- Mini Brake decals
- R99's ordered
- bad vibrations
- Exel Wheels
- problem braking... help?
- 15's for the Street
- Yoko ES100's on SSR Comp 17
- Best brakes for 16"
- How much are my runflats worth?
- Caliper covers?
- Lug bolts...Yellow vs Black?
- Help! P-Zero Nero (Summer version)?
- best brake system for cooper s
- Wheel/Tire Trades
- AAGGHHH How safe is 3 of 4 studs on wheel??
- Pics of R99, Gramlights or Superleggras on DS/B
- Want a good set of rotors...any help??
- 16" or 17" track wheels and tires?
- Came across some good deals
- RunFlat Tire Feedback-PLEASE :)
- Wheels and tires choices, Help ! : )
- JCW Brakes and Anti-lock mechanism
- throttle steer
- Looking for black wheel studs
- Yahoo's damaged my rims
- Jack Plate question
- changing wheel size
- Is there tire performance & longer tire life @ $100/per ?
- "Wheel mates"
- New Wheels
- AK Tire Monza PIctures
- tenzo mach-10s?
- B3 brake kit
- Where to buy Velox wheels?
- My FINAL Tire and Wheel Combo.
- How to ship wheels and tires?
- Ahhh the A8
- Fat tires on a 7 hollie?
- Hankook Ventus R-S2 Z212
- Front tires Cupping, possible cause?
- 16' vs 17' R90 and JCW Brakes
- Non Runflat - Non Track long wearing tire for the MCS; anyone got a recomendation?
- brake lines for $75??????
- Thanks, Alex!
- PIRELLI Girls are VERY HOT at the TIRE RACK !!!!!
- Stoptech BBK user...
- Can anyone confirm that the TCW 12.2" wilwoods clear x-lites from a cooper s?
- and Another Spare Tire Question...
- Runflat Sidewall Bumps
- JCW 18" tires
- Tire width - how much rubber do you need for the Mini?
- Hawk Performance Ceramic Pads?
- 215/45 R16 Azenis Fitment Question
- Stock Lug Bolts and Ro_Ja LT5's
- Wheels vibrating
- White wheels black roof anyone ?
- Brakes video
- Stock 15" and SS+?
- Odd Question About Caliper Paint
- Stupid Question about shipping tires and wheels.
- Kicked but at Buttonwillow but what is wrong with my brakes
- Sold the Superleggerra's, and Added BBS style ASA AR1's, What do you think?
- Why Not Michelin?
- Post Pics of your 15's !
- Will 17x7 with +36 offset. 215/40/17 rub?
- In search of a solid set of wheels and tires, any reccomendations?
- EBC pads...now squeal!!! Do I require new rotors??
- Brake advice
- Spare wheel and tire - seeking suggestions
- NEW Airless Tires from Michelin
- Wheel choices
- Do I Need A BBK?
- Thinking of getting ASA JS1 wheels in white. Do they hold up in rough weather?
- replacing tires will this effect flat tire sensor?
- JCW Brakes and SSR Comps
- Centerbore rings won't come out
- Toyo Praxis Tires - Any experience or opinons ?
- Runflat Sidewall Question
- Mini logo center caps?
- Track Tire choices?
- alignment tweeking?
- Weight of R85 OEm 17 inch wheels?
- Is MINI Wheels Hub Centric?
- Do all tires need to be same?
- Where do I get reasonably priced wheel locks?
- M Mobility Kit What it is?
- Brake Duct prototypes
- Brake Caliper Turn Back Tool For MINI
- OZ Superleggera Mounted Today, What do you think?
- Stripped the Caliper :\
- Brake Bleed Wheel Sequence
- Offset Discussion
- Offset for Rota Wheels
- Need to know for sure. Does Civic spare fit?
- Rear wheel well trimming
- Motegi Ro_Ja Lt 17'' fit issue
- Help me decide on tires please!!!
- Help distinguish wheel size in this pic
- 17" White wheels.. Exel TZ10 or TDR Pro Race 1?
- Any recommended dougnut spares?
- what size tires for 15s?
- Non Run-Flat Flat Tire Kit
- What is the minimum wheel clearance for a big brake kit?
- PLEASE, Someone Photoshop this
- Brake Pads: EBC Green vs. ?
- Want smoother ride
- Tire Age...Need Advice
- I think I'm gonna buy 18" Sport Max 920 Rims
- 11.75 Wilwood's On 16x7 Rota Slipstreams
- 05 brakes
- Wheel and tire switch questions from a newbie.
- is this a good deal?
- Removing brake rotors problem
- Naive question
- tire help needed
- Tire Pictures Needed
- Wheight of Web Spokes? ANYONE KNOW?
- Stock rotors/new pads or BBK for track?
- Why so many 16" wheels for performance?
- Nitrogen filled tires?
- Looking for some show car wheels for my Mini
- What about these?
- Weird Cable Linkage Sound in Steering + ABS
- Tracking the AVS100
- Bent Rims/Run-Flats suck!
- rear brakes wear first???
