R56 CEL code P0128, bad thermostat?
Old Sep 6, 2012 | 05:09 PM
Mindspin311's Avatar
Mindspin311
My CEL came on today, had the code read at a local parts store, P0128.
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
I can only imagine that this means my thermostat has failed in the open position and needs to be replaced.
Thoughts?
Old Sep 6, 2012 | 05:12 PM
bluefox280's Avatar
bluefox280
That, or the integrated Coolant Temperature Sensor (CTS) is faulty.
Either way, you're looking at a thermostat housing replacement.
- Erik
Old Sep 6, 2012 | 05:15 PM
Mindspin311
Is that the only coolant temp sensor on the motor?
A few month back, I had a coolant temp sensor replaced by WMW, but there is no CEL for it. The fans were constantly running hard, and it was determined that the sensor was running high. But, there was never mention of the tstat and housing being replaced as well.
The part cost for the sensor was only $20, the housing and whatnot appears to run around $100 or so.
Old Sep 6, 2012 | 05:27 PM
bluefox280's Avatar
bluefox280
Yes, it's on the thermostat housing.
However, I misspoke; the thermostat can be purchased separate from the Coolant Temperature Sensor (CTS).
- Erik
Old Sep 6, 2012 | 05:57 PM
Mindspin311
Yea, looks like it can be separate. Item #5 was probably what WMW replaced a few months back. Pricing looks similar too.
So either that sensor has failed, or the tstat itself?
Old Sep 7, 2012 | 12:19 PM
Mindspin311
Going to the dealer on Monday. Curious to see if its the tstat or temp sensor.
Old Sep 10, 2012 | 12:05 PM
Mindspin311
It was indeed the tstat, should have the car back this evening.
matthewbrakeii
May 13, 2021 08:39 AM
HaveATank
Sep 4, 2015 08:04 AM
David.R53
Sep 1, 2015 06:49 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
