Will 37 offset fit '14 CM
Old Nov 14, 2014 | 10:30 PM
MLH44's Avatar
MLH44
Need some advice. I found some wheels I like and all the specs are spot on except for offset. 18x8, 5x120, 72.5 hub diameter with 37 offset. 37 offset is lower than spec by only 3mm. Does anyone know (1) If 37 offer fit '14 CM and (2) with it being lower than spec what needs to be adjusted (hopefully nothing) to ensure proper fitting. Thanks in advance for your time and response. Cheers.
Old Nov 17, 2014 | 03:41 PM
CalsonicSE's Avatar
CalsonicSE
My aftermarket 19x8 wheels have 45mm offset. With 245/40 Sumitomo HTRZ III tires, the rear will lightly scrape on huge bumps. Fyi, I also have the sport suspension (which is a tad lower than normal suspension) and stock alignment.
My calculations indicate that if you go with 225/45/18, you should clear (with the normal suspension and stock alignment), or just barely scraping the rear on huge bumps (if you have sport suspension and stock alignment).
Old Nov 25, 2014 | 02:25 PM
bigdog0826's Avatar
bigdog0826
Smile
I am running aftermarket 19x 8, 45 offset with 235/30/19 with Coilovers lowered about 2.5 in and have no rubbing or bumping issues. I love the stance ands aggressive look of the wheels and tires.
Old Oct 28, 2015 | 11:05 AM
BLU-BY-U's Avatar
BLU-BY-U
Need Pictures of the the 37 offset if you took the leap.
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
jwildr56
Aug 26, 2015 12:40 PM
Mini'mon
Aug 16, 2015 04:15 PM
