ALL4 Tires rotation?
Old Nov 16, 2013 | 01:33 AM
evobunny's Avatar
evobunny
Hi I couldnt find any info on tires rotation for countryman all4. Do you rotate tires on the all4 model. if so, do you do front to back, or another way. And after you rotate the tires, what about tpms. If I reset it, would it know that its been rotated.
Old Nov 16, 2013 | 08:05 AM
chrunck's Avatar
chrunck
Yes, rotate. How depends on if you have bidirectional tread or single direction. Look to see if you have an arrow on the sidewall indicating direction. If they're single direction (arrow on the sidewall), the only thing you can do is swap front to back on the same side of the car. If they're bidirectional (no arrow), drop the fronts to the rear, then move the rears to the opposite front corner.
You don't need to do anything with TPMS, but check your tire pressure after rotating and add air as necessary.
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 01:10 PM
Sep 2, 2015 01:08 PM
