Navigation & Audio Amp under the seat problem?
Old Sep 21, 2010 | 11:39 AM
djdraddy's Avatar
djdraddy
I just got a call from the shop doing the amp install on my 2010 clubman. The say they are having difficulty fitting the Amp under the seat because there is a crossbar attached to the slider mechanism that drops down and interferes with the amp in this placement. Is anyone familiar with this and or does anyone know a work around for this problem?
Old Sep 21, 2010 | 01:51 PM
djdraddy's Avatar
djdraddy
Never mind. Figured it out myself.
Old Sep 21, 2010 | 10:16 PM
Maurtis's Avatar
Maurtis
What was the resolution?
Old Sep 21, 2010 | 10:32 PM
aafflyer's Avatar
aafflyer
Unless it was a very tall amp, my guess is that they tried to put it directly under the seat and not in the "compartment" under the seat after taking off the plastic plate.
Old Sep 21, 2010 | 11:25 PM
thirdraildesignlab's Avatar
thirdraildesignlab
So what system are they putting in for you?
Old Sep 21, 2010 | 11:37 PM
djdraddy's Avatar
djdraddy
Focal Polyglas 165V3E 3 way component system with a Kenwood KAC-7205 Amp.
Old Nov 28, 2010 | 12:16 PM
panerai's Avatar
panerai
I know I saw a thread with the size of the under seat compartment, but I've search and searched. But I can not find it :(
What size is the compartment?
Old Nov 28, 2010 | 01:13 PM
Derepente's Avatar
Derepente
Check the sticky on the R56 Thread: Post 756 in the Famously fact filled thread
However, if you get exact measurements, please post them and what model and year your MINI is. Thanks.
Old Nov 28, 2010 | 01:45 PM
panerai's Avatar
panerai
Excellent!
Will do when I fit my new amp!
Old Nov 28, 2010 | 03:04 PM
aafflyer's Avatar
aafflyer
The styrofoam piece that came out of my 2009 MCS is roughly 13" X 10 3/8" (maybe 10 1/2"). The height down there is roughly 2 1/2" high. Of course, getting wires connected to the amp will reduce the space the amp can use.
Old Nov 28, 2010 | 03:24 PM
panerai's Avatar
panerai
Removing the seat will be my first time for that as well, should be pretty straight forward if I've read correctly
Mini'mon
Aug 26, 2015 01:02 PM
Zettinger
Aug 25, 2015 04:04 PM
bseiden
Aug 15, 2015 10:16 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
