Team Dynamics Pro race 1, do i need hub centric ring for it??
Old Jun 10, 2005 | 12:27 PM
larkie's Avatar
larkie
i just bought a set of 17x7 45mm offset 4x100...
but wanna know do i need those center ring ?
if so where can i order it??
Old Jun 10, 2005 | 01:06 PM
red rage's Avatar
red rage
Yes, you should always order them, metal ones, if possible, keeps wheel centered on hub
TireRack, Discount Tire, etc...
Old Jun 10, 2005 | 04:06 PM
kenchan's Avatar
kenchan
What is the center bore size on your wheels?
If it's already for 56.1mm, no need. :smile:
Old Jun 10, 2005 | 05:27 PM
Passat774's Avatar
Passat774
Pro Race wheel need rings. Check the Team Dynamics website they may have the bore size.
I can check some books for the info if you can't find it
Old Jun 10, 2005 | 05:55 PM
MSFITOY's Avatar
MSFITOY
Yes...metal rings. Got mine through Discount Tire:smile:
Old Jun 10, 2005 | 06:42 PM
onasled's Avatar
onasled
.... yea, you got the cool red ones!
Old Jun 10, 2005 | 06:53 PM
MSFITOY's Avatar
MSFITOY
Ya but your sig is making me want to spend more money on a M7 wing
Old Jul 14, 2005 | 12:02 PM
sdiver's Avatar
sdiver
Do you remember what size rings the TDR PR1's need? Probably going to be placing my order on a set this weekend, so I'd like to get the centric rings at the same time.
Old Jul 14, 2005 | 12:13 PM
MSFITOY's Avatar
MSFITOY
I can't remember but the people you got the wheels from should know. The Mini's is 56.1mm.
Sid
Old Jul 14, 2005 | 01:15 PM
sdiver's Avatar
sdiver
Sid
Thanks Sid, got the hub-centric ring thing figured out...
Only one more question... (I should really come up with all of these at once )
I noticed you don't have the center cap on your TDR PR1's. Do they not fit?
Hopefully, that's all
Old Jul 14, 2005 | 01:29 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
PR1's produced after 2003 were made with a inner on the inside of the center bore that will accept center caps.
But if I recall in my conversation with Team Dynamics they only make one style cap for the PR1's
unfortunatly for me I have the older style. So, I don't get caps.
Old Jul 14, 2005 | 02:28 PM
MSFITOY's Avatar
MSFITOY
I tried to scope around for a simple domed chrome cap but no one has one and TRDs are extra/not very attractive. In the end, I prefer less:smile:
Old Jul 14, 2005 | 09:51 PM
sdiver's Avatar
sdiver
So I almost understand offset...I'm getting there. But what is the difference between a 38mm and a 45mm offset?
The TDR Pro Race 1's I've tracked down thru a seller near me only has them in a 38mm offset. I didn't even know they came in a 38mm offset, I've only ever seen them in a 45mm offset.
Old Jul 15, 2005 | 07:01 AM
MSFITOY's Avatar
MSFITOY
That's 7mm difference outwards. I was told that too when order but they came 45ET. With a 5mm spacer, I brought them out to 40ET. 38ET could cause you problems if you run low and use 215-225 tires:smile:
Old Jul 15, 2005 | 07:09 AM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
If you bought them from us they are included in the price of the wheels.
Old Jul 15, 2005 | 12:28 PM
MSFITOY's Avatar
MSFITOY
Aaron, the ones that came with my TRDs were plastic...not good. Metal rings held a tighter tolerance and got rid of the vibrrations.
Old Nov 9, 2005 | 09:22 AM
golden_child
I know this goes a ways back but just for FYI and anyone out there searching or doing a search for the bore size of a Team Dynamics Pro Race 1 size 17x7 the bore size of the wheel is 73.1mm.
The MINI bore size is 56.1mm
Bennyboy
Dec 1, 2016 11:09 AM
Nine Plan Failed
Oct 14, 2015 11:50 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 02:06 PM
SneedSpeed
Sep 2, 2015 05:34 AM
