Navigation & Audio ::OutMotoring:: check out the new R56 Sub Box + Amp
Old Nov 1, 2010 | 11:28 AM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
We are very excited to announce that we are now selling the FactoryFIT Amp and Sub box from Integral Audio. If you've struggled with how to get good bass out of your 'stock' system without completely giving up storage space in the back of your MINI this is the perfect solution.
If you have not seen this yet it is well worth your time...
http://www.outmotoring.com/mini-coop...x_and_amp.html
Lets face it, the stock and Harmon Kardon stereos flat our suck bad. Upgrading to the HK system is similar to taking a 1,500.00 chunk of $100's and tossing it in the trash. You may get a LITTLE bit more definition in the mids (usually from 3"-6" speakers) and highs (tweeters, etc) but still the bass bites it big time (slang for being crappy) and for what you pay you should at least get a 8" sub or a set of 6x9's that are in a sealed enclosure...but you don't. While they market it pretty heavily and have a nice "Harmon Kardon" badge. etc, don't believe the hype. While this sub box will not improve on the mids and highs, it will compliment it and offset the weak links in the system.
Basically this is as turn key as it gets when it comes to adding bass emphasis into the MINI Cooper stereo system. Sure, you can get a Bazooka tube or a nasty looking 'sub-in-a-box' from your local Best Buy or whatever but there is a slim chance it will even come close to quality of the bass from this custom bass enclosure. This unit was developed and refined by what I consider to be one of the most knowledgeable people in the MINI audio world and after talking with the owner at length I decided we had to offer this to our customers.
While it will require some work to install it, the benefits are well worth it. One of the first things I did with my personal R56 MINI was to replace all of the speakers and add a similar custom bass box with amp. While I am proud of what I made on a sunny Saturday afternoon it is actually not near as nice as this kit. This kit looks and sounds stunning and is very discrete so it will not draw attention of scoundrels and other thug-losers. By making a 'false floor' they were able to hide a very nice 10" sub as well as a dedicated amp to power it, which in turn keeps a majority of already small trunk space usable.
Here are the juicy specs:
The new Integral Audio FactoryFit™ Model 1100S Subwoofer System for the MINI is finally here! This is the best-sounding, cleanest-installing, most complete subwoofer system they have ever created - suffice to say you will not be disappointed! The improvement in sound quality in both the Standard and HiFi sound systems simply has to be heard to be believed.
Features:
* Integral Audio 10" IASW26-4 Subwoofer by SBAcoustics
* ARC Audio KS125.2 MINI Amplifier delivering 250 Watts
* Complete kit with EVERYTHING you need - including all wiring, connectors, and mounting hardware
* Completely Stealth Installation
* Requires NO cutting of wires!
* Can be removed in under 30 seconds
* Weighs less than 30 lbs
* Works with the Standard and the HiFi stereo systems
* Detailed step-by-step installation instructions (available for download)
The Model 1100S is a complete system including the enclosure, subwoofer, amplifier, and ALL necessary wiring and hardware! It installs in the boot and offers a clean, professional installation with the boot remaining completely usable. The enclosure can be removed in less than 30 seconds if the extra storage space is needed or for reducing weight for the track. Less than 1 cubic foot of boot space is lost, and the entire system weighs a mere 29 lbs! The installation of the Model 1100S requires NO cutting of wires and is appropriate for leased vehicles.
Clean, musical, authoritative bass is delivered by the new Integral Audio IASW26-4 10" subwoofer designed by SBAcoustics. The IASW26-4 is powered by the legendary Robert Zeff-designed ARC Audio KS125.2 MINI. The lightweight enclosure cabinet features extensive internal bracing and custom mounting hardware. The completely stealth look is acheived with a false floor panel with a heavy-guage steel grill that is completely covered with acoustically-transparent carpet that matches your MINI's interior. The false floor is designed to create a level load floor in the boot with seats folded down and allows the subwoofer to operate normally even if the boot is FULLY LOADED!
The Model 1100S has been carefully engineered as a complete system specifically for the MINI, with each component carefully designed with the other components and the vehicle in mind. You can't achieve this level of sound quality otherwise - the flat frequency response and clean transients of the 1100S simply can't be replicated with off the shelf products.
cut and paste into new browser window for install instructions:
http://www.integralaudio.com/install...tion_Guide.pdf
Zettinger
Aug 25, 2015 04:04 PM
1chaos52
Aug 24, 2015 01:28 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
