PDA
View Full Version : Countryman Wheels, Tires and Brakes
Pages : [1] 2
  1. Using a $50 spare from a Cadillac CTS on my Paceman
  2. F60 Audi wheel fit?
  3. R60 countryman - 215/55/18 or 235/50/18
  4. 4 "Thrill" wheels with Pirelli P7 tires with TPMS sensors
  5. 4 "Thrill" wheels with Pirelli P7 tires with TPMS sensors
  6. Rim fitment JCW 17 to OEM 17 2012 Countryman All4
  7. F60 Countryman wheel and tire combo?
  8. JCW Caliper differences between 2019 and 2020
  9. 🚗 Struggling to Choose the Perfect Countryman Tires
  10. Thank you - results
  11. Are these really 2-piece wheels
  12. Wheel width
  13. Can a fixed tire being moved?
  14. Poll: Which looks better
  15. Tirerack, DiscountTire...mount and balance
  16. New wheels online
  17. Wheel Brands (ASA, Petrol)
  18. Anyone Running the Conti DSW 06 or Michelin Pilot Sport All Season 4
  19. Rear tires larger in rear - R60 2014
  20. Countryman ALL4 JCW 2022 - Brake Upgrade Recommendations
  21. Autocrossing Paceman S 4All
  22. Brake replacement
  23. 215/65R17 Wheels on an F60?
  24. White letter tire Michelin PS4S
  25. Brake Line Question
  26. M7 Tuning Lift kit LT tires
  27. 205/55 R17 Winter Tire Pressure
  28. I finally bought myself some NEW wheels! (quick question)
  29. R60 Brake Bleed Advice
  30. Wheel fitment help
  31. BMW calipers on R60
  32. TPMS reset failure?
  33. JCW calipers on an S Will they fit?
  34. Caliper slide bolts
  35. Non run-flat backup plan
  36. 18. 8.5 inches in the R60 ?
  37. Superspeed Wheels
  38. For sale: 19” Mini Yours wheels and tires and spare tire
  39. Widest tires for stock 2020 CM?
  40. +35 offset????
  41. Alignment specs for new tires? Toe, Camber, Caster
  42. BMW X5 ET48 - will they work?
  43. 15" wheels on R60
  44. 19” jcw wheels for sale!
  45. All Terrain Tires for r60
  46. BMW offset 34
  47. Questions about getting new tires and mounting.
  48. Good run flat tires?
  49. Need stiffer sidewalls... please suggest
  50. F60: 235 50 18's fit but.....
  51. Help me fit a tire
  52. New F60
  53. 18x8.5 (112xET.45) F60
  54. All Terrains for your R60
  55. Are R127 wheels bendy?
  56. RFT vs. non-RFT Conversion Confirmation, Please.
  57. Spare under false floor solution? 2016 Cooper S Countryman All4
  58. I get to buy new tires!
  59. JCW adapters?
  60. Ground Up/Custom F60 Big Brake Upgrade - Brembo/Tesla 6-Caliper Setup
  61. Tires and Wheels
  62. Anybody running 17x8"+35 rims on there countryman?
  63. New wheels with offset 38
  64. Looking forward to 18" TurboFans for Summer
  65. My new to me BBS SR wheels I'll be running in the summer
  66. Stucked after a brake pads service
  67. TPMS compatibility
  68. Ronal Aero 18"
  69. Off Road Tires for Countryman all4
  70. Need wheel opinion
  71. Wheel Paint Touchup
  72. 225/45R19's - can I run them on a 2016 Countryman JCW?
  73. Installed 225/55/17 snow tires + 15mm spacers
  74. Tires
  75. R60 factory wheels for sale.
  76. Stock wheels for sale?
  77. Enkei VR5 Wheels
  78. R60 S ALL4 brake guide needed.
  79. brakes
  80. F60 JCW Winter Tires
  81. Crazy Wide + Small Offset
  82. Nokian WRG4 in Countryman
  83. Countryman all4s Calipers
  84. 235/40 Tire on 19" JCW Double Spokes?
  85. Please help - n00b question on wheel sizes
  86. Tire size question for lifted R60
  87. F/S 19" OEM 19" Masterpiece Wheels and Tires
  88. WTB - 19" Wheels
  89. Looking wheel/tire combo for rally style
  90. Continental ExtremeContact DWS 06 thoughts?
  91. WilWood Or Brembo?
  92. Is it True JCW Sport Brakes Won’t Fit?
  93. JCW Brakes on Countryman S
  94. R60 Factory Tires
  95. Wider tires
  96. New Volks on an F60 JCW
  97. Tirerack- Black Friday
  98. Tpms
  99. Is the Rear Camber adjustable ?
  100. Correct speedometer for tires
  101. 245 45 19 with lift kit is possibile?
  102. 205/60R16 Blizzaks on MODA MD20 wheels
  103. Brake pedal hard what are yours feel like?
  104. 18/ 8.5 et +30
  105. Wheel sizes for 2017 Countryman
  106. Anybody running Nitto's
  107. Wheel options
  108. New wheels and tires
  109. New here: tire suggestions
  110. winter tires
  111. Second clutch issue
  112. Michelin Recommendations?
  113. Do I need new TPMS sensors?
  114. Wheel and tire suggestions?
  115. 2017 Countryman Bolt Pattern?
