R56 What happened to my pops and burbles?
Old Aug 17, 2012 | 07:38 AM
Erhan's Avatar
Erhan
It's gone! I drive in sport mode all the time because the throttle response helps with heel&toe, and I LOVE the pops and burbles.
But since yesterday, pops and burbles disappeared... Sport mode button still is making the steering heavier, and throttle sharper... This is so weird!
Anyone with similar experience?
ps: this is a 2011 Cooper S.
Old Aug 17, 2012 | 08:36 AM
ellinara's Avatar
ellinara
Just a thought but it might be fuel quality. Try using a higher grade maybe that will do the trick?
Old Aug 17, 2012 | 08:38 AM
Erhan's Avatar
Erhan
Thanks for the reply. I pretty much always get my fuel from the same Chevron station by my office, and I always use the highest grade.
But maybe they had bad fuel in my last fill?
Old Aug 17, 2012 | 09:16 AM
muzak's Avatar
muzak
Was your car up to operating temps? The way the p&b works, it drops unburnt fuel onto the hot exhaust manifold, as far as I understand it.
Old Aug 17, 2012 | 09:18 AM
Erhan's Avatar
Erhan
The car was at operating temps. And I think you're right about how the p&b works.
Old Aug 17, 2012 | 09:32 AM
Spridget's Avatar
Spridget
http://www.gas-x.com/
Spridget
Old Aug 17, 2012 | 10:34 AM
JoanieB's Avatar
JoanieB
Maybe your car just isn't feeling talkative today.
Old Aug 17, 2012 | 11:19 AM
CK Williams's Avatar
CK Williams
I've noticed that mine is variable with some days being louder than others. I haven't tracked it yet to see if there is a pattern.
Old Aug 17, 2012 | 03:04 PM
k_h_d's Avatar
k_h_d
Ambient temperature effects my pops & burbles. In about 70 - 80 degrees there are times where I will get an extremely loud pop, almost a backfire. In the high 80's and 90's its usually justs the standard pops.
Old Aug 17, 2012 | 03:35 PM
Capt_bj's Avatar
Capt_bj
a new MINI is loaded with burbles and pops
just so many
you used yours up
a classic has an unlimited amount
Old Aug 17, 2012 | 06:55 PM
Erhan's Avatar
Erhan
Well, I got my pops back, shortly. Then I got a check engine light. Sweet.
Old Aug 18, 2012 | 10:21 AM
Melangell's Avatar
Melangell
How I wish I could rid The Dread Pirate of the backfire noises!
Old Aug 18, 2012 | 11:06 AM
ItalianJobSeattle's Avatar
ItalianJobSeattle
Dunno why but when the AC is on mine doesn't pops, when is worm(70 and up) doesn't pops..
meh
Old Aug 18, 2012 | 02:05 PM
automan21's Avatar
automan21
Love the P&B's. Once in a blue I will get a backfire like pop.
Old Aug 18, 2012 | 02:06 PM
automan21's Avatar
automan21
Did the OP get the codes checked to see what the issue was?
Old Oct 11, 2012 | 08:39 AM
MiniCrisis's Avatar
MiniCrisis
well mine used to pop and gurgle in the morn cold start but after the sensor bulletin stuff was done it won't accelerate gurgle and pop like prior. now it only does it at temp and when traveling. They say nothing was changed
rob&JCW
Feb 21, 2018 02:41 PM
embiggenedmini
Oct 15, 2015 12:36 PM
rob&JCW
Oct 9, 2015 11:12 AM
bneer
Sep 20, 2015 11:29 AM
MiniChick82
Sep 16, 2015 02:56 PM
