R56 Doesn't smell good
Doesn't smell good
On hot summer day when I put the A/C on my 2008 S, I smell anti freeze coolant and only when a/c is on. In any other mode no smell.
Any idea what's happening?
Coolant system should be flushed and filled every 3 years or 30K miles. One reason is for preservation of the headgasket and other related components to keep them supple and working effectively.
Could just be a bad hose connection, thermostat, water pump leaking onto hot parts causing odor in the cabin.
Subscribing for interest. My car smells a little "musty" when the AC is on full blast on a hot day as well. I just had the coolant flushed when I bought the car two years and 20,000KM ago.
The AC evaporator can easily get moldy and gross. Dark, cold, and wet conditions are a perfect breeding ground for nasty ****. The dealer has an evaporator cleaning service available.
And any auto parts store has a disinfectant spray you can use to help kill the gunk on it, my car is getting funky too. The spray does work! Give that a try if replacing cabin filter didn't work for you, also make sure you get the better charcoal carbon filter.
Yea pretty easy. All you need to do is pop open a box underneath the glove compartment and pull out the filter. I dont think you need any tools. There's a how to video on youtube somwhere.
Kimolaoha
Dec 5, 2020 09:32 PM
Powershift
Aug 16, 2015 05:14 PM
