225/40/18 & 215/35/18
Old Dec 21, 2004 | 06:42 PM
S1monLM's Avatar
S1monLM
Im currently running on Pirelli Nero 215/35/18, and Im planning swap it out for Dunlop super sport race 225/40/18. Im running on coilover and 18x7.5 +45 offset, do you guys think it will rub?
Old Dec 22, 2004 | 09:55 AM
Alex@tirerack's Avatar
Alex@tirerack
In the back, when loaded full, and you hit a bump. a tad of dremel work will clear it up.
Alex
Old Dec 22, 2004 | 07:59 PM
Passat774's Avatar
Passat774
Alex,
Could you please give us the range of offsets that would work when using the 225/40/18.
I understand that the plastic will need to be trimmed in the back
thanks, a fellow wheel guy
Old Dec 22, 2004 | 08:58 PM
2perCooper's Avatar
2perCooper
Alex
So it only happens when fully loaded?? He also stated that he is lowered, I am lowered on H&R Springs, should that make any difference?
I am asking because I plan on getting some 18s in the spring time, and I would like to use 225/40-18s
Old Dec 23, 2004 | 02:51 AM
S1monLM's Avatar
S1monLM
How about 225/35/18 Pilot sport 2? Will they rub since the sidewall is much taller than other tires?
Old Dec 23, 2004 | 10:22 AM
Alex@tirerack
225's are wider than I can promise or guarantee to fit, reguardless of offset. When I have seen 225's under 24.0 diameter theyn usually only rub a small amount. at 23.0 no rub at all. I am not making any claims on what 225's work, they are wider that I can guaratee trouble free fitments.
Alex
Lexo350
Mar 5, 2008 12:12 PM
pimpedout97x
Tires, Wheels, & Brakes
22
Feb 9, 2008 02:06 PM
SuprCooperS
Oct 22, 2005 08:20 AM
BaldBikerGuy
Jun 5, 2005 04:49 AM
Alex@tirerack
Nov 29, 2002 02:26 PM
