Newbie- rear tires cupping
Just purchased an 11 Countryman with 26,000 miles. The rear tires are cupping on the inside, and from what I've read thats not uncommon given the the negative camber. My question is for those who have rotated their tires to the front that had cupping. First, did you experience any vibration in the steering wheel? Second, was the noise any less given less negative camber in the front? Thanks
You need to rotate & balance your tires at regular intervals. Sounds like it is too late for your rear tires. If you put them on the front even after being balanced they will most likely shake the wheel.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
