PDA
View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52
  1. I know this is a tire rack sponsered thread, but...
  2. JCW Suspension questions.. Can I choose which springs?
  3. Wilwood BBK, post your kits and specs!
  4. RunFlats Are JUNK
  5. Brake Master/Hydrovac Repair Kit
  6. Question about offset
  7. Best JCW brake kit price?
  8. How much to professionally powdercoat silver R83 wheels?
  9. New tires coming soon -- what's the best size?
  10. PowderCoating lug nuts???
  11. Finally made the switch...no more runflats!!
  12. Wheel size/tire advice
  13. 3 choices..which would you choose?
  14. Wheel weight info...
  15. anyone ever get their tires mounted at Walmart
  16. Tire dumb person with a question
  17. 15 and 16 inch steelies
  18. Goodyear F1 GS-D3 Question
  19. Wheel locks: why bother?
  20. Does 205 have any advantages over 215?
  21. ABS fuse location?
  22. Weird Vibration. Not sure if tire related. Help please.
  23. need quick help? Will these rub?
  24. Replacement Tire Question (16's)
  25. 15s ok for street on an S ????
  26. Miata Minilites,will they work on a MINI?
  27. AutoX wheel/tire decision advice request
  28. any experience with motoforge wheels
  29. Has anyone noticed the Dinan Brake Kit?
  30. Axis Seven Mods Anyone?
  31. New shoes put on at Hot Import Daze
  32. R81 Holeys: A Tribute.
  33. Pagid Pads destroyed in one session?
  34. Do 16" SSR Comps work with JCW brakes?
  35. Vibration with new tires and wheels
  36. auto cross set up wheels and Hoosiers
  37. Rear caliper threads stripped
  38. Need input, I'm totally wheel ignorant!
  39. Kismet coincidence: New wheels
  40. 16" Bridge Spokes
  41. Pro 17in S-Lite people
  42. Runflat to regular tire question- same width???
  43. Will it fit?
  44. run or non-runflats again...
  45. Changing brake hoses
  46. Considering new wheels and tires...
  47. Looking for photos with HB or IB/B car
  48. Anyone running 20's yet??
  49. Cross drilled rotor choices
  50. Kumho MX vs. BFG g-Force KDW-2?
  51. Wheelmax Tuner Spline Key
  52. Picts needed of Rota Battles on your MINI
  53. What Tire is Best?
  54. Was it extortion???
  55. 17" BBS RG-R centering ring question
  56. TeamDynamics PR1 vs Exel TZ 10
  57. Front or Back?
  58. New 16 in. replacement tire options!
  59. Hawk Brake Pads
  60. Sumitomo HTR Z as track day tire?
  61. How do you pronounce Kumho?
  62. What is the weight on Nexo wheels??
  63. 205/40/17 tires and M7 springs
  64. Did I boil my brake fluid?
  65. If not tire noise, what?
  66. R98 Web Spoke Wheel Problem
  67. Aftermarket Holies
  68. MCS Track Wheels
  69. Need 17x8.5 or 9" wheels!
  70. P# for Hawk Blue stock caliper fitment?
  71. Rotor Torx Bolt/Screw Thingie...
  72. Brake suggestions
  73. Wax for wheels?
  74. TDR Pro Race 1's
  75. Opinions and Will It Fit
  76. 15 16 or 17?? pros-cons....and tire suggestions
  77. My hub caps fell off.
  78. Tire size & ride quality
  79. heeeelp BIG BREAK KIT trouble!!!
  80. Dunlop DZ02G
  81. Kosei K1 Racing Center Cap Solution
  82. reproduction 60's style Mini wheel for BINI??
  83. What is the best brake/BBK upgrade??
  84. Tires!!
  85. Yokahama Avid H4S ?
  86. Best Tires Under $100...
  87. Runflats on aftermarket rims???
  88. Any rules to predict possibility of rubbing?
  89. Less than 48 hours on S-Lites, here is what is new
  90. Potential wheel/tire purchase- need advice
  91. mount & balance Qs.
  92. Recommendation on budget 16 inch tires?
  93. New wheels on the car...yay!
  94. BBS RX on Ebay
  95. Average wear of factory runflats
  96. Mounting Directional Tires The Wrong Way?
  97. Alignment Feedback Please
  98. Anyone put 15 inch rims & tires on a MCS for comfort?
  99. BBK and 15" wheels for autoX only
  100. Tire Pressure
  101. Tires wearing to quickly for my wallet....
  102. Anohter Kosei-K1-TS quetions
  103. Stupid Balancing Question
  104. Rotas and Willwoods
  105. My wheels are on the way
  106. Pics of Silver Superleggeras on DS MCS?
  107. Wed Sport TC005 question
  108. Sendel S70 15x7 - fit or not?
  109. Cost To Powder Coat Wheels?
  110. My new shoes....RGII
  111. Finally decided on wheels..being installed tomorrow...
  112. advice request about tire purchase (size/brand) for 17" Flik Wasp
  113. Brakes Question
  114. 15 holey, 195 grippy enough?
  115. BF Goodrich KDW-2
  116. What tires do you use for racing?
  117. Rota wheels
  118. 16 or 17 inch pt.2 L@@KS
  119. Can someone help me?
  120. slime segment on american lemans
  121. Mini wheel center cap stickers choices?
  122. Runflat replacements
  123. Oh Oh - I think I need help - a lot of help!
  124. 17" runflats swap to 17" non- runflats
  125. Hey MMW guys!
  126. Tire Pressure
  127. Who makes the lightest 17" wheels for MCS?
  128. 16 or 17 Inch???
