you should use.
Old Feb 27, 2013 | 12:47 PM
Derek1387's Avatar
Derek1387
This makes me sad... but maybe will help the Mini run better on the bottom end. Thanks for the info.
Old Feb 27, 2013 | 01:05 PM
Braminator's Avatar
Braminator
Why are you sad? Your MINI should only get the best for it IMO.
Old Feb 27, 2013 | 02:52 PM
Rgoodwin's Avatar
Rgoodwin
Come on its only a couple bucks per fill up. I've tested both and I only run 93 no ethanol. Get a couple more miles per gallon and runs much smoother. Motor on!
Old Feb 27, 2013 | 03:26 PM
blakeslee_a's Avatar
blakeslee_a
Premium averages about 20-25 cents more than regular, when filling a 13 gallon tank that is a difference of $2.60 to $3.25 per fill up
How much are you really saving? Not worth it IMO
blakeslee_a
Premium averages about 20-25 cents more than regular, when filling a 13 gallon tank that is a difference of $2.60 to $3.25 per fill up How much are you really saving? Not worth it IMO
Old Feb 27, 2013 | 04:17 PM
Derek1387's Avatar
Derek1387
I guess you are right. Especially if you get better mileage.
It just looks like so much more as it creeps closer and closer to $4/gal
Old Feb 27, 2013 | 05:33 PM
Staggs's Avatar
Staggs
Didn't know that about the compression ratio! Also didn't know what the term "justa" meant until now. Thank you for that.
Old Feb 27, 2013 | 05:57 PM
Slave to Felines's Avatar
Slave to Felines
I recall that my owner's manual says "minimum 89, recommended 91+". So it'll be OK with mid-grade, but they recommend premium. Even for the "Justa".
Old Feb 27, 2013 | 05:58 PM
Rgoodwin's Avatar
Rgoodwin
I was filling up a Durango so this is like I'm making money!
Old Feb 27, 2013 | 08:20 PM
RJKimbell's Avatar
RJKimbell
Haha...me too, before Molly came home we had a 2001 Dodge Durango (15mpg, if I was lucky), not an R/T thank God and a 1999 Chevy Blazer, the Blazer was sold first and by default my Husband inherited the Durango. The Durango was traded for my Husband's 2010 Kia Soul Shadow Dragon SE #3 "SMAUG".
Seriously, if you are going to worry about a few extra pennies when you fill your tank, start using RedLine Motor Oil, I'm now getting 2mpg better because I switched to RedLine last October!!
Old Feb 28, 2013 | 09:27 AM
Staggs's Avatar
Staggs
I work in a rural area and noticed 91+ is scarce. The pennies don't add up to much... unless I have to go to one of those stations who is the only one with premium and jacks up the price. If I ever get in a bind and need to fill up here I feel pretty comfortable using a lower grade. But, have already picked out my stations that have a good price for prem.
How is HESS for prem gas quality?
Old Feb 28, 2013 | 05:42 PM
RJKimbell's Avatar
RJKimbell
I fuel up every Friday whether Molly is needing a drink or not...sign at Shell Station on corner reads..."$4.09"
I've posted this many times, don't really know how many have listened, probably not many but www.fuelly.com is a great place to keep track of MPGs and Costs, you'll also be able to see how other MINIs and cars are doing.
David.R53
Sep 1, 2015 06:49 PM
thebordella
Aug 31, 2015 01:37 PM
Shelly Cooper
Aug 10, 2015 12:05 PM
bc219
Aug 10, 2015 11:22 AM
