- So... I have been looking at some new tires...
- Recommendation for 15" tires
- Bigger brakes = less hp at the wheels
- Green Stuff Pads & a Weekend at the Track
- Questions re: mounting/balancing
- lose the run-flats
- Bbs Rgr....
- Brake bleeding question
- who know some cheap Wheels to replace my OEM 17"
- Have you switched out your OEM brake pads?
- Updated info on the DP caliper kit for 16" wheels!
- Ssp ??
- Help with Volk wheels?
- R99 wheel
- Cooper space-saver spare questions
- what should I know when buying used tires+rims?
- torque specs
- Wheel weights
- OZ wheels?
- Which size?
- Gas Mileage Decrease With Bigger Wheels/Tires
- Just Purchased Yoko AVS ES-100 but....
- What might be the Average life of a track only tire?
- Will these tires fit...
- Rotor Disc rotors
- Squeaking brakes on a new MC
- The pothole and the Mini.
- R-Compound Tires Listed in European Car Mag
- Classic Minilites to fit?
- Thank you, Alex @ Tire Rack!
- Help: Tires Have Super Slowwww Leak! Any Suggestions!
- Will Rota Slipstream Fit MCS?
- Need help on front brake kits
- 5 Zigen wheels...
- 15" BBS RA on a MINI?
- HRE 540R's Gunmetal w/ Polished Lips
- 205/45/16 on a 40os and lowering (???)
- minihune: Question RE: Jcw wheels
- Spacers
- Enkei RPF-1
- Need pics of 15" Exel TZ-10s or Team Dynamics
- HELP..Ferodo brake pads
- Where to buy 15 in White Wheels?
- Let's see some pics of aftermarket wheels on black Minis
- Goodyear Assurance feedback?
- Oz Canyon Wheels
- Where can I get these wheels???
- Can I Push 40 series tire onto wheels?
- 8in wide in the front and 9in wide in the rear?
- Air Pressure 16" run flats?
- wheel specs for Cooper?
- smallest wheels
- 16" vs 17" wheels
- 15, 16 or 17
- reputable online wheel seller???
- Will these wheels be fine on my CVT cooper???
- run flat installed, wheel damaged
- Kumo Ecsta MX question
- 205 40 17's on MC?
- I brake too hard!
- Who sells Toyo Proxes RA-1 tires (at a good price)?
- EBC Greenstuff Transplant Questions
- Is a brake "transplant" possible
- Hankook Ventus Hrii H405 or Toyo Proxes 4 quietness
- Vibration
- NEED help Rear strut bolt broke
- Best plan for street & autox tires/wheels?
- How are my brakes?
- Anyone got pic of Black V-Spoke or X-Lites Wheels?
- 15x7.5 36 et rims?
- Need to get tire mounted, North Jersey
- Need help, Deciding between these two sets of wheels.
- 185/55 R15 for 15" holies?
- Pilo Racing - New Brake Rotor Upgrade Available! Free Shippi
- adjustable coilovers
- Info on warranty replacement of rotors?
- nippon racing rims
- Wheels, how wide can you go.
- Thinking About A New Set of Wheels
- Fuzion tire by Firestone
- Screws vs. Screwless
- Mushy Brakes
- Smaller kit for 16" wheels?
- Ran over nail punctured side wall
- Advice on rear piston retraction?
- Speed Bleeders anyone?
- SSR type C needs hub centric rings ??
- Got rid of the run-flats, now what....
- Proper Brake Bedding?
- Who's got Rotas?
- bubble in sidewall on runflat safe to drive on?
- 18" wheel offset
- 15" 7 holes
- Goodyear Eagle F1 GS-D3 fitment
- Anyone know what Wheels/Tires these are?
- UUC Brake kit?
- Exel Maj Wheels
- Brembo rear discs
- Will the 15" R81 (7-hole) Cooper wheels fit on a Cooper S?
- Mintex RedBox Shrieking like crazy!
- Hubcentric ring adapters?
- Raising the Mini?
- Brake pad replacement????
- Kosei K-1 TS 15x7 with Avon 225/45
- Rear wheels tilting inward at the top
- Another stupid tire question.....
- Fender Rolling.
- Max Grip Tires in July European Car Mag
- Spray off of the ES100s
- What is a fair price?
- winter rims
- EBC Green Stuff brake pads are........
- Major Problems with my Pro Race 1's...Bought some Centerline
- Rotating my Victoracers?
- Fender-well trimming for 37 offset wheel and 215/45-17 tire.
- Tire pressure for the stock 17 inch run flats
- Accu-Torq vs Torque Wrench
- Pics of Pro Race 1's with center cap wanted
- Spongy brakes after bleeding and new lines- Any ideas?
- H&R coilovers with 18" anyone
- powdercoating or painting wheelS?
- Who makes the S-Lite wheels for MINI? I have two different k
- New Wheels & Tires now car pulls right.
- Rota Tarmac 17" black PICs?
