R56 Bentley manual lets me down!
I own a 2007 Mini S and need to replace my LOWER grille due to some damage. I have the Bentley Service Manual for my car, however. there is no info on changing the lower portion of the grille. There's info on the top portion (called radiator grill), but the info on the bottom portion is absent for some reason
. What is the process to perform this task? Do I need to remove the bottom of the front bumper cover to get at the lower grille attachment points? Any info will be greatly appreciated. Thanks in advance for your helpful posts. Ron
When I do grill and IC work, I usually take off the bumper. Not sure if that is necessary but it gives me lots of space to work with.
See helix13.com for their instructions to remove the front bumper (for IC install but don't take off the IC). Not too difficult and it took less than 2 hours the first time I did it.
The bumper must be removed. Look at bumper instructions in the Bentley, and the grill instructions will probably be in that section as well.
Meanwhile, attached are instructions from the BMW TIS manual.
Thanks guys, that really helps. I appreciate all the info and help. Have a great week everyone. Ron
I have done it 4-5 times already and it still takes me longer than 5 minutes. In fact it takes me more than that that jack up the car and put the front on jack stands and take the front wheels off. This could be Olympic and World record, just keeping with this week's theme.
You do that for taking the bumper off? It shouldn't be necessary.
Maybe we can see a live feed of you doing that in 5 minutes. I bet I could learn a few tricks.
elverado
Jan 18, 2022 02:51 AM