  129. Flik Wasp Wheels??
  130. The BAG LADY ROCKS!!!
  131. Hub Diameter
  132. Black S-Lites
  133. New to me. Wheels and tires.
  134. check out these babies
  135. What's the verdict on Hankook Ventus RS2?
  136. T1-S vs T1-R
  137. 35mm Offset - rubbing issues
  138. part 3: Test Results: A Valuable Tire Rack Advantage
  139. 215/40/16 Toyo T1s ??
  140. Need Winter Tires & Wheels
  141. Black rims/wheel advice needed (and yes I searched)
  142. Will it fit?????
  143. Work Emotion CR weight?
  144. Pagid Blue Race Brake Pads....Where?
  145. index ;Test Results: A Valuable Tire Rack Advantage
  146. part 2: Test Results: A Valuable Tire Rack Advantage
  147. Question about Wheelmax
  148. 16" DS Wheels for DS/B MCS??
  149. ?... what do you lose by going w/ 18's or 17's as opposed to fac16's?
  150. 16-inch All-Season Decision
  151. I've got R90 Wheel's, need new center caps
  152. Yoko 215/45/17 Tire Pressure for Cabrio?
  153. 225/50/15 on MCS w/ 1.2" drop? anyone with this setup?
  154. Check out these '06 models and wheels by MINI!!
  155. Winter tire size question
  156. Love'em or Hate'em... Need your opinion please
  157. Cobalt GTS pads
  158. Road noise - Pirelli performance stock runflats vs Yoko ES100
  159. under pressure
  160. Using MCS Stocks on a Mazda?
  161. "18 tires question?
  162. BFG KDW 2s vs. Pirelli P Zero Nero M+S?
  163. Can nailed tire be repaired?
  164. Test Results: A Valuable Tire Rack Advantage
  165. Dumb question re: wheel replacement
  166. Offset question
  167. BBS RX 17x7 ET35. will they fit?
  168. Quick width question
  169. Quality of Kosei wheels...
  170. How much inside clearance is there on a Mini?
  171. Asa Em9???
  172. After market wheels with stock center bore
  173. Tire size conundrum
  174. Finally got my new wheels on!
  175. pitting on white X lites
  176. deleting pad wear sensor...
  177. help! can't decide!
  178. Rotation advice
  179. TCE Wilwoods
  180. Here we go again,what do you think of this...?
  181. Toyo RA1...
  182. Team Dynamics wheels still available?
  183. Stupid question on tire pressure...
  184. Any GOOD Wheelmax experiences?
  185. ContiComfortKit Exposed~!
  186. spacers only on the front?
  187. Stoptech brake kit fitting
  188. Friends don't let friend "run-flat"
  189. tow hook for MCS
  190. Jack points & Caliper paint
  191. Wilwoods under Rotas?
  192. Curb Rash Repair
  193. Question: buying packages from the internet
  194. Another wheel question
  195. Want to trade brand new 16" ASA LW5's in white for white R83s
  196. Want Bling-Bling W/O Cha-Ching?
  197. 205-45-17 versus 215-45-17
  198. Anyone have a picture of their MINI with ASA JH6 wheels?
  199. Beat the *#$% out of my brakes!
  200. Who's running 18" wheels? Pictures!!
  201. Help me choose! Silver or Anthracite SSR comps with CR/B Mini?
  202. Tire size question
  203. Are lugs for all OEM mini wheels the same size?
  204. JCW brake kit install problem...help!
  205. Anybody using a Honda Civic doughnut spare tire/wheel?
  206. QUICK! Lug torque!
  207. Which way to go?
  208. Team Dynamics Pro race 1, do i need hub centric ring for it??
  209. Yoko ES 100 or Parada Spec-2?
  210. Rota Stock Wheels, 16 by 6.5
  211. Anyone with CHROME wheels?
  212. Advan A048?
  213. Ecsta 711 experiences?
  214. Keeping White Wheels White
  215. Track tires
  216. Ultimate Fix-O-Flat Solution.. From Continental
  217. Looking for 15" "R"s ?
  218. Stock rims/tires for track day?
  219. Tire Size Question
  220. ASA JH6 weight?
  221. What is the best track-dedicated brake pad?
  222. Q: 15" Wheels for track only
  223. Any experience with Wilwood Big Brake kit?
  224. Nakayama Shumacher Evo
  225. 18" wheels--what size tires??
  226. Please advise ...
  227. Mini and Runflat Tire Trivia - First year runflats were offered on a Mini?
  228. Such things as Runflat rims?
  229. 16x7" wheels. maximum offset in front and rear
  230. Can runflats be re-mounted?
  231. 15" Tire Pressure questions
  232. Ecsta V700 availability
  233. TCE kits available in the UK?
  234. Wilwood Brake tapping noises
  235. Where to get tires put on
  236. The MINI is pimpin'
  237. 16" aftermarket alloys - feedback request
  238. Non-Runflats make a big difference!
  239. Researched but wanna make sure...
  240. Pirelli Runflats Following Rain Grooves
  241. Rotation info
  242. Wilwood Clearance Question
  243. 16'' runflats or 17'' performance?
  244. Large Spacers?!
  245. White Wheels! yes/no/pics
  246. new shoes
  247. room for more rubber
  248. Tires That Can Last Over 8 Months
  249. Nail In Sidewall
  250. Help w/ Slow Leak Identification
