tires, tires, tires....again
Tires
After my Yoko es100s, I am thinking about trying the Falken FK-451. With a treadware of 280 and stick well enough for a victory in STX. The only problem is that they don't come in an exact match for 205/45/17 (205/40/17, 215/40/17 and 215/45/17 exist).
Falken is also coming out with their next gen. Azenis in Nov.
Chris
Chris
Koolmini,
I have been having good luck with the Toyo Proxes T1S. But I have not run the Yokos for comparision, so I have no idea of the differences. The Toyo's have excellent build quality and they are round ( not as easy to find as it may seem) and fairly light. The T1S tread design is awesome in the wet but a bit on the noisy side.
Vince
Next cabin at the Dragon in 2003
Vince
ive had RE750 for about 10,000km now, and i love them...
they can be noisy, but they grip like glue on dry asphault, hot or cold (and i mean cold as in like 10 degrees celcius)
in the wet though they lose some of their composure
but i'd still recommend it over the SP5000, Pirelli P6 all road, and Birdgestone RE92 tires that i've had tried on other cars
Coordinator :: Low Country MINIs
on
toyo proxes 4 the best, highly recomended
heres a good place to get info and i put the link on the reviews of the toyo proxes 4
http://www.1010tires.com/tirereviews.asp
Kumho MX will satisfy your Dragon urges in the dry. The Toyo T1S is also a great choice, but a touch more expensive. I know you like to run 215/45-17's Kool, but I recommend 215/40-17, which will have a marginally wider footprint and will be a few tenths shorter giving better gearing.
Cheers,
Ryan
Cheers,
Ryan
A buddy of mine is running Falken FK-451's right now after he wore out the previous set of ES100's... He said the 451's provide a much nicer ride on the street but aren't as capable as the ES100's at the limits, especially in the wet. Even so, he said he is enjoying the plusher ride on his daily commute... His estimate is that the FK-451 is about 9/10th's as capable as the ES100's...
FWIW, he's going back to ES100's the next time he needs street tires, though...
