R56 P0171 engine code on 2012 MCS...Help??
Old Aug 20, 2012 | 09:00 PM
2MIN1's Avatar
2MIN1
Hey guys,
I have a 2012 MCS with 2,800 miles on it. I have now had the p0171 code pop up twice now (reading with my scangauge ii) it first came up about 2 wks after I installed a Forge intercooler, Sprint Booster, and K&N filter (around 1,800 miles). I retightend all the hoses and cleared the code. It's been off now for a month, then all the sudden tonight it comes back on. The car has no loss of power, it does have an ever so slight shutter at idle that can be felt though the brake peddle. Can you guys offer any insight??
Thanks in advance!
Old Aug 20, 2012 | 09:09 PM
bluefox280's Avatar
bluefox280
* MINI DTC P0171 (0x2BC0) - System Too Lean (Bank 1)
Well, in the midst of your modifications, the ECU is now seeing a too lean fuel combustion by reading your pre-cat O2 sensor.
I would remove the air intake first, and drive around with the OEM airbox installed and see if the code returns.
- Erik
Old Aug 21, 2012 | 05:31 PM
2MIN1's Avatar
2MIN1
Thanks. I do have the OEM airbox, just an K&N panel filter. But I will try to replace the factory filter and see if that helps. When it happened the first time I just thought I had it tightened up the hoses well enough and maybe I had a small air leak. After resetting the light, it has not yet come back on, but ive only put about 10 miles on it since.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
David.R53
Sep 1, 2015 06:49 PM
PSIChocolate
Aug 13, 2015 12:46 PM
