R56 Justa water pump problem
Old Mar 27, 2013 | 07:58 PM
yyj3869's Avatar
yyj3869
Last time I went to dealership regarding idle problem after they diagnosed my car, they found the water pump leaks. I just didn't think that it is big deal and I requested fill up the coolant (it was right below minimum) and then after 2 months passed, now I checked the coolant it's below minimum again and smells burning little bit as well from engine... there are nothing came on the indicator...if I leave it like that, engine is going to be messed up?
Old Mar 27, 2013 | 08:08 PM
slinger688's Avatar
slinger688
Top up the coolant ASAP. Do not wait for the idiot light to come on.
What year is the car? Is it under warranty?
Old Mar 27, 2013 | 08:19 PM
yyj3869's Avatar
yyj3869
It's 07 justa hits almost 79k..unfortunately, it's out of warranty..
Old Mar 27, 2013 | 08:35 PM
Bakerbrdz's Avatar
Bakerbrdz
https://www.northamericanmotoring.co...placement.html
This might help, do it yourself. This is a turbo but should be straight foward
Old Mar 27, 2013 | 08:39 PM
yyj3869's Avatar
yyj3869
I don't have any mechanic skills....
would replacement cost a lot?
Old Mar 28, 2013 | 10:18 AM
grueinthebox's Avatar
grueinthebox
Search shows people being quoted $750-850 to have the water pump replaced. Possibly dealer costs / good independent mechanic might be cheaper? Dunno, but water pump and coolant leaks are definitely a big deal. Replacement is spendy, but nowhere near the cost of a new engine.
Old Mar 28, 2013 | 10:42 AM
Posted this in another post but it will show you the parts and what you need. Here is the Hepu version water pump. Also you will want to make sure you are not leaking under the thermostat, its on the driver side of the engine. It can pool some coolant on the top of the transmission.
Replace the pump and recommend to refill with MINI OEM coolant mixed with distilled water. You don't want you engine to leak coolant and then overheat.
Hepu water pump
http://www.ecstuning.com/Search/11517550484/ES2139915/
MINI OEM Coolant
http://www.ecstuning.com/Search/82140031133/ES196253/
Old Mar 29, 2013 | 04:25 PM
yyj3869's Avatar
yyj3869
These two are i received from dealership. i need to replace water pump right? and im confused with price. second one shows it costs $482.90. if its right, its good deal right? or is it without labor fee?
Old Mar 29, 2013 | 05:29 PM
mini coop's Avatar
mini coop
My 2008 Justa with 75,000 miles had a water pump leak. Its recommended to have the timing belt and tensioner done at the same time as, mileage wise, its due and the car will last longer. The engine is apart anyways and this is how the timing belt and tensioner is accessed. It would be cheaper in the long run. Another recommendation though is to have the output solenoid replaced as the engine light (BMW "VANOS"/timing term) may come on. I had my pump/belt/and tensioner replaced with oem parts at my local shop for $1,195.00. I had the solenoid replaced for $180.00 at the dealer because at 75,000 miles my check engine light came on. I motored my 2008 with my 2012 to the dealer for its first scheduled maintenance, so, I had the solenoid replaced there becasue it was convenient. Good luck.
Old Mar 29, 2013 | 05:59 PM
yyj3869's Avatar
yyj3869
Did u have idle problem also?
Old Mar 30, 2013 | 04:59 AM
mini coop's Avatar
mini coop
Somewhat.....there was a knocking noise at idle that would last about 20 seconds and would then go away.
Old Mar 30, 2013 | 02:11 PM
yyj3869's Avatar
yyj3869
omg... early this morning I went to Mini cooper specialist (Mini World) in Sun valley,CA to get water pump fixed. It took about 3-4 hours and they checked temperature after they replaced water pump and that was okay. then I came back home and popped the hood and checked coolant level. it was below the minimum....wth... I called them and ask why this is happening. they told me to bring it in on monday....omg......what am i supposed to do!!! I can't drive now...
Old Mar 30, 2013 | 04:22 PM
M'Cooper's Avatar
M'Cooper
It could have just not been fully bleed after the fix. Air may have cane out after the drive or after it sat and cooled. A top off of coolant may be all it needs.
Old Mar 30, 2013 | 06:56 PM
yyj3869's Avatar
yyj3869
thanks for the reply. It might be but I think I will go back there on monday and let them check it again...
Old Mar 31, 2013 | 08:19 AM
yyj3869's Avatar
yyj3869
Old Mar 31, 2013 | 03:40 PM
yyj3869's Avatar
yyj3869
today I test drove my car and heard something odd noise from the hood on the passenser side. I heard vibration on the windshield when I accelerated and noise was on and off. I didn't have that prblem before I replace the water pump...
Old Mar 31, 2013 | 08:19 PM
kyoo's Avatar
kyoo
what was the idle problem? anything like idle hunting at cold engine temps?
Old Apr 1, 2013 | 08:29 PM
yyj3869's Avatar
yyj3869
I went to service shop where I have water pump fixed and noticed that coolant was leaking on the surface and let them check it again. they jacked up the car and looked at where the coolant leak comes out from. they showed me that thermostat is leaking.....I was really mad that they didn't check the thermostat after they fixed water pump..I felt really suspicious......
Old Apr 1, 2013 | 09:23 PM
ZippyNH's Avatar
ZippyNH
Did you tell them "i have a leak, someplace said it might be the waterpump.." or did you say i need a new waterpump...if so they just did it as " customer requests"...no diagnosing.
it would NOT be common for the thermostat to leak and/or the waterpump at 80k miles...so i kinda doubt unneeded work was done...
sounds like you are kinda wound up....relax...it is just a car.
Old Apr 3, 2013 | 01:48 PM
yyj3869's Avatar
yyj3869
waterpump was needed to be fixed. Dealer diagnosed my car and found that water pump leaks. thats why i took it to there. and i asked them to check if thermostat is okay and they checked it is okay first time and now they are saying thermostat is also problem.
Old Apr 3, 2013 | 03:10 PM
TheBigNewt's Avatar
TheBigNewt
Sounds like you got (radiator) hosed .
20
Jul 1, 2025 01:41 PM
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
kwijmbo
Aug 5, 2015 09:00 PM
