PDA
View Full Version : Navigation & Audio
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16
  1. Navigation & Audio Finished sub install (Polk/Alpine)
  2. Navigation & Audio Help: New Garmin mount installation question...
  3. Navigation & Audio Sub Enclosure?
  4. Navigation & Audio Random Song Play from iPod
  5. Navigation & Audio BT, aux audio and usb died
  6. Navigation & Audio 2011 audio muted at startup?
  7. Navigation & Audio NewMiniStuff bluetooth install instructions?
  8. Navigation & Audio yep, advice on stereo upgrade again
  9. Navigation & Audio Right side trunk ground point?
  10. Navigation & Audio iPhone mount using a dock - Any Options?
  11. Navigation & Audio HK Radio
  12. Navigation & Audio Iphone 4 and 08 Cooper Clubman USB issue??
  13. Navigation & Audio Nab cd stuck
  14. Navigation & Audio MINI Connected FAQ's
  15. Navigation & Audio Question for MINI Connected owners
  16. Navigation & Audio 2008 Clubman S Nav Volume
  17. Navigation & Audio IPOD icon not showing up when iPhone is connected
  18. Navigation & Audio IPOD icon won't show up when I plug in my iPhone
  19. Navigation & Audio ProClip owners - questions
  20. Navigation & Audio Tapping into x9331 on a Hifi system
  21. Navigation & Audio Replacing Speakers...Replace Wires Too?
  22. Navigation & Audio 2011's with Connect or Nav- working correctly?
  23. Navigation & Audio HTC Evo and bluetooth
  24. Navigation & Audio Upper Speaker
  25. Navigation & Audio x9331 wire gauge - vampire tap sizing
  26. Navigation & Audio R56 Stereo Upgrade Project(looks like it is possible now)
  27. Navigation & Audio Nav/CONNECTED/RADIO Manuals
  28. Navigation & Audio Conflict between Comfort Access and Nav?
  29. Navigation & Audio Do I need the IPOD Interface if I have the USB/Aux Inputs?
  30. Navigation & Audio Upgrading to Harman\Kardon sound system
  31. Navigation & Audio Micro Sized Computer
  32. Navigation & Audio Has anyone installed a Sound Ordnance B-8PT subwoofer?
  33. Navigation & Audio Nav Upgrade
  34. Navigation & Audio Underseat holes
  35. Navigation & Audio Door Lock Pin won't go up or down
  36. Navigation & Audio Bypassing the factory speaker wiring on an '09 MCS
  37. Navigation & Audio Interesting iPod sound quality quirk
  38. Navigation & Audio PAC LC-2 remote volume control
  39. Navigation & Audio iPhone 4 and MINI Cooper 2011 queries
  40. Navigation & Audio Custom Sub box
  41. Navigation & Audio Re-Q, does it make a noticeable difference?
  42. Navigation & Audio Ipod/HK weirdness
  43. Navigation & Audio Got the mud out of my car
  44. Navigation & Audio My little SQ project
  45. Navigation & Audio AUX not recognized
  46. Navigation & Audio How did you upgrade your Sound System?
  47. Navigation & Audio OEM Power Supply For GPS
  48. Navigation & Audio Best suggestion for rarely used iphone 4 holder/dock?
  49. Navigation & Audio MCS 2011 R57 Cabrio Sound system Upgrade
  50. Navigation & Audio A truly great Garmin GPS mounting bracket
  51. Navigation & Audio How to run wires for ipod in armrest
  52. Navigation & Audio 2008 HIFI amplifier upgrade
  53. Navigation & Audio Any Mobile Ham Radio installs???
  54. Navigation & Audio Took a chance on some ebay ipod cable...
  55. Navigation & Audio playing music video
  56. Navigation & Audio Bluetooth.....save your money
  57. Navigation & Audio Radio problems
  58. Navigation & Audio Using HERTZ Speakers in the 2009 R57 non-hifi with Sat Nav
  59. Navigation & Audio does anyone have problems with Garmin???
  60. Navigation & Audio How to re-use Garmin portable friction mount?
  61. Navigation & Audio Mini-connected any advantage?
  62. Navigation & Audio Need iPod help
  63. Navigation & Audio Samsung Transform M920 Bluetooth Pairing
