JCW adapters?
Old Jun 9, 2019 | 06:30 PM
OreoSAll4's Avatar
OreoSAll4
JCW adapters?
I have a 2012 Countryman S All4 and recently acquired a set of 2019 JCW Countryman wheels for almost nothing. I was wondering where I can grab adapters to fit them with. Also how wide of a stance can I go? Original specs were 205/55-17 and the JCWs are 225/55-18. Only issue is the JCW has a smaller inside center.
Cheers dudes!
Old Jun 12, 2019 | 07:36 AM
CG1*'s Avatar
CG1*
Cheers dudes!
The old R60 is a BMW wheel spec, whereas the new F60 uses the Mercedes spec. See the following images.
The adapters below will take care of the center bore issue as well as the lug pattern change while providing a new centering flange for the 66.6mm wheel bore. As for flush ... I recall there being a reasonable amount of fender overhang in the front of the R60. I'd recommend holding a yard stick to the fender, measuring the gap, and then running the offset calculations to figure out where the face of your new kicks will be with various spacer thicknesses. If I had to guess, you'll probably want the thinnest spacers available that are the type pictured below. For this reason, the link below should take you to the 17mm versions, which qualify as such.
https://www.ebay.com/itm/5X120-To-5X...ty!44141!US!-1
Get on it~
Old Jun 21, 2019 | 06:22 PM
OreoSAll4's Avatar
OreoSAll4
Get on it~
thank you so much for the info!!!! HOPEFULLY 17mm isnt too bad of a difference on the stock suspension!
Old Aug 17, 2019 | 10:57 AM
OreoSAll4's Avatar
OreoSAll4
Loving the look!
I like how it fills the wheel well and pushes it out a little. Only bad thing is the TPMS is not compatible. Let’s see how long it takes me to be irritated at the dummy light and shell out more money that what I paid for the wheels/tires combo. 😅
H2o racer
Jul 8, 2019 04:45 PM
Jubatusjames
Mar 29, 2019 03:10 PM
wzabrouski
Jun 14, 2018 12:56 PM
Jaque_Mate
Mar 7, 2018 02:56 PM
wildfamily
May 24, 2013 03:04 PM
