R56 Inter cooler muffler delete-Check engine light?
Old Aug 31, 2012 | 09:35 PM
Jdblown03's Avatar
Jdblown03
After doing the intercooler muffler delete with an 8" section of hose the hose blew loose after the first run from not being tightened enough. After driving back home a mile and making the repair a check engine light came on and stayed on. Any ideas and how do I get it off?
Old Sep 1, 2012 | 01:18 PM
ThePro's Avatar
ThePro
Is it just a code or are there drivability issues?
Is the light stuck on?
Do you have access to a code reader?
You could try the battery reset method, (future posters may deny its use, I have no comment, but it's worth a try)
I took mine out without any codes or issues.
Though when it came off, it could set a real code that may have to be cleared with a reader.
Old Sep 2, 2012 | 07:09 AM
bluefox280's Avatar
bluefox280
Grab hold of an approved MINI-protocol scanner, and remove the stored fault code.
NO, removing power from the ECU does not clear out faults as the codes are stored in the ECU's non-volatile memory.
You must use a scanner to correct clear any stored codes from the ECU.
- Erik
Old Sep 2, 2012 | 07:18 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
You will need a code reader to read and clear the codes. If the car is driving fine, it most likely related to the leak at install.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Sep 2, 2012 | 08:09 AM
Jdblown03's Avatar
Jdblown03
Got ahold of a scanner and reset.Thanks
Etrain
16
Aug 5, 2024 04:37 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
bleonard1401
Aug 11, 2015 02:53 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