  64. Navigation & Audio Audio Problem: CD stuck in play mode, no other buttons work
  65. Navigation & Audio Does anyone have their iPad working with the USB connector?
  66. Navigation & Audio Longer Y-Cable for 2010
  67. Navigation & Audio Aux hum
  68. Navigation & Audio R55 HiFi amp wiring
  69. Navigation & Audio Adding Sirius/Ipod/Bluetooth to OEM Stereo?
  70. Navigation & Audio 2008 MCS Stereo Question
  71. Navigation & Audio Double DIN Install
  72. Navigation & Audio Factory Sirius Radio?
  73. Navigation & Audio Let Me See Your Gps/nav Set Up!!!!
  74. Navigation & Audio weird radio behavior
  75. Navigation & Audio New 2011 Nav
  76. Navigation & Audio Amp Turn On Found
  77. Navigation & Audio Radio Question
  78. Navigation & Audio IPhone 4 Armrest insert
  79. Navigation & Audio built in gps
  80. Navigation & Audio 2101 MCS none hifi system USB question
  81. Navigation & Audio re-Q 5 question
  82. Navigation & Audio Garmin Nuvi Retrofit kit install with Pictures X9002 location
  83. Navigation & Audio IBOC/DAB reciever disconnect
  84. Navigation & Audio Newb Question
  85. Navigation & Audio Kenwood KAC-9104D 900W Class D Mono Amplifier
  86. Navigation & Audio ::OutMotoring:: check out the new R56 Sub Box + Amp
  87. Navigation & Audio Kensington iPHONE cable (charge and high quality audio)
  88. Navigation & Audio AUX-in missing on my Radio Wave CD
  89. Navigation & Audio Equalizer (or CleanSweep?) with a recent HK upgrade?
  90. Navigation & Audio PAC SWI-JAC - howto?
  91. Navigation & Audio Mirror Switch R56 Removal Help
  92. Navigation & Audio Skipping Stations 2010 HK Radio
  93. Navigation & Audio 2010 (late 09) HU & USB
  94. Navigation & Audio 2011 RDS vs NAV
  95. Navigation & Audio Is a 600 watt amp too much for the stock battery and alt?
  96. Navigation & Audio HD Radio IBOC Retrofit Success
  97. Navigation & Audio Another amp question, simple
  98. Navigation & Audio Alpine Sound System Retrofit
  99. Navigation & Audio Any way to decrease wind noise for Bluetooth?
  100. Navigation & Audio Hiding iphone/audio cables behind the dashboard
  101. Navigation & Audio Can I mute my MINI?
  102. Navigation & Audio Amplifier Locations
  103. Navigation & Audio Alpine or Integral Audio Upgrade
  104. Navigation & Audio Don't like 100 Hz cutoff, try 120 Hz cutoff ...
  105. Navigation & Audio Any R56 owners with Harmon Kardon upgrade in the Tucson area?
  106. Navigation & Audio Plug and Play speakers?
  107. Navigation & Audio Bluetooth added to 07 MCS - Great Success!!!
  108. Navigation & Audio Gong volume with nav on a 2009 MCS?
  109. Navigation & Audio Max Speed Alert on Nav screen
  110. Navigation & Audio Toggle On / Off HD Radio?
  111. Navigation & Audio Upgrading Hifi - 6 speakers in front vs 4
  112. Navigation & Audio Car stereo and on board computer
  113. Navigation & Audio 07 S...Bluetooth stopped working?
  114. Navigation & Audio R56 Speaker swap
  115. Navigation & Audio What iPods will charge with the MINI iPod interface?
  116. Navigation & Audio Harmon/Kardon Equalizer Settings - What are you using?
  117. Navigation & Audio 2nd Generation Nav Model??
  118. Navigation & Audio Amp under the seat problem?
  119. Navigation & Audio The newest generation MINI GPS mount w/ a Garmin 550
  120. Navigation & Audio Engine Noise! (High Pitched Wining After Audio Upgrade) Please help!
  121. Navigation & Audio Cheap Ipad Mount
  122. Navigation & Audio How to install Sirius factory oem kit.
  123. Navigation & Audio Differences between Hi-fi 2011 vs 2009\10
  124. Navigation & Audio mObridge and Audison BitOne?
  125. Navigation & Audio Amp install questions
  126. Navigation & Audio Anyone fitting or going to fit a MS-8?
