Will 17x7 with +36 offset. 215/40/17 rub?
Old May 5, 2005 | 01:45 PM
VoiD's Avatar
VoiD
I'm currently shopping for wheels and the only offset they have is a +36 in the wheel I have..
Will I have problem with rubbing when running 215/40/17 tires?
I am planning to lower the car about an inch later on.
Please let me know what you think.
Thanks.
Old May 5, 2005 | 02:02 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks.
Doesn't look good for you if you lower your MINI.
Talk to Alex@tirerack.com
With stock suspension you are right at the limit for rubbing with a +36mm offset. The 215/40-17 tires are OK but load rating is a bit lower than stock.
Trimming with a dremmel tool to the outer wheel arches in the rear would be needed once you lower your MINI.
Old May 5, 2005 | 02:05 PM
onasled's Avatar
onasled
It will rub a good amount I believe.
Old May 5, 2005 | 02:07 PM
VoiD's Avatar
VoiD
aren't people running superleggeras (with a +37mm offset) on lowered cars?
is 1mm going to make a different?
I don't mind trimming a little, but I don't want anything rubbing the metal.
Old May 5, 2005 | 05:06 PM
Passat774's Avatar
Passat774
IMO, you should be ok.. When you lower you may need to trim, like everyone else has said
Old May 5, 2005 | 05:07 PM
VoiD's Avatar
VoiD
that's what I think..
I ordered the rims, so I'll report back once I get them mounted.
Old May 5, 2005 | 05:26 PM
Passat774's Avatar
Passat774
are you going to tell us what you are getting or are we going to have to wait ??
Old May 5, 2005 | 05:55 PM
Itsdchz's Avatar
Itsdchz
the superleggera's didnt rub on stock height with only passenger and driver on the car. 17x7 37mm offset, 215/45/17.
Old May 5, 2005 | 06:32 PM
VoiD's Avatar
VoiD
wait till monday.. It's a Volk Racing wheel.
Old May 5, 2005 | 07:53 PM
kyriian's Avatar
kyriian
oooooooo can i take a quick guess they are te37s?
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
luisfv56
Nov 16, 2015 01:55 PM
