PDA
View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52
  1. Axis Reverbs
  2. 16" vs. 17" wheels
  3. 911 !!! I need HELP Installing wheels!!!
  4. Will these BBS fit properly and not rub?
  5. Light, Black and 16"?
  6. Rotors DO glow when hot!
  7. BBS Accessories
  8. Shipping Tires & Rims?
  9. "Affordable" performance brake upgrade...
  10. Stock brakes for track day?
  11. Promini Brake kit stage 2 installed
  12. Pirelli Corsa or Kumho V700
  13. Question for Alex on SSR Comp
  14. Initial selection ,advise needed.
  15. Which wheels to order if I'll be selling them anyway?
  16. Looking for DIY Brakepad replacement instructions
  17. Kumho Ecsta V700s for DEs??
  18. received and installed snows from TireRack
  19. Curbage on my White S-lite...
  20. Wheels & Tires for street / autocross
  21. Lug conversion kit
  22. Painted R84s...Orange X-lites
  23. Hub Rings?
  24. Snow Tire size?
  25. BBS RK or RK II's
  26. 225/40/18 & 215/35/18
  27. Recommended tires for stock rims
  28. Hankook Ventus H405,Falken Ziex Ze-512,or Toyo Proxes 4?
  29. Paging Alex - Shipping Question for you
  30. dust shields below freezing?
  31. Hooray for Tirerack
  32. Dumb Question - R84 center caps
  33. New BBK from TCE
  34. what size for a 1" lowerd "S"
  35. Help! Just Got Winter Tires, Flat Tire light is on.
  36. how to remove the darn hubcap???
  37. Michelin Pilot Exalto PE2
  38. Request: Pics of 17" and 18" on stock MCS suspension
  39. 17" S-lites, perf vs all-season OEM tires
  40. 17s or 18s???? Pros & Cons...
  41. Vibration when braking
  42. RGRs are BBK friendly?
  43. All Weather or Snow Tires?
  44. Tire help Goodyear, Bridgestone, Toyo
  45. MINI Compact Spare Tire width...
  46. Brakes.....
  47. brake dust
  48. S-lites replacing FLIKs for the winter
  49. Opinions on these wheels please
  50. Ro-Ja Wheels? Post Photos PLEASE!
  51. Got Wheels on!!! PIC
  52. 225-45-16
  53. New Flik Apex2!!
  54. question on hub centering rings
  55. Are Volk wheels a direct bolt on???
  56. your opinions on changing to snow tires
  57. New 5zigen FN01r-c wheels!
  58. Powder coating wheels?
  59. Tire Rack website showing NO info on MINIs today.
  60. Wheel installation
  61. Dunlop Direzza?
  62. Switching to 215/45 R17 from 205/45 R17
  63. MINI not supported on Tirerack.com??
  64. BFG Scorcher t/A
  65. Kazera pitting
  66. What wheels are these?
  67. What is the difference in all the MINI wheels?
  68. SSR comp price increase
  69. Storing Wheels and Tires
  70. oem mcc wheel/tires on mcs?
  71. For OE MCS X Lite, what is best replacement Tire?
  72. How to murder your wife....
  73. Can't find old thread with tire replacements to MCS 16inchers
  74. Falken Azenis For Track Use?
  75. Steering wheel vibration
  76. Who has these wheels......????
  77. New Tires
  78. Crazy Brake Fluid = Dot 5.1
  79. low buck brake ducts
  80. Looking for tires 215/45/17
  81. 5Zigen Pro Racer wheel
  82. nail in my run flat
  83. wheel help!
  84. Question for Alex....
  85. 215 or 205/50/16
  86. 15" wheels and tires on an S?
  87. 17" or 18" given the option???
  88. nitrogen tire inflation
  89. Kosei K1 TS 15x7 et38 Fitment on '03 MCS?
  90. 17" Pirelli Runflat - separated from rim and wall
  91. Some questions....
  92. Brembo BBK and 16s?
  93. did i do something wrong?
  94. 18s and H-Sport
  95. vibrating steering wheel on SSR wheels
  96. Anyone Painted Their 16" R83's Black?
  97. 16x7", ET42 or ET48...what's best ??
  98. Glass Transition Point Compound Standards?
  99. What's better 7.5 wide or -2 lbs
  100. Moving tires out, side panel debris?
  101. Rim Size Question
  102. Which wheels should I get?
  103. Winter Tires for S Lites???
  104. Runflat fixed today
  105. Anyone Have these rims on their car?
  106. Steel rims for winter
  107. winter tires on lowered MCS
  108. AC Schnitzer Wheels
  109. Input please on wheel choice
  110. Heeelp with tire issues
  111. Time to replace OEM tires on '02 Cooper CVT...
  112. tire chains
  113. Pilo Racing - Brake Speed Bleeders now available!
  114. Flik Bullet-a
  115. better all season tires than the runflats
  116. Run flat has a nail
  117. Goodyear RS-A and snow; good or bad?
  118. New : Pirelli Winter 190 Snowcontrol
  119. BF Goodrich Tires?
  120. Anyone make 215 R17 in 30 or 35 series???
  121. 17x7.5 45mm Offset Fit With H-Sports?
