R56 Bad alternator or just battery?
Old Apr 7, 2013 | 07:15 PM
LawrenceC's Avatar
LawrenceC
So I drove my R56 to work today then 20 minutes later I was going to move it then it wont start, Dash lights are still intact but won't start so I took one of those portable jumpers at work then it starts then few hours later I was going to lunch then it won't start again so I did the same thing so it started, Got back to work I left the engine running for at least 30minutes and hope everything is okay then I turned it off. I get into my car and it won't start again.
What could be the problem? At idle the accessport reads 14volts
Old Apr 7, 2013 | 09:52 PM
sir5150's Avatar
sir5150
I would say your alternator is working fine if it reads 14 volts. Your battery most likely has a bad cell that won't let it hold a charge.
Old Apr 8, 2013 | 05:11 AM
countryboyshane's Avatar
countryboyshane
Yup, 14V during idle is a sign of a good alternator. Your battery is focked.
Old Apr 8, 2013 | 07:20 AM
lowsid3r's Avatar
lowsid3r
Just want to throw out that an alternator can read proper voltage and still be bad. Bad diode not enough amps so on. Most likely you need a new battery though.
Camden90240
Sep 28, 2020 12:09 PM
UncDeo
Nov 4, 2019 04:08 AM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
wildwestrider
Sep 6, 2015 06:18 PM
