Navigation & Audio 2008 HIFI amplifier upgrade
I have a 2008 Mini S with the HIFI upgrade, I am looking at changing out the factory amplifier with a JL Audio XD700/5 and adding a sub. However, I heard that I should not replace the factory amplifier because of the mini's computer. Is this true?
Does any one have any advice on replacing the factory amplifier. What problems will I have if I replace the amp? Or should I add a second amp for the sub? If so, how would I do that?
I know the XD700/5 will fit where my factory amplifier is, does anyone have any other amp recommendations that will fit in the same location?
Thanks,
Any advice is needed.
Thanks,
The factory amplifier must remain in the car or at least be reconnected in order for the dealer to perform any upgrades. The factory amp has a connection to the K-CAN bus and the computer knows it is supposed to be there.
If you are planning on upgrading all of your speakers then a 5ch amp would be a good choice. If you are planning on leaving any of the factory speakers in place you will want to leave them connected to the HiFi amp since the crossovers are all built into the amp - only the tweeters have any passive component frequency protection.
EDIT: On second thought, it doesn't make any sense that the dealer wouldn't be able to program changes to installed modules - that's exactly what they do for any dealer-installed option. And they must be able to change the amp option code, otherwise they wouldn't be able to upgrade from HIFI to the new HK. Still, one of the tech's told me for certain that he personally had to re-install a HIFI amp in order to do install bluetooth.
Does that jive with your information?
on
You are absolutely correct!
NCS Expert is the probably one of the only few ways to change the Vehicle Order. ISTA/P doesn't do it, you can only add "official" retrofits to the vehicle, but cannot remove them. I am sure the dealer does not have access to NCS, even the regional techs probably don't have the capability.
The Vehicle Order stored in the car is very detailed, including the interior options and color of the car.
If you are curious check out my car's VO here:
http://forums.bimmerforums.com/forum...6&postcount=11
on
Well, I never got to the retrofit screen of ISTA/P (some sort of issue with my J2534 cable) on my car so I wasn't able to see if HK upgrade was an official upgrade.
I think the ISTA/P is dummed down, but since ISTA/P is updated very frequently and they add new options and features regularly. ISTA/P includes the updated firmware for modules. For theoretical example, to really retrofit an HK amp from the HIFI amp (I discovered that the manufacturer of the amp is HarmonKardon, at least that is what it reports) would require a firmware update to the head unit radio module to include new the new AMP VO option code and DSP filter settings required. So it is possible it could become an official retrofit.
Unfortunately, I just did not get very far in ISTA/P to give a real answer about the capabilities.
embiggenedmini
10-15-2015 12:36 PM