  122. I Would Like To Find..........
  123. Wheels & Tires
  124. Replacing tires
  125. My 5th MCS modification...
  126. Winter tire pressure
  127. New 17" Web-spokes weigh 22.31 lbs. per wheel
  128. widest , affordable 15" rims ??????
  129. Tire pressure?
  130. red rover, red rover
  131. Dark Silver Mini, Bronze Wheels
  132. I'm just gonna ask
  133. Buying these wheels
  134. Tire/wheels dealers in central Ohio
  135. Help!?! Black FLIK Wasps
  136. Falken Azenis RT-615
  137. 2RE Web Spoke wheel weight?
  138. Lightweight 15" wheels for Wilwood 11.75" brake kit?
  139. Moon Wheels/Hubcaps?
  140. I'm so confused
  141. wheel help
  142. LTPWS Questions..
  143. hamman HM4 Whats the deal!
  144. My new Avon Tech M500 tires rock!
  145. Is anyone running Toyo Proxes 4s?
  146. I guess it's time to put on the snows...
  147. Tire pressures on and off the car.
  148. Toyo tires for track
  149. MINI's factory rims
  150. Aftermarket wheels, are they ever balanced?!?
  151. Any ideas on the brand and name of these wheels?
  152. Tire Rotation Questions
  153. Runflat options
  154. Need some input about wheels!
  155. Michelin's PAX system
  156. Opinions, please!
  157. Thanks Alex!
  158. 18 x 7.5 with 45mm backspacing
  159. How did your MCS handling improve with non-run flat?
  160. Wilwood 11.75" Brake Kit Installed
  161. Painting the brake calipers
  162. Toyo T1S and Yoko Parada
  163. Yoko Avid V4s
  164. Need Help with Tires (Runflat went flat)
  165. 17in. OZ Superleggeras WTD
  166. Non-MINI related wheel question...
  167. Miata compact spare on MCS?
  168. My New Wheel hit a curb! Help!
  169. Brake Dust
  170. Fragile Tires
  171. Looking forward to joining the ranks of happy Mini owners
  172. other cars with the same bolt pattern?
  173. offset questions and treadepot.com
  174. 15'' 7 hole rims... need tires.
  175. 2 question??
  176. Team Dynamics ET38 w/ 215/40/17?
  177. Where to get Runflats mtd in mid TN area?
  178. Exactly what is brake fade?
  179. Looking for wheels
  180. cold hard steel
  181. Vibration and pulling right...
  182. cut thread
  183. Big brakes and 17" wheels
  184. Tire Noob
  185. Winter Tires
  186. Rear rotors smaller???
  187. Painted X-Lites for Winter
  188. Anyone seen these new MINI wheels?
  189. falken?yokohama?toyo?...
  190. Powdercoating inside of 2-piece R90 Wheel
  191. g-Force T/A KDW-2
  192. Snows on
  193. Prevent bottoming out, with new tires?
  194. Will 17" S-Lite center caps fit 16" R84 V-Spoke?
  195. For Sale - 4 Pirelli Euforis runflats
  196. Help with finding center caps
  197. Will these Rims fit??
  198. R90s from Classic Mini, OH
  199. Can Pirelli Euphoria Run-Flats Be Plugged or Repaired?
  200. tires, tires, tires....again
  201. FS: Silver 17 x7 S lite rims (only)
  202. Need Mini Spare
  203. 17 x 7 et 35
  204. New Wheels
  205. Now what
  206. Largest 18" tire size?
  207. Msfit found some studs...16 of them!!
  208. Winter Tires?
  209. SO-3 vs P-Zero Nero? Any tests?
  210. Need to buy Toyo Proxes 4 for stock 16" S-Lites - conflicted about the optimum size
  211. Tire Clearance Chart
  212. Doughnut spare....how to secure it.
  213. How do you know if you need new brake pads?
  214. mini center caps fit Volk TE37s ??
  215. Ro_Ja Formula 5 and 7
  216. What do you guys think of these rotors?
  217. Which Winter Tires on Stock 16" S Rims
  218. Which rims to get?
  219. summer tires in winter?
  220. exel speed
  221. pzero nero ALEX
  222. TZ10's....Nice
  223. new Volk TE37 "Cup" wheels on MCS ?
  224. Team Dynamics Mirage wheels are on!!
  225. 215/35/18 or 215/40/18
  226. Where to buy a compact spare?
  227. made my mind up!
  228. Great Tire Info!
  229. Tire weight
  230. 215/40 or 215/45?
  231. New Sizes for Avons Tech R & Kumhos 710?
  232. Rim damage caused by tire change avoidable?
  233. Hankook Ventus tires, anybody know anything about them?
  234. New TZ10s are on!
  235. question on anthracite flik wheels
  236. anybody running BBS RG-F in 15x7" for MCS??
  237. Brake upgrade review
  238. Dinan-Brembo: simple repackaging?
  239. White R90's are in!
  240. rimS
  241. Rota Sub-Zeros
  242. Opinions/ suggestions wanted
  243. The Hawk has landed!
  244. 15" R81 7-hole "Holey" Weight
  245. JCW sports brake kit
  246. Speed Star Wheel : a limited time offer @ TireRack
  247. 18" Wheel Weight
  248. 205/50 on SSR Comp 15x6"
  249. Heavier Wheels/Tires = Lower Dyno HP
  250. photoshop help needed