  127. Navigation & Audio MB Quart 12" flat/shallow sub, any good?
  128. Navigation & Audio subwoofer install - cut out question? please help..
  129. Navigation & Audio Garmin 360 factory mount removal
  130. Navigation & Audio Stock Speaker Replacement/Upgrade Questions
  131. Navigation & Audio new NAN - Mini 2011
  132. Navigation & Audio Ok guys, which speakers to replace on front doors?
  133. Navigation & Audio Subwoofer working sporadically
  134. Navigation & Audio Head Unit Upgrade
  135. Navigation & Audio iPhone 3G + iOS 4.1 Yippie!
  136. Navigation & Audio Loud "POP" sound when starting up the car
  137. Navigation & Audio updated speakers..
  138. Navigation & Audio Has anyone installed the Dice Mediabridge
  139. Navigation & Audio Power Issue Powered Sub install
  140. Navigation & Audio Dude, it's all about the wattage....
  141. Navigation & Audio About had it with my system
  142. Navigation & Audio Quick USB/AUX question
  143. Navigation & Audio Amp question
  144. Navigation & Audio camera alerts
  145. Navigation & Audio Voice Phone Book
  146. Navigation & Audio Ipod integration issue
  147. Navigation & Audio Stereo upgrade in a leased Mini
  148. Navigation & Audio harmon upgraded stereo
  149. Navigation & Audio Mini Connected Stereo Questions- How many iPods and where?
  150. Navigation & Audio Garmin recall
  151. Navigation & Audio Y-Cable AUX split / RCA Input MCS 2010 HK Audio
  152. Navigation & Audio cheap gps mount
  153. Navigation & Audio My Mini Full Newbie Upgrade + Install
  154. Navigation & Audio Finally: A solution to that missing amp remote signal source?
  155. Navigation & Audio Ipod Help
  156. Navigation & Audio Garmin EcoRoute
  157. Navigation & Audio New head unit on R53 with H/K upgrade...
  158. Navigation & Audio phone will forget to pair with car
  159. Navigation & Audio Bluetooth call quality fixed
  160. Navigation & Audio My (very) Stealth Valentine 1 Install (w/video)
  161. Navigation & Audio GPS with way points?
  162. Navigation & Audio Droid paired but not connected!
  163. Navigation & Audio New Mini & cannot connect bluetooth!
  164. Navigation & Audio my Alpine (audio upgrade) tweeter developed a dent
  165. Navigation & Audio Navigation DVD
  166. Navigation & Audio Problem with Bluetooth and Blackberry Curve
  167. Navigation & Audio XM Problem
  168. Navigation & Audio Pro-Clip for iPod.iPhone question
  169. Navigation & Audio iPhone 4 Connectivity Issue
  170. Navigation & Audio r56 dvd screen rebooting
  171. Navigation & Audio Radio Turns On Without Key, Normal With Clubman?
  172. Navigation & Audio Thoughts on a reasonable audio upgrade
  173. Navigation & Audio Very very short antenna
  174. Navigation & Audio Mission Control mp3s
  175. Navigation & Audio HK audio system different? (05, 06, etc) [pins/amp placement/etc]
  176. Navigation & Audio call waiting on bluetooth? Is there a button?
  177. Navigation & Audio HELP! iPhone 3GS suddenly won't play '10 MC
  178. Navigation & Audio Factory bluetooth microphone with Parrot setup?
  179. Navigation & Audio Smartphone prep suddenly not recognizing iPhone (3G)
  180. Navigation & Audio Help with Sirius radio install.
  181. Navigation & Audio Activating Pandora while phone charges!
  182. Navigation & Audio iPod touch issues
  183. Navigation & Audio Sirius Hardwire install
  184. Navigation & Audio What cable for Droid X??
  185. Navigation & Audio R56: No audio from any of the audio sources all of a sudden.
  186. Navigation & Audio Rear Speaker fubar on HK
  187. Navigation & Audio GPS/Cell Phone Mount for the Cheap-Minded
  188. Navigation & Audio Blackberry BT Synch issues
  189. Navigation & Audio Anyone install a MS-8 in the Mini?
  190. Navigation & Audio Replacing the deck