- Rusted lug bolts with aftermarket wheels
- Flik Wasps?
- So, how much energy is in the wheels, and how much benefit is there in going lighter?
- superleggara or not so super?
- Red Baby
- 16" wheels with non-runflats?
- front end vibration after replacing runflats
- Rear Stainless Steel Brake Lines - Choices?
- Kuhmo V710 ??????????????????????????
- TCE Wilwoods - Holy Crap!!!
- Avon Tech M500 impressions
- anyone else having JCW brake problems???
- BBK with Panasport FS-16?
- Cheap decent/good tires :)
- JCW 18" Wheels - Fair Price?
- Tires For Some New Wheels
- Effect of wheel offset on handling
- Last minute dilemma...17" or 18"
- Handling worse with new wheels?
- New MCS Owner with Tire Question
- Will 17x7, et35 work on the MCS?
- Best Price on factory 17" R90
- Which anti-squeak goo works best?
- SSR Comp loose caps
- Alutec ZERO Wheels - tire size help!
- What does it mean when .... brake wear
- Tweel? What the....
- Impact of Wheel Width?
- Light weight White 17" rims
- Magnum cross-drilled rotors
- Total Cost of JCW Brakes?
- BBS RK or SSR Comp?
- 17" or 18" rims?
- Nitto NT555 vs. Pirelli PZero Neros
- New CF Brake cooling kits!
- lugs and hub rings
- 15 in wheels for Weekend track duty
- SSR Comps
- will 14"ers fit a MC?
- Got Konig (holes,freefall,rewind) Mini pics?
- Anthracite paint
- ?? 15" CP-035 wheel (11 pound)
- Stock lug bolts with aftermarket wheels?
- Is JCW brake kit worth the money?
- What torque setting for lugbolts on wheels?
- 16" wheel upgrade - what tires?
- Which Big Brakes for BBS RGR wheels?
- Questions on tire wear and stock setup
- Wheel Flustration NO LONGER Eating Away @ Me, Now it's the TIRES!
- "Don't put your best foot forward"
- Went to dealer might buy Mini with wheels
- Torque Steer - How do I minimize it?.
- Ditched the Runflats: Driving impression
- 16" B3 and Konig FreeFall (225/45/16)
- Damn these runflats!
- Ssr Gt1
- EBC Green Pads - with or without sensor hole?
- White 17" wheels wanted
- Load Rating?
- Strongest wheel?
- Stock 15 inch anyone?
- Brake question
- Tire pressures run-flats
- How is acceleration affected?
- wheel help
- Clack!!!
- Centerline Monsoon ( Storm ) wheel
- OEM Cooper Spare fit on S?
- Worries about rubbing with 215/45/17's?
- Edge Racing Mess Up
- 205/50/16 vs 205/55/16 on stock wheels
- Need help with track only tires
- Any one interested in a Rotor / Brake Pad Group Buy?
- Avon Tech R in 225/50-16
- Paint for the stock wheels?
- This might seem like a dumb Question.
- Rub Problems 18x7.5
- Advan RGII 17x7.5 +41....will they clear Brembo?
- Weighty decision - T1S vs Pilot Sport vs S03...
- Wheel opinion.
- Question for Alex (or anyone else) on tire pressure
- NO 215 / 17 R compound tires!
- Tire / wheel set for max comfort?
- Weight of stock 15" rims?
- Black R83?
- 195/65/15" studded snows-will they fit??
- 215/40-17 tires for MCS?
- Picture Request! Racing Hart C4
- conticomfortkit flat repair unit
- Floor Jack advice?
- Time for the first brake job...
- 225/50/15 will it fit an MCS?
- Anyone know the weight of the Gram Light 57S?
- ok everyone hates stock w/runflats, is the 2005 mini s any different?
- Rota Grid, which finish for DS/B MCS?
- Air Pressure for 215/45/17 Toyo Proxes4?
- Jack and Stand Points = Wheel is stuck!
- new Dinan MINI wheels?
- considering buying a plug kit
- Just dropped 16 1/2 pounds per corner
- Would these fit
- Whatcha know about bling?
- Metal Hub-Centric Rings?
- Chipping/scratches on my white x-lites
- OFFICIAL INFO CONCERNING E46 M3 CSL Replica Wheel
- Advice on these Motegi's....
- how long do the all season run flat tires last
- Infatuated With Mesh Wheels, Suggestions Wanted
- Brake Kits that fit R84 Wheels?
- Panasport Street v. Race Wheels
- Need reconmendation for exposed hub
- 215/50R 16 or 205/50R 16?
- I found a white rims touch up paint ..
- Inflation Rates
- Graham Lights - 57S
- Weight?
- 215/45/17, 215/40/17, 205/45/17... I'm confused!
- 215/40/16 too small?
- Stoptech BBK Installed
- other manufacturer rims?
- Changing from 16" Vspokes to 17" S-lites.. will speedometer be effected?
- Any input on runflats
- Wow (E46 M3 CSL Replica)
- just got two replacement runflats for the 16inch MCS