  116. What offset to get
  117. Tire Specs for 19x8.5 rim
  118. New TPMS
  119. Large diameter tires
  120. Turn off TPMS?
  121. R60 brake DIY question
  122. Tire Chains JCW w 19 inch wheels
  123. New CM owner, Want/Need rims. Thinking of 19's
  124. OZ rims
  125. Small rims,fat tires
  126. R60 wheels and tires on 1.5" drop?
  127. Thinking out loud: BMW brakes on R60?
  128. Sticky thread for R60 wheels?
  129. Countryman All4S PIRELLI CINTURATO P7
  130. TPMS sensor reset timing?
  131. R60 sprint booster
  132. 245/40r19 Tires
  133. What wheels to get?
  134. 2011 ALL4 AWD wheel spacers, Staggering which axle? Why
  135. Winter wheel and tire ?'s
  136. Help me re: brakes
  137. Team Dynamics
  138. Potentially adding new wheels, but...
  139. Possible new rims...
  140. Giving away lifted R60 Countryman Wheels/Tires
  141. Wheel change questions?
  142. Avantgarde 19"
  143. Swapping to lighter wheel?
  144. Going all out
  145. FS: 4x OE Continental ContiProContact SSR
  146. Chains? Spikes? Cable?
  147. BMW Wheels on CM ALL4
  148. Does anyone have studded 205/55/17 tires?
  149. BMW Tire Pressure Sensors
  150. 245/40/18 winter tires on H&R
  151. Mini Countryman R-134 JCW 19" cross spoke wheels for sale.
  152. New wheels!!!
  153. Pirelli Zottozero II RunFlats?
  154. I give up
  155. Who is running 225/55 R17 on Stock wheels
  156. Pilot Sport A/S 3 so good!
  157. +35 offset fit on mini countryman??
  158. Brake concerns
  159. More than winter questions - soft off-road
  160. 17" Stock Wheels for Sale
  161. All Season?, Winter?, Summer?
  162. Winter Tires/wheels
  163. Time for tires...
  164. New lifted blacked out countryman
  165. R124 (Double 5-Spoke) Fit Over OEM JCW Brembos?
  166. Looking for 17
  167. Stock wheels .....
  168. Rotors...EBC, ECS, Centric, Zimmerman?
  169. Brake swap: brakes from BMWs
  170. 245/45/18 ?
  171. Don't know much about tires, help is appreciated!
  172. Wheels from X3 (235/55 R 17)
  173. Wheel compatibility with other models
  174. 245/45/19 tires on 2015 Countryman
  175. which is best exhaust for 2011 R60.
  176. Best tire/size suggestion for a non run flat 19" wheel
  177. Stock 17" Wheels for sale
  178. Ebc yellowstuff brake pads?
  179. 19x8 ET37 235/35-19 tires....
  180. What are these rims?
  181. Odd tire wear pattern
  182. Lusting for dakar wheels!
  183. 18" APEX wheels for sale - fits CMS
  184. 18x8 wheels with 235 or 225 tire?
  185. 215/55-17 on 17x7.5 wheel.
  186. Rear brake pad life
  187. Cooper Crap lift able to fit 215/70 R17?
  188. 19" wheel suggestion
  189. 16"-17" wheels on a JCW
  190. Winter Tire suggestions for Countryman All4?
  191. New jcw countryman leather
  192. Any Good All Season Tire Swap Experiences?
  193. Will 37 offset fit '14 CM
  194. Which Vendor will put a non-RFT on my Countryman
  195. Will 225/50 r17 run flat fit on my 2013countryman s all4
  196. CM Lug bolt torque
  197. R1 Concepts Rotors & Pads
  198. 19" wheels....
  199. But all the Countryman can be mounted to the base 19 "?
  200. Wierd Tire Pressure Indicator not in owner's manual
  201. Source for inexpensive steel wheels for Countryman S?
  202. Looking for recommendations on 2001 CM ceramic brake pads.
  203. Brake Pad and Front Rotor parts list?
  204. Looking for a new set of wheels
  205. Pirellis
  206. Enkei NT03M+ or MINI R126 Turbo Fans?
  207. 2015 wheels same as 2014?
  208. New Countryman S ALL4...Need Tire Help Please
  209. 16" Steelies On a JCW Countryman
  210. 19" M5 Replica Wheels
  211. Warning lights
  212. Finally threw out my run flats!
  213. Hankook Ventus S1 Noble 2
  214. Need advise on tires
  215. Extended wheel locks when using spacers
  216. selling Runflats with only 4000 miles
  217. Wheel Locks for NM RSe14 19" Wheels
  218. Verdict on 195-60-R16 Snow Tires?
  219. Minilite Style wheel - 17"
  220. Aftermarket wheels
  221. Color number (or name) of 18" MINI white turbo fan wheels
  222. Does wheel/tire combo affect MPG?
  223. Which Wheels? (19's)
  224. Flat tires
  225. Asa gt8
  226. 5 lud bolt pattern for 2014 mini
  227. I beg forgiveness from all you Tire Folks
  228. Stock wheel weight?
  229. Newbie- rear tires cupping
  230. Newbie- rear tires cupping
  231. Countryman John Cooper Works OEM 19" tires
  232. Breytons
  233. 245/40R 18's Winter Tires
  234. BMW M3 Brake Kit Retrofit
  235. CM Brake Upgrade
  236. Need advice...
  237. General G-MAX AS-03
  238. 19 x 9.5 ???
  239. Best place to get brake pads
  240. 2012 Countryman with 2" lift and 225/55/R18s
  241. Experience with Mini Roadside assistance & Non-runflat tires
  242. Will TPMS fit the 16" OEM steel wheels?
  243. How to Install Center Caps on 16" Steel Rims
  244. Best non run flat tire....
  245. All 4 Countryman slipping in little snow?!
  246. Can I run 245/45r17 on stock 17" wheels on my CMSall4?
  247. Use of Space Saver Spare with 18" wheels?
  248. How long did your tires last?
  249. ALL4 Tires rotation?
  250. 2012 Countryman All 4s Winter tire Question