  191. Navigation & Audio On my 3rd iphone 4... some interesting workings in mini.
  192. Navigation & Audio 2010 Cab with Bluetooth with factorry Nav problems
  193. Navigation & Audio New Mini Owner - XM question
  194. Navigation & Audio Another Bluetooth Question
  195. Navigation & Audio MINI key look alike USB
  196. Navigation & Audio diy oem bluetooth install??
  197. Navigation & Audio Wire clutter
  198. Navigation & Audio What is your thoughts - Infinity Kappa 60.9cs
  199. Navigation & Audio Help setting up Ipod
  200. Navigation & Audio Want to Replace but can't find Upper Speakers for replacement
  201. Navigation & Audio Bluetooth question
  202. Navigation & Audio How can I Use My Steering Wheels Controls for My iPod
  203. Navigation & Audio When using Sirus in Aux plug -- Bluetooth phone won't work
  204. Navigation & Audio Most system?
  205. Navigation & Audio Phatnoise in R56?
  206. Navigation & Audio iPhone 4 with Bluetoooth...or not so much
  207. Navigation & Audio Options question...
  208. Navigation & Audio Upgrade '09 Nav to Mini Connected?
  209. Navigation & Audio Didn't see that coming....USB Y cable works perfect for iphone 4
  210. Navigation & Audio The Mini Cooper road...
  211. Navigation & Audio How much $$$ to Install 6 Disc CD Changer?
  212. Navigation & Audio iTouch mounting bracket from Cravenspeed
  213. Navigation & Audio iPod not charging... revisited
  214. Navigation & Audio Factory iPod interface
  215. Navigation & Audio redoing my trunk for a pair of Dayton10's...
  216. Navigation & Audio I just want a simple XM radio
  217. Navigation & Audio Aftermarket HeadUnit - I took the plunge
  218. Navigation & Audio Speaker system
  219. Navigation & Audio Modding of factory Nav screen??
  220. Navigation & Audio IPhone 4 Question
  221. Navigation & Audio 07 Cooper S radio not working
  222. Navigation & Audio I have a few questions about my future stereo setup (alpine pdx-5)
  223. Navigation & Audio 2010 Cooper S and HK Option
  224. Navigation & Audio Did I get the right sound system?
  225. Navigation & Audio Did I get the right stereo system?
  226. Navigation & Audio navigation
  227. Navigation & Audio This has likely been discovered already, but... (Pandora related)
  228. Navigation & Audio Black A-Pillars w/tweeter mount for R57 - do they exist?
  229. Navigation & Audio Looking for a cell phone holder with Nuvi ball receiver
  230. Navigation & Audio ipod adapter issue
  231. Navigation & Audio iPad covers
  232. Navigation & Audio 2010 HK Stereo Upgrade questions
  233. Navigation & Audio New Garmin 295W in 2009 R57 W/pic
  234. Navigation & Audio Super STEALTHY radar DETECTOR installs (GEN2)?
  235. Navigation & Audio My x9331 Harness Failed!
  236. Navigation & Audio R57 Cooper S Convertible
  237. Navigation & Audio My 2010 Mini Cooper Style/Performance/Sound Build, its going to be a long one
  238. Navigation & Audio Bluetooth sucks! what to do!
  239. Navigation & Audio Dash kit ordered!! double din !!
  240. Navigation & Audio 2010 Mini S Harmon Kardon Problem
  241. Navigation & Audio Gong Adjustment Oddity...?
  242. Navigation & Audio Pioneer Introduces Pandora Radio Integration - iPhone App [VIDEO & PICS]
  243. Navigation & Audio Stereo Dash Kits?
  244. Navigation & Audio Custom A Pillars ?...Pics?
  245. Navigation & Audio Ipod-Shuffle songs?
  246. Navigation & Audio 2010 MCS at shop today having JL Audio components installed
  247. Navigation & Audio CD player question
  248. Navigation & Audio x9331 connector - the same for Hi-Fi and base systems?
  249. Navigation & Audio Quick Sanity Check on a Sirius Install from you experts out there
  250. Navigation & Audio Replaced OEM CD player, lost bluetooth & USB...
