All 4 Countryman slipping in little snow?!
Old Dec 9, 2013 | 03:45 PM
Seastar's Avatar
Seastar
Hello everyone. I have a 2012 CMS all 4. It started snowing lightly today while I was at work and when I left to go home there was a little bit of slushy snow on the road. I was surprised how much my car was slipping and I wasn't even driving fast. What the heck? Why is this if my car is 4 wheel drive?
Old Dec 9, 2013 | 04:38 PM
bandwagn's Avatar
bandwagn
Hmm, mine has summer tires* and I was pleasantly surprised as to how well I was still getting around - yes, it was definitely slick, but I was expecting that.
(* picked it up in Dallas, where they usually have no snow)
Old Dec 9, 2013 | 05:01 PM
fishbulb's Avatar
fishbulb
Give us a little more info on the slipping... Spinning tires and not going anywhere? Something different? Does it have summer tires on it?
Old Dec 9, 2013 | 07:19 PM
chini's Avatar
chini
All wheel drive will not prevent you from slipping. My wife was commenting yesterday how her AWD Outback anti-lock brakes kept kicking in when she was attempting to stop. She has all season tires. Over the same route my 2WD CMS with winter tires had no such problem. Winter tires are huge. Love my Michelin Primacy Alpin PA3's!
Old Dec 9, 2013 | 08:08 PM
Z06_Pilot's Avatar
Z06_Pilot
do you have an auto trans? i wonder if that could be causing it as well.
We have an M6 in ours, and it snowed here over the weekend(about 4 inches or so), and we have the 19" summer P-Zero runflats on.
No problems at all. The All4 system took off from stops with absolutely no slippage, and turns were fine. Very easy to modulate the manual clutch for a smooth, slip-free take off.
short shifting is the key for us in snow and I'm not sure an auto trans will perrform as well in the snow/slush...that's just an educated guess on my part, though, so be kind folks
Old Dec 9, 2013 | 08:25 PM
diducmeb4's Avatar
diducmeb4
Perhaps too much pressure on the accelerator.
Old Dec 10, 2013 | 05:11 AM
watchluvr4ever's Avatar
watchluvr4ever
We got a few inches here yesterday and I experienced no slipping. My tires are Bridgestone Blizzak WS70's.
Old Dec 10, 2013 | 07:41 AM
Minibeagle's Avatar
Minibeagle
Slush is the most two-faced a-hole form of "solid" water. It will take you out when you least expect it. I find it worse than snow or visible ice.
Traction on all 4 wheels is good at getting you going in a straight line. That`s it. Anything that involves lateral movement and stopping when dealing with snow, slush or ice and, you need winter tires if you want to deal with that crud the best way possible.
I noticed that you're in Vancouver and probably deal with more rain than anything else during winter. You should at the very least have good all-seaon tires on the ALL4 CM.
Old Dec 10, 2013 | 07:56 AM
Fly'n Brick's Avatar
Fly'n Brick
Why should 4 wheel drive be immune to icy conditions? Get over it, cold stuff is slick regardless.
Old Dec 10, 2013 | 08:01 AM
Z06_Pilot's Avatar
Z06_Pilot
OK, I request unanimous consent to revise my previous post
Wife went to work this a.m. in fresh snow, and indeed the front end is washing out(think massive understeer!) when trying to make turns.
I was really hoping we could hobble through winter with the P-Zero runflats..not so much. Yes, I know, a pipe dream, but we wanted to give it a try.
I am going to order the Nitto Motiva all-seasons from Discount Tire to put on our 19" OEM wheels.
yea, I know smaller wheels might work better in snow, but I just can't bring myself to do that when I am going to be buying the nm engineering 19" wheels and Michelin Super Sport tires come the spring
Old Dec 10, 2013 | 08:15 AM
fishbulb's Avatar
fishbulb
Snow aside, I did the front camber mod on my ALL4 and it helped a bit with the front washing out.
22mm rear sway bar should seal the deal!
Old Dec 10, 2013 | 04:33 PM
ke3ee's Avatar
ke3ee
Front camber mod ?
Old Dec 10, 2013 | 07:39 PM
CHKMINI's Avatar
CHKMINI
Jeff, put some real snow tires on it if you're going to run summers too. We have a discount deal at Discount Tire in Columbus. Just mention Mid-Ohio Motoring (will probably be censored) or contact Nathan (probably censored too) and he can hook you up.
Old Dec 11, 2013 | 05:36 AM
Angib's Avatar
Angib
I don't think that tank has winter tracks on. I mean, who would try to drive a tank on icy roads with all-season tracks, huh?
Old Dec 20, 2013 | 02:10 AM
doctorjuan's Avatar
doctorjuan
Have 2013 Countryman JCW with 18" Goodyear run flats and the traction on snow is terrible.
Today, I am having Bridgestone Blizzak on 17" wheels installed and am really hoping I will have better results.
That they will be 205 instead if 225 should help.
Old Dec 20, 2013 | 02:39 AM
Z06_Pilot's Avatar
Z06_Pilot
so we had the Nitto Motivo's mounted, and have had several snow/ice conditions.
light years better than the P_Zero 19" run flat OEM's. they really inspire confidence in the nasty conditions, and with a 60,000 mile tread warranty, I like it even better. They are really fantastic in rain also.
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
JBsC6
New York/New England
Sep 24, 2015 02:41 PM
Southern Marylander
18
Sep 18, 2015 07:16 PM
Sep 14, 2015 12:48 PM
dandw2
Sep 7, 2015 11:14 AM