- Looking for HOT black 16" wheels
- Centerline Wheel Specials
- will these wheels fit?
- Why use lug bolts? Conversion?
- BF Goodrich Traction T/A V (205/50/16)......
- 18" anyone running 205-40-18
- hubcentric rings for everyone!!
- Stoptech Update
- A mallot to remove wheel?
- Why size up on wheels?
- Anyone have photos of Panasports on their car?
- Newbie! Best all around spring/shock combo for aggressive s
- Looking for help & pictures of lowerd MINIs W / 215-40-17's
- Collapsible spare tire for MINI?
- JCW Wheels almost stolen!!
- brake caliper paint
- Big Brake Kit
- keskin wheels
- Suggestions on lowering
- Kumho ecsta 711?
- tire and wheel match up question
- replacement tires ???
- ROUND DECAL FOR WHEEL CENTER
- Will they fit?
- 215 35 18 rubbing
- Feedback on Goodyear Eagle GT-HR?
- Lug Bolt Torgue for Track Day
- Brake pad warning light!
- Explain wheel sizes please
- Pics on Indi Blue MC/MCS with wheels
- 16'S, 17'S OR 18'S? Which size makes the MCS look the cooles
- Can anyone find Konig Heliums and Falken Azenis 205/50-15?
- New JCW wheels for my "S"
- "The best tires belong in front" is a myth...
- MC 5speeds hows yours
- 2 to 3 piece wheels???
- What is the most mileage one got from the Yoko AVS ES100?
- WARNING! Check your tire pressure!
- Need help and advice
- Help, my runflat indicator light keeps coming on after insta
- Kumho MX on stock Cooper wheels
- change rims = change speedo reading?
- Proper OEM lug bolt torque specs
- Drag-racing tire
- tire pressure
- Wheel Color?
- those dam$ wheel studs
- MOMO M2's
- NEW Wheels Pics
- Need help with new wheel and rim problem
- No plans for JCW wheels in white
- Pics of new wheels.
- some questions about tires/wheels and sizes and such
- 225/40-17?
- Falken GRB FK-451
- Did I get the wrong wheel?? Help with deciphering and tire
- Pics of 205/50/16's on Mini
- Strong wheel+tire combination?
- drilled or slotted rotors?
- about oz superleggra
- Which is lighter weight, ES100's or Spec2's?
- Replacing my 195/55/16 run-flat's
- Painted Brake Calipers w/ Pics...
- AP Brake kits question
- Brake Calipers
- Which rotors to go with?
- What is the best tires for street and some track?
- Labor Charge from MINI Dealer for JCW Wheels
- Has anyone ever actually sold S Lites with runflats?
- Kumho V710 Recall
- Speedometer (and odo) difference with 205/50-15's
- 18 Rims with 215/35 Tires
- What's Lifespan of Pirelli Eufori@'s?
- Is 205/40/17 OK?
- What wheels are these?
- How to Pick New Wheels for MCS?
- Any pics of Centerline RPM wheels with electric blue?
- Goodyear Eagle F1 GS-D3, opinions or reviews?
- Gunmetal Rota Wheels on Dks/Dks--pics please!
- volk gt7, stoptech brakes, carbon fiber front lower lip
- BBS RGR 17's-Picture
- size help for a newb.
- MINI with HRE's??
- Pictures of JCW wheels installed
- tires?
- Kosei K1 TS
- R-compounds - recommendations for MC?
- Flik Wasp Wheel Company
- 205/45 17 Choices: Looking at AVS ES100 vs Parada Spec-2
- Centerline Polished rims on ebay
- Avon Tech R
- Kumho ECSTA V710 Tire Eligibility Suspended
- Alex - Fuzion Tires for the MCS 7 x 17 Wheels
- Brake upgrade question-->
- question about powder coating
- Scratches in polished lip. What to do?
- LETS SEE SOME LIP!!!
- KUMHO TIRE RECALL! Ecsta V710
- Volk GTU wheels
- Brake pad replacement; pad sensor question
- need your advice quickly
- 17x7" vs 17x7.5"
- ONLY $99ea!! PIRELLI P ZERO CORSA 215/45/17 (set of 4)
- JCW wheels installed?
- Brakes
- Pot Hole = Popped Run-Flat!
- need help finding particular size runflats
- Mintex Redbox - autocrossing?
- How Install aftermarket wheels?
- Widest tires to fit on OEM 15" wheels
- Anyone with the 15" 7 holes - ? for you.
- Black rims with a Metal Lip
- No more runflats for me
- painting wheels
- painting wheels
- lug pattern and offset for wheels
- Goodyear Service Center B.S.?
- Slow leak in new Yokohama AVS ES1000 and BBS RGR's
- Comments on ADR and Flik wheels???
- Hub Size help!
- Team Dynamics Monzas
- Anybody selling their stock wheels?
- Black Wheels, any pix?
- 205/50/16 on OEM 16 x 6.5
- Roofing Nail in Rear Runflat -- Question
