New BBK from TCE
Old Dec 19, 2004 | 08:10 PM
onasled's Avatar
onasled
New BBK from TCE
OK, well it's new to me, but also somewhat new to the Mini. I spent the weekend installing a TCE Big Brake Kit via Randy Webb. This kit featurs the new larger rear rotor. I'll start by just posting a before and after pic of the rear wheel. I have some othet instalation pics I will post shortly.
AFTER . . . . . . BEFORE
Old Dec 20, 2004 | 07:08 AM
jazmini's Avatar
jazmini
Wow, that rear rotor is a lot bigger. Looks much better! :smile:
Old Dec 20, 2004 | 07:17 AM
Bisch's Avatar
Bisch
Looks great! You never think how small the OEM rears are until you see a comparison like that!!
p.s. Thanks again for your help....it's installed, and off to the dealer in about an hour...
Old Dec 20, 2004 | 07:22 AM
MyPocketRocket's Avatar
MyPocketRocket
Look like the brake pads only grip 50% of the discs?
Old Dec 20, 2004 | 09:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The BBK is limited by the stock caliper.
I think I see aftermarket brake pads installed- that helps.
The stock rotor is using a much smaller diameter while the TCE rotor uses a much larger diameter- I'd expect that the surface area of the rotor in contact with the brake pad would be similar to slightly larger than stock.
Another consideration is that the total mass of the rear rotor is much much larger and can handle heat loads much better than the stock rotor- this means the brakes perform better and resist overheating better.
The rotor slots also help remove the boundary gases compared to stock.
Old Dec 20, 2004 | 09:20 AM
toddtce's Avatar
toddtce
Same pad as before, so perhaps 50% might be a way to look at.
Rotor torque value is up about 15%.
squawSkiBum
Oct 2, 2015 09:21 AM
HaveATank
Sep 16, 2015 08:32 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
toddtce
Aug 29, 2015 11:13 AM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
