Navigation & Audio IBOC/DAB reciever disconnect
Old Nov 2, 2010 | 11:58 AM
perro's Avatar
perro
Hi,
Can I unplug IBOC/DAB reciever (under the steering coloumn)? Will there be any errors or disfunctionallities?
Thanks.
Peter
Old Nov 2, 2010 | 01:17 PM
strobeyprobey's Avatar
strobeyprobey
In the R56 it is in the boot on the right hand side behind the cover, is your car the R57? I can't imagine the tuner would fit under the column.
If you unplug the IBOC you will have no radio tuner (no FM or AM).
You would have to reconnect the antenna lead that goes to the head unit and then reprogram the radio with NCS Expert to enable the head unit radio.
Old Nov 3, 2010 | 01:42 AM
perro's Avatar
perro
Hm... So what is then the thing under the dash between the steering column and gas pedal?
Thanks.
Old Nov 3, 2010 | 09:44 AM
strobeyprobey
That is A7000a, the Transmission control module. You *may* not want to remove that.
Old Nov 3, 2010 | 10:09 AM
perro's Avatar
perro
Yeah...
PsychoRallye
21
Feb 17, 2019 06:08 AM
Supertractor3
Apr 7, 2017 11:16 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
wildwestrider
Sep 6, 2015 06:18 PM
